Random restarts i Win7, trenger hjelp til og lese dump-fila.
Lurer på om noen kan gjøre DMP-fila lesbar. Har prøvd Windbg, men den sier den magler det ene og det andre.
Hvis noen kunne hjulpet meg med dette så hadde det vært flott.
Legger med fila:
020610_15444_01.rar
Microsoft ® Windows Debugger Version 6.11.0001.404 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump20610-15444-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: D:\Symbols\Win7;D:\Symbols\Vista;D:\Symbols\XP;SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02a05000 PsLoadedModuleList = 0xfffff800`02c42e50
Debug session time: Sat Feb 6 16:45:25.329 2010 (GMT+1)
System Uptime: 0 days 0:00:10.360
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa80077238f8, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
0: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa80077238f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`035696f0 fffff800`02cbfa89 : fffffa80`077238d0 fffffa80`05523b60 00000000`0000000a 00000000`00000001 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`03569c10 fffff800`02ba1547 : fffffa80`077238d0 fffff800`02c1a5f8 fffffa80`05523b60 00000000`00000286 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`03569c40 fffff800`02b09b95 : fffff800`02c7c360 fffffa80`076b2fa8 fffffa80`076b2fa0 fffffa80`05523b60 : nt!WheapProcessWorkQueueItem+0x57
fffff880`03569c80 fffff800`02a84161 : fffff880`012fce00 fffff800`02b09b70 fffffa80`05523b60 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`03569cb0 fffff800`02d1a166 : 00000000`00000000 fffffa80`05523b60 00000000`00000080 fffffa80`05507040 : nt!ExpWorkerThread+0x111
fffff880`03569d40 fffff800`02a55486 : fffff880`0336a180 fffffa80`05523b60 fffff880`033750c0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`03569d80 00000000`00000000 : fffff880`0356a000 fffff880`03564000 fffff880`0307a540 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_MAE_PRV
LESBAR kanskje, men ikke helt klart hva problemet er ...
A "stop 0x124" is fundamentally different to many other types of bluescreens because it stems from a hardware complaint. Stop 0x124 minidumps contain very little practical information, and it is therefore necessary to approach the problem as a case of hardware in an unknown state of distress.
Denne er for deg:
Ensure that none of the hardware components are overclocked. :p
Endret av helsten2
alt er stock:)
Det som er rart er at det kan gå dager imellom, prøvd og skifte ut omtrent alt i pcen så jeg har en sterk minstanke om at det ligger i software\drivere\os.
Alt av stress-tester osv. går fint.
Men det kan vel også bety at hardware kan være feil innstilt slik som minne foreks?
Samme stop-feilen:
http://social.technet.microsoft.com/forums...6-445255560901/
Det glemte jeg: TUSEN TUSEN TAKK :thumbs:
Endret av Amanita Muscaria
