Tråden om Fallout: New Vegas. (Ingen OT og ingen piratsnakk.)
@raid2: Den linken.. Er det noen unmarked quest i spillet eller noe sånt?
Noen av de annonsene er referanser til quester, andre er nikk til tilfeldige, kanskje også merkelige og ulogiske ting man støter på. "Home for sale" f.eks, er en referanse til det huset stappfullt av feller og skorpioner, "Scientist wanted" er jo et nikk til Helios One-questen.
Hadde litt sweet REVAGE!!
Jeg prøvde å utrydde the fort når jeg var level 12-14 eller noe, gikk dårlig, nå kom jeg tilbake med boone or rex, samt sniper rifle og hunting revolver.
I left no one alive, jeg drepte også mr. hourse bare fordi jeg ikke likte hans planer for vegas og jeg drepte great kahns fordi jeg er sterkt anti drugs.
Mini-patchen for PC er nå ute via Steam:
______________________________________________________
- Companions now show up as waypoints on the map
- Companions will always fast travel with you, unless told to wait or sent away
- Crafting menu should filter valid (bright) recipes to the top of the list
- Fix: DLC error/save corruption
- Fix: Stuttering with water effects
- Fix: Severe performance issues with DirectX.
- Fix: Controls temporarily disabled after reloading Cowboy Repeater while crouched
- Fixed crash using the Euclid C-Finder while having the Heave Ho perk
- Fix: Entering the strip after Debt Collector causes crash and autosave corruption
- Fix: Using Mojave Express dropbox can cause DLC warnings
- Fixed crash when buying duplicate caravan cards from a vendor in a single transaction
- Fix: Sitting down while looking down a weapon's ironsights leaves player control locked
- Fix: If a companion is knocked uncon. with broken limbs they stay broken on respawn
- Fix for varmint night scope effect persisting in kill cam.
- Fix for giving companions armor that adds STR does not increase their carry weight
- Fix NPC Repair menu displays DAM as DPS
- Having NPC repair service rifle with forged receiver decreases CND.
As mentioned previously, we still have a comprehensive update coming for PC, 360, and PS3. As we have more details, we'll share them with you.
_______________________________________________________
En ny og en større oppdatering er også under sertifikasjon. 1-3 ukers tid. Vi konsoll eiere vil også få en fiks snart.
kom en ny bugg virker det som. våpena som "kameraten" din har med seg inn i kasinoer blir ikke frigitt ved å gå ut igjen.
bugg som ikke har blitt fiksa:
veronica (BOS) slutter å følge etter deg etter at hu prøver å snakke med deg etter at du har orna quest sammen med hu. er vell meninga hu skal takke deg eller noe. men du får bare den normale dialogboksen du kan bringe opp manuelt.
Fant en morsom ølreferanse i et bootleg bryggeri:
Dette refererer til Tactical Nuclear Penguin fra Brewdog, som er verdens mest alkoholholdige øl (32%).
"The End of History" med sine 55% holder rekorden for tiden. BrewDog-brygg det óg riktignok.
Men må si jeg humret litt selv da jeg så det i spillet :)
