Tråden for romfergeoppdraget STS-131
HKS
Oppdatering:
Nedtellingen for STS-131 er nå i gang!
Planlagt T-0 er som nevnt i første post, mandag 5. april (2. påskedag) klokken 12:21 norsk tid.
Foreløpig er det 80% sjanse for at været er bra nok!
Aktiviteter i nedtellingen fredag og lørdag:
NB! Alle tider er i østkyst-tid (EDT).
Launch-3 Days (Friday, April 2)
Prepare for the start of the STS-131 launch countdown
Perform the call to stations (2:30 a.m.)
Countdown begins at the T-43 hour mark (3 a.m.)
Begin final vehicle and facility closeouts for launch
Check out backup flight systems
Configure avionics systems for launch
Review flight software stored in mass memory units and display systems
Verify backup flight system software in Discovery's general purpose computer
Activate and test navigational systems (4 p.m.)
Complete preparations to load power reactant storage and distribution system (6 p.m.)
Flight deck preliminary inspections complete (7 p.m.)
Enter 4-hour built-in hold at T-27 hours (7 p.m.)
Clear launch pad of all nonessential personnel
Perform test of the vehicle's pyrotechnic initiator controllers
Resume countdown (11 p.m.)
Begin operations to load cryogenic reactants into Discovery’s fuel cell storage tanks (11 p.m.)
Launch-2 Days (Saturday, April 3)
Enter 9-hour built-in hold at T-19 hours (7 a.m.)
Offload 645 lb LO2 from reactant tanks
Demate orbiter mid-body umbilical unit (1:30 p.m.)
Resume orbiter and ground support equipment closeouts
Resume countdown (4 p.m.)
Main engine avionics, pneumatics and controller checkout (4 p.m.)
External Tank feedline inspection/camera cleaning
Flight Crew Equipment stowage
Begin removal of pad ground support equipment
Pressekonferanse nuh på nasa tv...
Lurer på om eg kan få vist nasa tv på min android mobil?
Vet ikke, men for alle som har iPhone så kan de laste ned NASA sin offisielle app. Det er også flere uoffisielle apps som har NASA TV i AppStore.
L-1 dag nå!
Alt har så langt gått veldig bra i nedtellingen. Discovery oppfører seg fint, og værvarslet sier fremdeles at det er 80% sjanse for at været er bra nok. Forhåpentligvis kan det bli en meget fin oppskytning imorgen, med Discovery som flyr inn i soloppgangen!
Her har vi dagens aktiviteter på Kennedy Space Center. Dere ser dagen slutter med at de begynner å fylle opp den eksterne tanken med flytende drivstoff.
NB! Alle tider er i EDT!
Launch-1 Day (Sunday, April 4)
Enter built-in 13 hours, 56 minute hold at T-11 hours (12 a.m.)
Activate the orbiter's communications systems
Lower engine support platforms, retract access platforms
External Tank Inspections
Complete Flight Crew Systems time critical stowage (middeck payloads)
Rotating Service Structure begins move away from Discovery to the park position (9:30 a.m.)
Perform ascent switch list
Fuel cell flow-through purge complete
Resume countdown at T-11 hours (1:56 p.m.)
Activate the orbiter's fuel cells (3:06 p.m.)
Clear the blast danger area of all nonessential personnel
Switch Discovery’s purge air to gaseous nitrogen (3:56 p.m.)
Complete final walkdowns
Enter 2-hour built-in hold at the T-6 hour mark (6:56 p.m.)
Complete tanking preparations
Launch team verifies no violations of launch commit criteria prior to cryogenic loading of the external tank
Clear pad of all personnel
Resume countdown (8:56 p.m.)
Chill down propellant transfer lines (8:56 p.m.)
Begin loading the external fuel tank with about 500,000 gallons of cryogenic propellants (about 9:06 p.m.)
Enter 2-hour, 30-minute built-in hold at T-3 hours (11:56 p.m.)
Perform inertial measurement unit preflight calibration
Align Merritt Island Launch Area tracking antennas
Complete filling the external tank with its flight load of liquid hydrogen and liquid oxygen propellants (about 11:56 p.m.)
