Grenville Skrevet 7. juni 2003 Del Skrevet 7. juni 2003 sitter her och vurderer å sette opp en nettradio og lastet ned shoutcast plugin. må man ha noe spesielt for å kunne gjøre dette ? jeg har online.no internett , er det mulig for meg å ha nettradio ? Lenke til kommentar
Grenville Skrevet 7. juni 2003 Forfatter Del Skrevet 7. juni 2003 ingen som kan hjelpe meg ? jeg får koblet meg til , men det virker som at den kobler seg fra. sjekk på dette : <06/07/03@12:37:13> [dest: 205.188.234.42] starting stream (UID: 0)[L: 1]{A: SHOUTcast Directory Tester}(P: 0) <06/07/03@12:37:13> [dest: 205.188.234.42] connection closed (0 seconds) (UID: 0)[L: 0]{Bytes: 8192}(P: 0) <06/07/03@12:37:15> [yp_add] yp.shoutcast.com added me successfully <06/07/03@12:38:12> [dest: 80.212.173.68] starting stream (UID: 1)[L: 1]{A: WinampMPEG/2.7}(P: 0) <06/07/03@12:38:14> [yp_tch] yp.shoutcast.com touched! <06/07/03@12:38:20> [dest: 80.212.173.68] connection closed (8 seconds) (UID: 1)[L: 0]{Bytes: 57344}(P: 0) <06/07/03@12:38:20> [dest: 80.212.173.68] starting stream (UID: 2)[L: 1]{A: WinampMPEG/2.7}(P: 0) <06/07/03@12:38:24> [dest: 80.212.173.68] starting stream (UID: 3)[L: 2]{A: WinampMPEG/2.7}(P: 1) <06/07/03@12:38:24> [dest: 80.212.173.68] connection closed (3 seconds) (UID: 2)[L: 1]{Bytes: 24576}(P: 0) <06/07/03@12:38:27> [dest: 80.212.173.68] connection closed (4 seconds) (UID: 3)[L: 0]{Bytes: 24576}(P: 1) <06/07/03@12:38:28> [dest: 80.212.173.68] starting stream (UID: 4)[L: 1]{A: WinampMPEG/2.7}(P: 0) <06/07/03@12:39:15> [yp_tch] yp.shoutcast.com touched! <06/07/03@12:40:16> [yp_tch] yp.shoutcast.com touched! <06/07/03@12:41:16> [yp_tch] yp.shoutcast.com touched! <06/07/03@12:42:17> [yp_tch] yp.shoutcast.com touched , kanskje jeg skal bytte ut det med noe annet , men hva ?. takk for all hjelp <06/07/03@12:42:17> [yp_tch] yp.shoutcast.com touched! Lenke til kommentar
