[LØST] En firkant som roterer/ruller
Hei,
Driver å skal få en firkant til å rotere/rulle bortover i et JPanel. Får den til å flytte seg bortover, men ikke rulle.
Her er koden min:
import java.awt.*;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.geom.*;
import java.io.IOException;
import java.net.URL;
import java.util.Calendar;
import javax.imageio.ImageIO;
import javax.swing.*;
public class Firkant extends JFrame
private JPanel panel = new Panel();
public int T = 0;
public Firkant()
	super( "Firkant" );
	setSize(600, 600);
	setResizable( false );
	Timer t = new Timer(1, new ActionListener()
		  public void actionPerformed( ActionEvent e )
			  T += 1;
			  panel.repaint();
	t.start();
	Container c = getContentPane();
	c.setLayout( new FlowLayout() );
	c.add( panel );
class Panel extends JPanel
  public Panel()
		setPreferredSize(new Dimension(600, 600));
		setBackground(Color.DARK_GRAY);
  public void paint( Graphics g )
	  super.paintComponent(g);
	  Graphics2D g2 = (Graphics2D) g;
	  Rectangle2D rect;
	  g2.setColor( Color.white );
	  if( T < 250 )
		  rect = new Rectangle2D.Float(T, 50, 100, 50);
	  else if( T < 650 )
		  rect = new Rectangle2D.Float(250, (50 + T) - 250, 100, 50);
	  else
		  rect = new Rectangle2D.Float(250, 450 - (T - 650), 100, 50);
	  g2.draw( rect );
	  g2.drawLine(0, 100, 250, 100);
	  g2.drawLine(350, 100, 600, 100);
	  g2.drawLine(250, 100, 250, 400);
	  g2.drawLine(350, 100, 350, 400);
	  g2.drawLine(0, 100, 250, 400);
	  g2.drawLine(350, 400, 600, 100);
	  g2.drawLine(250, 500, 350, 500);
public static void main( String[] args )
	Firkant vindu = new Firkant();
	vindu.setVisible( true );
	vindu.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
Endret av Sir Zu Zwat
  • 3 uker senere...
