Spotify invite /beg
Zatuke
Proxy måten å få gratis spotify på funker ikke. Så jeg lurte enkelt og greit på om noen hadde en invite jeg kunne få?
Jeg hadde en for lenge siden. Å etter å ha lett litt i inboksen fant jeg den til slutt. Men den fungerte ikke.
Så sa en venn av meg at jeg burde spørre på diskusjon.no. Og slik er det til at jeg er her og tigger etter en invite til spotify. Er det noen som kunne tenke seg å hjelpe meg?
hei og velbekomme:
Here is how you do it:
1. Go to this page.
2. Enter https://www.spotify.com/en/get-started/ inte the address field on the page you just entered and press “Go”. If any of those two don´t work for registering, Spotify has blocked them. In case they don´t work please contact us and we will add two new ones as soon as we can.
3. Now you should see the registration page for Spotify.
4. Fill out your details and use the postcode IP123BS (or any valid UK postcode).
5. Accept the user agreement and create the account.
6. Now you have an account, but your not done yet. Now open a new browser windows and go to Spotify.com. Go to “Edit Profile” which is found in the bottom menu. Enter your username and password and login.
7. Now change your country and postcode to your real ones. This part does not work for everyone. You should be fine even without it.
8. That was it. Now your good to good. Just download the software and you will have access to all the music you want.
This technique can be used over and over again as many times as you like. But don’t forget to change to your real country for all the accounts you create. This is very important because Spotify only alowes you to use your Spotify account abroad for 14 days. Any account exceeding 14 days abroad will be suspended.
hei og velbekomme:
1. Go to this page.
Ser du ikke hva TS sier? Proxymetoden funker faktisk ikke lenger.
Har også invites, send pm.
OPPFORDRING i samme svingen: Kjøp premium, det koster ikke mye i måneden (mye annet å sløse bort 100 spenn på), og du kan nyte reklamefri ubegrenset musikk, med offline-spillelister inkludert!
Endret av Venesis
