Telenor logger seg svært ofte på min router
Hei
Telenor logger seg svært ofte på min router, er det noen her ute som kan gi en logisk forklaring på dette?
Ringte Telenor for å høre og det var ikke lett skal jeg si dere å komme igjennom til rett vedkommende som hadde med dette å gjøre :)
Men vedkommende sa bare at dette var en rutine å gjøre dette av og til for å sjekke linja mellom dem og kunden, dvs meg,,
Men sjekk denne router logg som er min (iallefall et utdrag av den).
11|02/24/2010 13:21:55 |146.172.4.133 | |User:TnExtrnlRlrs
TELNET Login Successfully
12|02/24/2010 12:35:34 |146.172.4.133 | |User:TnExtrnlRlrs
13|02/24/2010 11:51:57 |146.172.4.133 | |User:TnExtrnlRlrs
14|02/24/2010 11:47:04 |146.172.4.133 | |User:TnExtrnlRlrs
15|02/24/2010 10:34:56 |146.172.4.133 | |User:TnExtrnlRlrs
16|02/24/2010 10:26:18 |146.172.4.133 | |User:TnExtrnlRlrs
17|02/24/2010 09:35:46 |146.172.4.133 | |User:TnExtrnlRlrs
18|02/24/2010 08:28:11 |146.172.4.133 | |User:TnExtrnlRlrs
19|02/24/2010 08:25:06 |146.172.4.133 | |User:TnExtrnlRlrs
20|02/24/2010 07:51:18 |146.172.4.133 | |User:TnExtrnlRlrs
21|02/24/2010 07:30:38 |146.172.4.133 | |User:TnExtrnlRlrs
22|02/24/2010 06:50:34 |146.172.4.133 | |User:TnExtrnlRlrs
23|02/24/2010 06:48:48 |146.172.4.133 | |User:TnExtrnlRlrs
24|02/24/2010 05:39:12 |146.172.4.133 | |User:TnExtrnlRlrs
25|02/24/2010 05:24:46 |146.172.4.133 | |User:TnExtrnlRlrs
26|02/24/2010 04:47:12 |146.172.4.133 | |User:TnExtrnlRlrs
27|02/24/2010 04:38:24 |146.172.4.133 | |User:TnExtrnlRlrs
28|02/24/2010 03:53:18 |146.172.4.133 | |User:TnExtrnlRlrs
29|02/24/2010 02:47:37 |146.172.4.133 | |User:TnExtrnlRlrs
30|02/24/2010 02:32:57 |146.172.4.133 | |User:TnExtrnlRlrs
31|02/24/2010 01:48:39 |146.172.4.133 | |User:TnExtrnlRlrs
32|02/24/2010 01:32:23 |146.172.4.133 | |User:TnExtrnlRlrs
33|02/24/2010 00:23:05 |146.172.4.133 | |User:TnExtrnlRlrs
End of Logs
Det er jo oftere enn 1 gang i timen..
og dette pågår hele tiden..
Hva gjør de inne på min router?
ip adressen dere ser er telenor sin, det har jeg fått bekrefte fra telenor.
Noen ganger står det slik:
2|02/22/2010 23:28:44 |146.172.4.133 | |User:TnExtrnlRlrs
3|02/22/2010 18:03:01 | | |Tr069
0:Tx SetParameterValuesResponse
4|02/22/2010 18:03:01 | | |Tr069
0:Rx SetParameterValues
5|02/22/2010 18:03:01 | | |Tr069
0:Tx GetParameterValuesResponse
6|02/22/2010 18:03:01 | | |Tr069
0:Rx GetParameterValues
7|02/22/2010 18:03:01 | | |Tr069
0:Tx EmptyPost
8|02/22/2010 18:03:01 | | |Tr069
0:Rx InformResponse
9|02/22/2010 18:03:01 | | |Tr069
0:Tx Inform, evt=0x4, rty=0
10|02/22/2010 18:02:53 | | |Tr069
Men aner ikke hva dette betyr.. vet dere?
vel det er jo tydeligvis noe automatisert ihvertfall. jeg tror neppe du har noe å frykte - det er nok bare samling av statistisk informasjon for å gjøre jobben enklere for support ved evt. feil oppstår. Det er første gangen jeg har sett inlogging på ruteren for å gjøre dette, men det er sikkert nyttige data du kan hente ut på denne måten også.
Hvis du virkelig vil så er det jo ikke værre enn ¨endre passordet på login for å forhindre dette. Det er ingen krav om at du må bruke standard konfig på ruteren tross alt ved mindre du skal senere be om support (så ha en backup av configen du kan gå tilbake til om du endrer noe).
Som sagt, jeg tror ikke det er noe å bekymre seg over. Det er svært lite personlige data eller informasjon om nøyaktig hva det er du overfører som lagres i ruteren uansett. De kunne nok sett hvor på nettet du koblet deg til, men thats about it, og det er de jo uansett lovpålagt til å logge (uten at de trenger å logge inn i ruteren av den grunn).
Men... de bør jo kunne gi deg en forklaring på hva det er de gjør. Hvis du skal spørre dem så tror jeg det er best å gjøre skriftlig på mail siden denne typen automatisering er det som regel bare de som er litt opp i systemet som styrer med - ikke de som sitter på telefonsupporten rett mot brukerene - og det er mye enklere å forwarde en epost opp i systemet enn å prøve å få snakket med en av dem når du ringer inn.
-Stigma
-Stigma
Dette hjelper desverre svært lite.
Man har en vanlig "admin" passord og man har et "master" passord, kunden har da admin tilgang, mens ISP har "master" tilgang.
Dette vil da si at ISP`en uansett kan logge seg inn på utstyret selv om man bytter adminpassordet.
Det er et provisjoneringsverktøy som sjekker info mot et par andre systemer i forhold til hastighet og støymargin på linjen din. Det er ikke "farlig" og heller ikke til belastning for din del, tvertimot da den ofte provisjonerer port og modem oppover enn nedover.
