Hjelp Mister Nettet på pc'en
hey jeg har et problem i det siste har det vært ett problem med nettverket
jeg har drivet å surfet på nettet og fra tid til annen så kutter nettet seg..
tok en copy fra loggen på routeren min THOMSON ST780:
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 87.102.7.114 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 3): Protocol: ICMP Src ip: 24.27.74.59 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Port Unreacheable
FIREWALL icmp check (1 of 4): Protocol: ICMP Src ip: 71.98.84.46 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 3): Protocol: ICMP Src ip: 74.88.243.130 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 96.50.99.149 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 124.171.61.33 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Port Unreacheable
FIREWALL icmp check (1 of 3): Protocol: ICMP Src ip: 78.88.146.222 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 2): Protocol: ICMP Src ip: 24.209.42.72 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 5): Protocol: ICMP Src ip: 79.167.190.12 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
FIREWALL icmp check (1 of 3): Protocol: ICMP Src ip: 70.65.7.82 Dst ip: 85.164.151.222 Type: Destination Unreachable Code: Host Unreacheable
Litt mer etter en clear log + nettet hopper av:
FIREWALL event (1 of 1): modified rules
FIREWALL event (1 of 1): created rules
PPP PAP Authenticate Ack received
PPP PAP Authenticate Request sent
FIREWALL event (1 of 1): deleted rules
PPP link down (Internet) [85.164.148.238]
Endret av silinox
Det ser ut som om det er et problem med autentisering mot isp. Mulig det er en setting på router som resetter påloggingen din men det blir vill tipping fra min side.
takk for tipset vil det hjelpe å factory set routeren tror du?
