HTC Desire Bravo (2010) - Hva mer kan vi ønske oss?
Evju
Android 2.3 Update for HTC Desire kan nå lastes ned fra HTC Developer. Dessverre ingen OTA enda. Håper det kommer en ny oppdatering senere for vanlige brukere.
Note: This Rom update is for development only and not for general public use. Upgrades to non-authorized phones may result in loss of functionality. In addition certain functions may no longer be usable after re-flashing the ROM, including but not limited to MMS and SMS and HTC also disclaims liability for any unusable functions. HTC disclaims liability for the loss and/or leakage of any personal data resulting from the re-flashing of the ROM.
twb !
Det står også
Is this the official update for HTC Desire to Gingerbread?
Yes, this is the official update for HTC Desire to Gingerbread.
Will this release remove the ability to send SMS / MMS like in the disclaimer?
Only certain regions, specifically the ones listed below, will have some functionality removed. For the majority of regions, there is no impact to your SMS / MMS functionality.
Why is this only for developers?
Due to the complicated nature of the update we suggest only expert users proceed. We have provided the update in as user friendly way as possible and also included the instructions in the download file but we were unable to provide the update by our usual over the air method.
When can I download the upgrade for my phone?
You can still access the download at http://developer.htc.com for the upgrade for your phone, unless you are in the regions listed below.
Will HTC issue an over the air (FOTA) for HTC Desire update to Gingerbread?
No, this downloadable RUU is the official update to your phone. The update required that we conserve space by removing customizations and wallpapers, we had to release the update as a downloadable update.
Note:This ROM update is for development only and not for general public use. Upgrades to non-authorized phones may result in loss of functionality. In addition certain functions may no longer be usable after re-flashing the ROM if you are using an excluded variant (listed below), including but not limited to MMS and SMS and HTC also disclaims liability for any unusable functions. HTC disclaims liability for the loss and/or leakage of any personal data resulting from the re-flashing of the ROM.
Exclusions:The following regional variants are not-compatible with this upgrade: Germany (Telekom Deutschland), North America, South Korea, and Japan.
Endret av syar2003
twb !
Det står også
Er det noen som har lastet denne ned og prøvd den? Hadde vært kjekt å fått Gingerbread på telefonen :thumbup: :thumbup: ?
Har lagt den inn jeg.
Tilgjengelig intern lagringsplass (etter installasjon av kun 3G watchdog) er 126MB.
Så det blir enda mindre intern lagringsplass? Da er denne oppgraderingen uaktuell for min del tror jeg. Jeg sliter mer enn nok med de 147MB jeg har i dag, utrolig teit denne måten de har løst lagrings plassen på.
Tror nok jeg må roote og finne en måte å få mer lagrings plass på uten å knote alt for mye. Er drittlei å ha kun 15MB ledig, har ikke så mange apps inne. må slette noe hele tiden for å teste ut nye apps.
Har plutselig fått et problem med Desire'en min. Her en dag var alle apps på minnekortet "borte". Minnekortet virket til alt annet, men ikke apps. Hvis jeg prøver å installere en app på kortet/en app som automatisk legger seg på kortet, får jeg feilmeldingen "Feil ved installasjon. Kunne ikke installere på USB-lagring eller SD-kort."
Noen som har peiling på hvorfor det er slik? Har lastet ned noen av appene igjen og lagt dem på internminnet, men der er det jo i utgangspunktet fullt fra før... :-/
Kan noen hjelpe meg?!
Jeg tengte at jeg fikk ny sense for en eller anna grund.
Er det mulig å få nyere sense da?
Eneste måten å få nyere sense på er root + custom ROM, men hvis du har installert 2.3.3 oppdateringen fra HTC finnes det akkurat nå ingen måte å få root på. Det går heller ikke an å gå tilbake til stock 2.2.
Ja, det gjør den. Er en del på xda som har prøvd det meste for å få tilbake root, eller gå tilbake til 2.2. Hvis root er viktig for deg må du enten bruke custom roms basert på denne oppdateringen, eller vente og se om noen gidder å finne ut av hvordan man får root med ny HBOOT.
skjønner ikke dette.. om jeg vil installere gingerbread på telefonen min, må jeg laste ned innholdet på linken? og risikere hva?
Du skal bare ha gingerbread?
Da ville jeg ha ventet til oppdateringen kommer opp på telefonen din og installert på vanlig måte.
Er det virkelig vanskelig å lese 15 innlegg over her det quotede engelske fra HTC hvor det står med fet skrift.
Endret av syar2003