Final Inspection Team and Closeout Crew proceeds to launch pad
Mens vi venter, så setter jeg inn et bilde fra torsdag, når lasterommet til Discovery ble lukket for siste gang før oppskytningen. Bildet er tatt i PCR (Payload Cangeout Room) som er inne i RSS (Rotating Service Structure).
Ca. 45 minutter til MMT (Mission Management Team) skal møtes for å diskutere om de skal gi GO til å begynne å fylle Discovery sin eksterne tank med flytende drivstoff. Hvis de gir GO starter prosessen med å fylle over 2 millioner liter med flytende oksygen og flytende hydrogen litt over klokken 03:00 i natt norsk tid.
Setter inn et bilde etter at RSS ble rotert vekk fra Discovery før idag:
SE BILDET I FULL OPPLØSNING
God morgen!
Iløpet av natten har tankingen av Discovery gått bra. Astronautene er nå på vei ut til romfergen!
Så langt ser alt bra ut!
Her er aktivitetene planlagt i nedtellingen idag frem til T-9 minutter:
Launch Day (Monday, April 5)
Resume countdown at T-3 hours (2:26 a.m.)
Perform open loop test with Eastern Range
Crew departs Operations and Checkout Building for the pad (2:31 a.m.)
Complete closeout preparations in the White Room
Check cockpit switch configurations
Begin Eastern Range final network open loop command checks
Flight crew begins entry into the orbiter (3:01 a.m.)
Astronauts perform air-to-ground voice checks with Launch and Mission Control
Begin to close Discovery's crew hatch (4:06 a.m.)
Perform hatch seal and cabin leak checks
Complete White Room closeout
Closeout crew moves to fallback area
Primary ascent guidance data is transferred to the backup flight system
Enter 10-minute hold at T-20 minutes (5:06 a.m.)
NASA test director conducts final launch team briefings
Resume countdown at T-20 minutes (5:16 a.m.)
Transition the orbiter's onboard computers to launch configuration
Start fuel cell thermal conditioning
Close orbiter cabin vent valves
Transition backup flight system to launch configuration
Enter estimated 45-minute hold at T-9 minutes (5:27 a.m.)
Launch director, Mission Management Team and NASA test director conduct final polls for "go/no go" to launch
Resume countdown at T-9 minutes (about 6:12 a.m.)
Endret av [GDI]Raptor
Det lille tekniske problemet de hadde med en av Discovery sine brenselceller har de nå kommet frem til at ikke blir noe problem for dette oppdraget.
Været er fremdeles GO!
Nedtellingen står på T-9 minutter, og det er pause i nedtellingen.
Mot slutten av denne pausen skal NASA sin "launch director" "polle" eller spørre hele teamet om de er GO eller NO GO for oppskytning.
Vi er klare til å komme ut av den siste pausen i nedtellingen!
Når vi kommer ut av T-9 minutter tar GLS (Ground Launch Sequencer) over nedtellingen. Dette dataprogrammet kontrollerer nedtellingen helt frem til T-31 sekunder. Da tar Discovery sine datamaskiner over kontrollen!
Her er aktivitetene i "terminal count":
Start automatic ground launch sequencer (T-9 minutes)
Retract orbiter crew access arm (T-7:30)
Start APU recorders (T-6:15)
Start auxiliary power units (T-5)
Terminate liquid oxygen replenish (T-4:55)
Start orbiter aerosurface profile test (T-3:55)
Start main engine gimbal profile test (T-3:30)
Pressurize liquid oxygen tank (T-2:55)
Begin retracting the gaseous oxygen vent arm (T-2:50)
Fuel cells to internal reactants (T-2:35)
Pressurize liquid hydrogen tank (T-1:57)
Deactivate bi-pod heaters (T-1:52)
Deactivate solid rocket booster joint heaters (T-0:50 seconds)
Orbiter transfers from ground to internal power (T-0:50 seconds)
Ground launch sequencer go for auto sequence start (T-0:31 seconds)
Booster gimbal profile (T-0:21 seconds)
Ignition of three space shuttle main engines (T-6.6 seconds)
Booster ignition and liftoff (T-0)
