Piffe opp skrivebordet litt i Ubuntu
* Er det mulig å få conky til å ikke forsvinne når jeg trykker Ctrl+Alt+Del?
Denne derimot har jeg ikke funnet ut av....
Eneste jeg tenker på er å keybinde egendefinert kommando til ctrl+alt+del. med "pkill conky" forsvinner ihverfall conky :)
Les på nytt. :p
Han vil at conky ikke skal forsvinne når han trykker Ctrl+Alt+Del.
# UBUNTU-CONKY
# A comprehensive conky script, configured for use on
# Ubuntu / Debian Gnome, without the need for any external scripts.
# Based on conky-jc and the default .conkyrc.
# INCLUDES:
# - tail of /var/log/messages
# - netstat shows number of connections from your computer and application/PID making it. Kill spyware!
# -- Pengo
# Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_type override
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# fiddle with window
use_spacer right
# Use Xft?
use_xft yes
xftfont DejaVu Sans:size=8
xftalpha 0.8
text_buffer_size 2048
# Update interval in seconds
update_interval 3.0
# Minimum size of text area
# minimum_size 250 5
# Draw shades?
draw_shades no
# Text stuff
draw_outline no # amplifies text if yes
draw_borders no
uppercase no # set to yes if you want all text to be in uppercase
# Stippled borders?
stippled_borders 3
# border margins
border_margin 9
# border width
border_width 10
# Default colors and also border colors, grey90 == #e5e5e5
default_color grey
own_window_colour brown
# Text alignment, other possible values are commented
#alignment top_left
#alignment top_right
#alignment bottom_left
alignment bottom_right
# Gap between borders of screen and text
gap_x 10
gap_y 10
# stuff after 'TEXT' will be formatted on screen
TEXT
$color
${color orange}SYSTEM ${hr 2}$color
$nodename $sysname $kernel on $machine
${color}Uptime:$color $uptime ${color}
${color orange}CPU ${hr 2}$color
${freq}MHz Load: ${loadavg} Temp: ${acpitemp}
CPU0 ${cpu cpu1}% ${color lightgray}${cpubar cpu1}$color
CPU1 ${cpu cpu2}% ${color lightgray}${cpubar cpu2}$color
${cpugraph 000000 ffffff}
${color orange}MEMORY${hr 2}$color
RAM: $memperc% ${membar 6}$color
Swap: $swapperc% ${swapbar 6}$color
${color orange}DISK${hr 2}$color
Root: ${fs_free_perc /}% ${fs_bar 6 /}$color
MB1T: ${fs_free_perc /media/My Book 1TB}% ${fs_bar 6 /media/My Book 1TB}$color
MB1T: ${fs_free_perc /media/My Book}% ${fs_bar 6 /media/My Book 1TB}$color
MB2T: ${fs_free_perc /media/My Book 2TB}% ${fs_bar 6 /media/My Book 2TB}$color
Vel. her er min conky config. Forsvinner som nevnt ikke når jeg presser ctr-alt-d eller ctrl-alt-del
Startes manuelt ved at jeg bare skriver conky i terminalen når jeg slår på maskinen.
