the_fire Skrevet 5. mars 2010 Del Skrevet 5. mars 2010 Hver gang jeg logger inn på MacBook-en min, spretter følgende vindu opp: Hva kan det være, og hvordan kan jeg hindre det i å starte slik hver gang jeg logger på? Har MacBook Pro med 10.6.2. Last login: Fri Mar 5 00:57:22 on console kri[***]ds-macbook-pro:~ k[***]$ /System/Library/Frameworks/JavaVM.framework/Versions/A/Commands/java ; exit; Usage: java [-options] class [args...] (to execute a class) or java [-options] -jar jarfile [args...] (to execute a jar file) where options include: -d32 use a 32-bit data model if available -d64 use a 64-bit data model if available (implies -server, only for x86_64) -client to select the "client" VM -server to select the "server" VM -jvm is a synonym for the "client" VM [deprecated] -hotspot is a synonym for the "client" VM [deprecated] The default VM is client. -cp <class search path of directories and zip/jar files> -classpath <class search path of directories and zip/jar files> A : separated list of directories, JAR archives, and ZIP archives to search for class files. -D<name>=<value> set a system property -verbose[:class|gc|jni] enable verbose output -version print product version and exit -version:<value> require the specified version to run -showversion print product version and continue -jre-restrict-search | -jre-no-restrict-search include/exclude user private JREs in the version search -? -help print this help message -X print help on non-standard options -ea[:<packagename>...|:<classname>] -enableassertions[:<packagename>...|:<classname>] enable assertions -da[:<packagename>...|:<classname>] -disableassertions[:<packagename>...|:<classname>] disable assertions -esa | -enablesystemassertions enable system assertions -dsa | -disablesystemassertions disable system assertions -agentlib:<libname>[=<options>] load native agent library <libname>, e.g. -agentlib:hprof see also, -agentlib:jdwp=help and -agentlib:hprof=help -agentpath:<pathname>[=<options>] load native agent library by full pathname -javaagent:<jarpath>[=<options>] load Java programming language agent, see java.lang.instrument -splash:<imagepath> show splash screen with specified image logout [Prosess utført] Lenke til kommentar
Jesper Karsrud Skrevet 6. mars 2010 Del Skrevet 6. mars 2010 Du kan jo gå inn i System Preferences og se om det ligger noe under Login Items på kontoen din. Det skjer jo ingenting på den ene linja som starter der, så det er vel egentlig ikke noe stort problem, men skjønner at det er plagsomt at den popper opp hver gang du logger på Lenke til kommentar
the_fire Skrevet 7. mars 2010 Forfatter Del Skrevet 7. mars 2010 Takker, det lå under Login Items. Problem løst. Lenke til kommentar
