StylishXx Skrevet 27. februar 2010 Del Skrevet 27. februar 2010 (endret) Hei prøver og lage en side for venner osv... men får denne feilmelingen: Notice: Undefined index: $name in /www/zzl.org/m/a/f/mafialegend/htdocs/_check_user.php on line 10 Notice: Undefined index: cookieusername in /www/zzl.org/m/a/f/mafialegend/htdocs/_connect.php on line 18. _check_user.php: <?php ################################################# # # # Auteur: J. Klompen # # Site : http://www.maffia.net.tc # # Date : 15 apr 2005 # # Email: [email protected] # # # ################################################# if($_POST['name']) { $name = $_POST['name']; $password = $_POST['password']; include "_connect.php"; $datem = date( "j.M.Y - G:i:s" ); $opdracht = "insert INTO ip_logs values('0','$name','$password','$datem','$REMOTE_ADDR')"; $resultaat = mysql_query($opdracht); $lijstGebruikers = "SELECT * FROM users WHERE username='$name' AND password='$password'"; $resultLijstGebruikers = mysql_query($lijstGebruikers); if (mysql_num_rows($resultLijstGebruikers) == 1) { $name = $_POST['name']; $password = $_POST['password']; setcookie("cookieusername", $name,time()+86400); setcookie("cookiepassword", $password,time()+86400); $lijstGebruikers = "SELECT `id` FROM users WHERE `username`='$name' AND `password`='$password'"; $resultLijstGebruikers = mysql_query($lijstGebruikers); while ($row = mysql_fetch_array($resultLijstGebruikers)) { setcookie("userid", $row[id],time()+86400); } $melding = "Login succes, <br /> You will be redirected in 2 seconds"; echo "<META http-equiv=refresh content=\"0;url=login_true.php\">"; } else { $melding = "Login wrong"; } } ?> _connect.php: <?PHP ################################################# # # # Auteur: J. Klompen # # Site : http://www.maffia.net.tc # # Date : 15 apr 2005 # # Email: [email protected] # # # ################################################# $Host = "#"; $User = "#"; $Pass = "#"; $DBName = "#"; $Link = mysql_connect ($Host, $User, $Pass); mysql_select_db($DBName); $cookieusername = $_COOKIE['cookieusername']; $datem = date( "j.M.Y - G:i:s" ); ?> Beklager, viste ikke hvordan jeg fikk det i en script box. Håper noen kan hjelpe meg. Endret 27. februar 2010 av StylishXx Lenke til kommentar
Runar Skrevet 27. februar 2010 Del Skrevet 27. februar 2010 Du sier lite om hva koden din skal gjøre, sett at du faktisk forstår det selv. Er du sikker på at et mafiaspill er det beste å lage for en på ditt kunnskapsnivå? Hvis jeg ikke tar feil har du et skjema som sender data videre til _check_user.php. Dette skjemaet må ha et felt med navn "name" for at koden din skal kunne sjekke om brukernavnet eksisterer. Kan vi få se koden fra den filen også? Vær snill å bruk eller [php] rundt, så gjør du det letter å lese. Lenke til kommentar
Noble Skrevet 22. mars 2010 Del Skrevet 22. mars 2010 Kan ikke en mod sette en sticky ang spørsmål om mafiaspill? Lenke til kommentar
Runar Skrevet 22. mars 2010 Del Skrevet 22. mars 2010 Kan ikke en mod sette en sticky ang spørsmål om mafiaspill? Hva mener du det skulle være godt for? Det er jo ikke imot forumes retningslinjer å stille spørsmål relatert til mafiaspill. Lenke til kommentar
