Overklokke en gammel prosessor!
Jeg trenger en del hjelp med min PIII 500Mhz!
Prosessor: PIII 500Mhz
Hovedkort: Aopen AX6BC
Har klart å komme opp i 560Mhz, men det må vel gå ann å kommer lengere!
SiSoftware Sandra
System Mainboard
MP Support : No
Model : AX6BC R2.57 Jan.03.2002 AOpen Inc.
BIOS ID : 01/03/2002-i440BX-00000006C-00
Memory Controller
Error Detection Method : 8-bit parity
Error Correction Capability : None
Supported/Current Memory Interleave : 1-way / 1-way
Number of Memory Slots : 2
Maximum Installable Memory : 512MB
Maximum Module Size : 256MB
Supported Memory Types : SDRAM
Supported Memory Voltages : 3.3V
Physical/BIOS Memory Banks
DIMM1 (RASL-0 RASL-1) : 128MB DIMM SDRAM single-bank
DIMM2 (RASL-2 RASL-3) : 128MB DIMM SDRAM single-bank
System Chipset
Model : Intel Corporation 82443BX/ZX 440BX/ZX CPU to PCI Bridge (AGP Implemented)
Bus(es) : ISA AGP USB SMBus/i2c
Front Side Bus Speed : 1x 112MHz (112MHz data rate)
Max FSB Speed / Max Memory Speed : 1x 100MHz / 1x 100MHz
In Order Queue Depth : 4 req(s)
Logical/Chipset Memory Banks
Bank 0 Setting : 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-3-3CL
Bank 1 Setting : 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-3-3CL
Bank 2 Setting : 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-3-3CL
Bank 3 Setting : 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-3-3CL
Bank 4 Setting : 64MB SDRAM 8-1-1-1R 6-1-1-1W 3-3-3CL
Multiplier : 1/1x
Refresh Rate : 15.60µs
Power Down Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : 128MB 16x(8Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz)
Memory Module 2 : 16MX64E-1338MX8 001021C3 128MB 16x(8Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz) (CL2 upto 100MHz)
Memory Module 3 : 64MB 8x(8Mx8) SDRAM PC100-222-622 (CL3 upto 125MHz) (CL2 upto 100MHz)
Environment Monitor 1
Model : Genesys GL518SM SMB
Mainboard Specific Support : No
AGP Bus
Version : 1.00
Speed : 75MHz
Current Data Transfer Rate : 2x 75MHz (150MHz data rate)
Side Band Enabled : Yes
Aperture Size : 16MB
LPC Hub Controller 1
Model : Intel Corporation 82371EB/MB PIIX4E/M ISA Bridge
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Multiplier : 1/4x
DMA Multiplier : 1/2x
USB Controller 1
Model : Intel Corporation 82371AB/EB/MB PIIX4/E/M USB Controller
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
System SMBus Controller 1
Model : Intel PIIX4 SMBus / compatible
Speed : 16kHz
Expansion Slot(s)
ISA : ISA 16-bit 5V FullLength
PCI (Ch) : PCI 32-bit 5V FullLength Available
PCI (Bh) : PCI 32-bit 5V FullLength InUse (Brooktree Corp Bt878 Mediastream Controller)
PCI (Ah) : PCI 32-bit 5V FullLength InUse (Compex ReadyLink Express 10/10 Fast Ethernet Adapter)
AGP (8h) : AGP 32-bit 3.3V FullLength InUse (Creative Labs Graphics Blaster RIVA TNT)
Port Connector(s)
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO Compatible - Floppy / None
COM1 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 Compatible - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB25 pin female / DB25 pin female
Keyboard : Keyboard Port - None / PS/2
PS/2 Mouse - Detected : Mouse Port - PS/2 / PS/2
USB : USB - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 2507 : Mainboard has too few memory slots. Upgrading the memory may be difficult or expensive.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Warning 2541 : FSB exceeds Chipset rated speed. Reduce FSB.
Warning 2542 : Memory bus speed exceeds Chipset rated speed. Reduce FSB/memory multiplier.
Warning 2523 : Memory bus speed exceeds memory rated speed. Reduce memory bus speed.
Warning 2521 : AGP bus speed is too high. Reduce FSB speed or FSB/AGP multiplier.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Stakkar meg, er bare 14, så fatter ikke så mye.... :(
Mener at 560MHz er temmelig max av hva man får denne opp i. Sansynligvis grunnet at PCI/AGP-hastigheten blir for høy. om du kan justere dividere til PCI/AGP-bussen så kanskje du kommer litt høyere, men jeg tror ikke dette er mulig på såpass gamle HK.
heh..vet at den e gammel og suger!
Men har liksom ingen inntekt til å kjøpe ny heller! :(
Legger litt extra info om prosessoren:
SiSoftware Sandra
Processor(s)
Model : Intel® Pentium® III
Co-Processor (FPU) : Built-in
Speed : 560MHz
Performance Rating : PR672 (estimated)
Type : Standard
Packaging : SECC(2) Slot1 Cartridge
Rated Speed/FSB : 500MHz / 1x 100MHz
Multiplier : 5x
Generation : 6th (6x86)
Model Information : P6K (Katmai) Pentium III 450-600 2-2.05V
Revision/Stepping : 7 / 3 (0)
Stepping Mask : kC0
Microcode : MU06730E
Core Voltage Rating : 2.050V
Serial Number : 0000-0673-0002-572F-7EE0-4EA0
Processor Cache(s)
Internal Data Cache : 16kB synchronous write-back (4-way, 32 byte line size)
Internal Instruction Cache : 16kB synchronous write-back (4-way, 32 byte line size)
L2 On-board Cache : 512kB ECC synchronous write-back (4-way, 32 byte line size)
L2 Cache Multiplier : 1/2x (equiv. 280MHz)
Host Interface(s)
Upgradeability
Socket/Slot : SLOT 1
Upgrade Interface : Slot 1
Supported Speed(s) : 600MHz (or more)
Power Rating(s)
Core Power : 32W (estimated)
Sensors
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : No
CID - Context ID : No
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
CMOV - Conditional Move Instruction : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : Yes
CLF - Cache Line Flush Support : No
Unknown : No
DS - Debug Trace & EMON Store : No
ACPI - Software Clock Control : No
MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : No
SS - Self Snoop : No
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : No
PBE - Pending Break Enable : No
IA-64 Technology : No
DAZ - Denormals Are Zero : No
Advanced Settings
L2 Cacheable Range : 4GB
L2 Cache Grouping : 1 bank(s)
L2 Cache Latency : 8 clock(s)
Data Error Checking : Yes
Low Power Mode : Yes
Fast Strings : Yes
In Order Queue Depth : 8 req(s)
Machine Check Architecture Settings
No. Reporting Banks : 5 bank(s)
Performance Tips
Warning 222 : CPU speed higher than rated speed! Reduce CPU speed.
Tip 210 : Mainboard supports faster CPUs, so the CPU can be upgraded when needed.
Warning 220 : The CPU Serial Number is enabled.
Fikk PIII-500 opp i ca. 600MHz med MSI 6163Pro-HK. Frya selvfølgelig dette HK-et og bytta til AOpen. Stopper på 560MHz ja.
Se http://www.cpudatabase.com/ Her kan du finne prosessoren din.
Jeg ser at gjennomsnittlig overklokking er 612mhz (156 brukere).
Du kan ta et par av innleggene med en klype salt, slik at konklusjonen er at du hvertfall nærmer deg maks overklokking på prosessoren din med standard kjøling.
p3-500 er egentlig ikke en så veldig god overklokker. Da var det bedre om du kunne få tak i p3-350, p3-333 med samme core/l2 cache som p3-500, og heller overklokke disse opp til ca 500mhz...
Det var som regel L2 cachen som bremset disse prosessorene. Å dissable l2 cachen gav som regel høyere overklokking på prosessoren, men dårligere ytelse (l2 cache er temmelig viktig)
*mimre*
DrErling
?? Mitt gamle P2B kjørte 133mhz med 33/66 mhz i PCI/AGP frekvens...
Joda, det er mange BX chipsett som taklet både 133 og høyere. Men han har en p3-500 som sjelden takler så høy fsb. Det betyr at 5*133=666mhz blir i meste laget for den prosessoren, selv om agp/pci frekvensen da etter all sansynlighet blir riktig.
Det er vel ved 124mhz fsb at agp/pci frekvensen setter seg automatisk ned. Synes å huske at 123mhz kunne ta knekken på både det ene og det andre, mens 125mhz var safe (og faktisk en underklokking av pci/agp).
DrErling
