Diskusjon om Battlefield 3
Jeg spilte en runde TDM på Canals istad.
Av de 20 gangene jeg døde var 15 av dem rundt hjørnet, ute av synet til den som drepte meg.
Det er gjengangeren, mer enn vanlig, etter siste patch :(
Er noe rart med at småvåpen går igjennom 15 cm betongvegger, blir like overrasket hver gang...
Det er clientside hitdetection. Spiller man på dårlige servere, evt han som skaut deg/du lagger så skjer slikt. Betyr likevel ikke at du skulle overlevd, men at du egentlig skulle spist jord noen ms tidligere.
Network Smoothing Factor:
This slider controls interpolation, a technique which predicts where a particular moving object or character is currently located in the game world, based on actual locational data periodically received over the network. If an enemy soldier is running along in front of you, interpolation allows their movement to appear fluid, calculating their predicted movement across the screen even though your computer is receiving only periodic updates of where they actually are. So instead of seeing a person jerkily warping from point to point, you see smooth animated motion all the way along. By reducing this slider, you can reduce the use of interpolation, and in turn potentially increase your accuracy by reducing latency; you're more likely to shoot at where someone actually is at any time. The downside to reducing the slider is that it may make character movements more jerky in the game. This depends on a range of factors, including the quality and latency of your own connection to the server, and those of the other players. Start by lowering the slider to the midway point. If after a period of gameplay on your favorite servers you don't notice any jerkiness in friendly or enemy movements, then lower it slightly again. If you do, raise it slightly until things are smooth.
Noen som har lekt seg med denne settingen under "Gameplay" og merket noe forskjell hvis du har god/dårlig link ?
Endret av Topguy
Noen andre som har opplevd at man ikke ikke får skifte hvilken harddisk battlefield installeres på?
Origin -> Settings -> General -> Downloaded Games
Velg partisjon og mappe.
Det gjelder meg og. Selv om jeg i Origin sine innstillinger peker installasjonsmappen til C: legges spillet inn på samme sted som det lå sist.
Så hvis jeg spiller på en server med bra linje/ping, samt at jeg ikke lagger....skal det være positivt for en med drittlinje som tar meg?
Har et rart fenomen.
Jeg og en kompis sitter å gamer sammen på hver vår laptop, vi er koblet opp til samme router trådløst.
Routeren er 5 meter unna og alltid med meget bra signal.
Allikevel får jeg hele tiden lagg uansett server. Altså jeg spurter avgårde og blir dratt tilbake 2-3 "meter" med jevne mellomrom.
Har dere noen tips ?
Nei ikke egentlig ... har et Intel Advanced Centrino 6230 kort. Kan google litt etterpå å se om det er flere med dette kortet som sliter.
Grafikken skal det egentlig ikke være noe problemer med. Har HD6990M som er et relativt bra kort. Har stabil FPS.
Får se litt når jeg kommer hjem hvordan det oppfører seg der.
Gjest Slettet+3165
Når en får 5 service stars på et våpen, får man 10000 poeng og Dog tag, eller 2000 poeng og Dog tag?
Bytter som regel våpen så fort jeg har unlocket alt, så har ikke passert 500 kills på noen enda :whistle:
