LØST: PSN nede : Error 8001050f
90 stemmer
  1. 1. Fungerer PSN hos deg?
Everyone READ THIS PLEASE.
Here's what's going on right now: something with the PS3's internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3's clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
Does this affect me?
-If you have a Slim PS3, you're good to go. Continue playing it as normal.
-If you have a "fat" PS3, you may be affected. Some fat PS3s have worked ok, but it seems a good majority have been bugged.
What does this bug mean?
-If affected, your date and time has been set to a random past date. This prevents you from signing into PSN, playing any PSN games, or using any DLC. Your trophies will also not display correctly or be able to sync.
How do I fix it?
-You can't. Even if you don't sign into PSN, it won't help. This is a hardware issue.
So, what do I do?
-Wait 24 hours. Other products that have had similar bugs have corrected themselves after the "bugged" day. On Monday around 6pm central time, all PS3s will automatically correct themselves...maybe.
-If that doesn't work, we'll need a firmware update from Sony, which should be a pretty important priority for them right now.
Did I lose my data/themes/etc?
Your save data/games/dlc/themes are fine. They'll be fixed when the PS3 is fixed. Trophies are uncertain right now, but they'll be fine if you've synced them before the PS3 was bugged. Unsynced trophies are an unknown right now.
If I have a bugged PS3, can I still use it?
It's probably not a good idea, as I have no idea what will happen to the trophies you earn during the bugged time. Movies/media will work fine.
Så i beste fall blir alt greit av seg selv ved midnatt (når 2. mars starter). I verste fall er dette mer komplekse greier som kan ta en del dager, kanske så mye som 1-2 uker.
Gjest Slettet-D7I5Gr2
Skulle tro det var 31.desember 2000! Saklig av meg å vente helt til idag for å starte med Heavy Rain. :p
Heldigvis ble jeg ferdig med Wrestlemainia i mårrest. :D
Denne uka kan bli meget interessant hvis det ikke er enkel løsning på dette. Vi står potensielt ovenfor en av de verste fadesene i konsollhistorien, verre enn Red Ring of Death på X360...
Uansett, har du en eldre PS3 så ikke slå den på foreløpig!
Endret av kilik
Startet playstation i stad, tenkte at det bare var PSN som var nede for et lite øyeblikk. Så startet å spille The Saboteur, og fant ut dette nå at det var litt mer en at det bare nede for en liten stund. Men har da alle mine trophies. Så ingen skade skjedd. Har en PS3 80GB, så høres merkelig ut dette med at du mister trofeene vis du spille et trophyspill...
Endret av Bister
Ikke alle spill som har trophies får problemer nei, men usikkert hva som kan skje, så jeg vil ikke anbefale å prøve slike spill nå hvis man er redd for trophies. Har man allerede startet PS3 i dag er skaden skjedd, men de som ikke har startet den bør vente til over 01.00 i kveld/natt da den innebygde klokken i PS3 tror det er skuddår 29. februar og ikke 1. mars i dag.
Endret av kilik
20 millioner PS3-er som må leveres inn på en gang greier Sony umulig å håndtere. I såfall snakker vi ventetider på flere måneder. Får satse på at dette kan fikses på en enklere måte.
Sies at relativt nye 80 GB-modeller ikke har denne feilen.
