Noen her som tilfeldigvis har fått snust opp informasjon om det er mulig å firmware-oppgradere en 7250 til 7250i? Jeg krysser i hvert fall fingre og tær :)
En jeg snakket med hevdet at han hadde snakket med Nokia og at de hadde utelukket muligheten, på grunn av forskjeller i maskinvaren, men jeg vil da tro at nytt menysystem, redigeringsprogram og slikt som dette burde være mulig å flashe over...
Nokia kan da uansett ikke regne med at 7250-eiere kommer til å kjøpe seg en 7250i for å få de nye funksjonene? :roll:
De gjorde da det med 6310 ell ? Hva med 8910 og 9210 ?
Se her
Phone Features
Imaging
Take photos with the integrated camera and send them to friends and family1,14
Associate a picture to your contacts in the phone book
Advanced multimedia player
- Edit images with frames, clip art and text
- Adjust photo contrast and zoom in on images
- Show slide show
Use night mode when snapping photos in low light conditions
High-resolution color display: 128 x 128 pixels, up to 4,096 colors
Camera image capture at 352 x 288 resolution
Use photos as wallpaper to personalize your phone
Multimedia Messaging Service
Create, send and receive messages with image, sound and text1,14
Edit and forward received messages with image and text to compatible phones1,14
Received MMS images and MIDI ring tones can be saved in the Gallery menu†
Mobile Messaging
E-mail, text and picture messages1
Predictive text input
Connectivity
Mobile Internet1,2,12
High-speed data transmission via GPRS1,15
Wireless modem capability via USB cable or infrared
Send and receive data via infrared
Synchronize your phone book, calendar and to-do list with your PC using Nokia 7250i PC Suite4
TTY/TDD (Telecommunication Device for the Deaf) compatibility with phone adapter6
Hearing aid support with the LPS-4 Loopset
Downloadable Java™ Applications
Java™ support for application downloads
Preloaded Java applications: Converter, Triple Pop game and Bounce game
Organization
Phone book with up to 500 contacts, with multiple numbers and text entries per contact†
Calendar with monthly view
To-do list with priority levels
Alarm clock with snooze, stopwatch and countdown timer
Integrated speakerphone for convenient communication
Personalization & Fun
Use the Go-To menu to quickly access the features you use most
Xpress-on™ color covers, front and back
Use wallpaper templates or customize your wallpaper by loading an image onto your phone display
8 different color schemes to personalize display elements such as headers, battery strength and network indicators
Polyphonic (MIDI) ring tones
Stereo FM radio (headset required, stereo headset sold separately)
Specifications
Tri-band international phone‡
4-way scroll for easy navigation
Internal antenna and vibrating alert
Weight: 3.24 ounces
4.13 inches long x 1.73 inches wide x 0.75 inch thick
Service
GSM/GPRS 900/1800/1900 MHz
7250i Battery Life
Standard Li-Ion Battery 780 mAh
-- Digital Talk Time up to 5 hours*
-- Digital Standby Time up to 10 days*
