console
Gjest Slettet+1374861
mkay...i will teach u.. ;D
her er deler av min config.cfg fil:
console "1.0"
crosshair "1.000000"
fps_max "99"
fps_modem "99"
gamma "99"
host_framerate "100"
brightness "50"
con_color "255 255 255"
net_graph "3"
net_graphwidth "320"
graphheight "42"
net_scale "5"
net_graphpos "1"
net_graphsolid "0"
net_graph "0"
sv_aim "0.000000"
hpk_maxsize "0"
viewsize "110.000000"
r_bmodelhighfrac "5.0"
mp_decals "0.0"
gl_dither "0"
gl_overbright "0"
gl_palette_tex "0"
gl_keeptjunctions "0"
gl_wateramp "0"
gl_ztrick "1"
gl_lightholes "0"
gl_spriteblend "1"
gl_polyoffset "0.1"
gl_cull "1"
gl_smoothmodels "0"
gl_monolights "0"
gl_picmip "1"
gl_playermip "1"
gl_max_size "64"
gl_alphamin "0.5"
gl_polyoffset "0.1"
gl_monolights "0"
gl_flipmatrix "0"
max_shells "0"
gl_monolights "0"
max_smokepuffs "20"
gl_cull "1"
mp_decals "0"
disse er først og fremst til å øke FPS og lysmengde (enklere å se mørke plasser).
mer her:
s_rolloff "1.0"
s_doppler "0.0"
s_distance "60"
s_automin_distance "2.0"
s_automax_distance "30.0"
s_min_distance "8.0"
s_max_distance "1000.0"
s_leafnum "0"
s_refgain "0.4"
s_refdelay "4"
s_polykeep "1000000000"
s_polysize "10000000"
s_numpolys "200"
s_bloat "2.0"
s_verbwet "0.25"
s_a3d "0"
s_eax "0.000000"
volume "0.1500"
suitvolume "0.680000"
hisound "1.000000"
bgmvolume "1.000000"
_snd_mixahead "0.1"
lydsettings. gjør det enklere å høre motstanderen på lang avstand. anbefaler btw headphones på det sterkeste. det BØR vere headphones du bruker viss du skal spille seriøst.
mer her:
team ""
model "none"
skin ""
topcolor "30"
bottomcolor "6"
dette er ikke så viktig. den gjør bare slik at hvis du skal se en demo blir ikke en del av modelene "bugged". more:
rate "5500"
cl_cmdrate "20"
cl_updaterate "20"
cl_rate "5500"
cl_lw "1"
cl_lc "1"
cl_latency "-25.987"
tracker "0"
cl_dlmax "128"
cl_himodels "0.000000"
cl_idealpitchscale "0.8"
cl_timeout "35"
cl_cmdbackup "2"
cl_download_ingame "1"
cl_allowdownload "1"
cl_allowupload "1"
settings til en ISDN oppkobling. ikke bruk dette hvis du har ASDL eller modem! det virker svært fint på 1 linje ISDN ;) ono mas:
hud_takesshots "0"
fastsprites "0"
hud_capturemouse "1"
hud_fastswitch "1"
hud_centerid "1"
hud_classautokill "1"
setinfo "lefthand" "0"
setinfo "vgui_menus" "0"
setinfo "ah" "0"
setinfo "dm" "0"
setinfo "autoteambalance" "0"
+mlook
en del instillinger her, som foreksempel høyreholdt våpen, avskrudde hjelpetekster med mer ;)
skulle du trenge noe hjelp for å få informasjon om noen av kommandoene eller hjelp til å bruke disse er det bare å svare her...så skal jeg se på saken ;)
håper du fikk litt hjelp og tips. det er forresten lite plasser og få hjelp til slikt. alle de norske sidene ble lagt ned for en tid tilbake. :
  • 2 uker senere...
flappen2k- try this one:
rate "9999"
cl_cmdrate "35"
cl_updaterate "40"
cl_rate "999"
cl_lw "1"
cl_lc "1"
cl_timeout "35"
cl_allowupload "1"
  • 3 uker senere...
