Flere autocomplete felt på samme side
Prøver meg frem med autocomplete felter, de henter info fra en database, men jeg ønsker 2 felter som henter data uavhengig fra hverandre på samme side..
Prøvd å lage en ny tekstboks, og gitt den et unikt navn, så kopiert hele php scriptet og satt inn navnet på det nye feltet, men får det ikke til..
PHP script
<?php
// PHP5 Implementation - uses MySQLi.
// mysqli('localhost', 'yourUsername', 'yourPassword', 'yourDatabase');
$db = new mysqli('localhost', 'xx' ,'xxx', 'test');
if(!$db) {
	// Show error if we cannot connect.
	echo 'ERROR: Could not connect to the database.';
} else {
	// Is there a posted query string?
	if(isset($_POST['queryString'])) {
		$queryString = $db->real_escape_string($_POST['queryString']);
		// Is the string length greater than 0?
		if(strlen($queryString) >0) {
			// Run the query: We use LIKE '$queryString%'
			// The percentage sign is a wild-card, in my example of countries it works like this...
			// $queryString = 'Uni';
			// Returned data = 'United States, United Kindom';
			// YOU NEED TO ALTER THE QUERY TO MATCH YOUR DATABASE.
			// eg: SELECT yourColumnName FROM yourTable WHERE yourColumnName LIKE '$queryString%' LIMIT 10
			$query = $db->query("SELECT value FROM countries WHERE value LIKE '$queryString%' LIMIT 10");
			if($query) {
				// While there are results loop through them - fetching an Object (i like PHP5 btw!).
				while ($result = $query ->fetch_object()) {
					// Format the results, im using <li> for the list, you can change it.
					// The onClick function fills the textbox with the result.
					// YOU MUST CHANGE: $result->value to $result->your_colum
		 			echo '<li onClick="fill(\''.$result->value.'\');">'.$result->value.'</li>';
			} else {
				echo 'ERROR: There was a problem with the query.';
		} else {
			// Dont do anything.
		} // There is a queryString.
	} else {
		echo 'There should be no direct access to this script!';
HTML Søkefelt
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Ajax Auto Suggest</title>
<script type="text/javascript" src="jquery-1.2.1.pack.js"></script>
<script type="text/javascript">
function lookup(inputString) {
	if(inputString.length == 0) {
		// Hide the suggestion box.
		$('#suggestions').hide();
	} else {
		$.post("rpc.php", {queryString: ""+inputString+""}, function(data){
			if(data.length >0) {
				$('#suggestions').show();
				$('#autoSuggestionsList').html(data);
} // lookup
function fill(thisValue) {
	$('#inputString').val(thisValue);
	setTimeout("$('#suggestions').hide();", 200);
</script>
<style type="text/css">
body {
	font-family: Helvetica;
	font-size: 11px;
	color: #000;
h3 {
	margin: 0px;
	padding: 0px;
.suggestionsBox {
	position: relative;
	left: 30px;
	margin: 10px 0px 0px 0px;
	width: 200px;
	background-color: #212427;
	-moz-border-radius: 7px;
	-webkit-border-radius: 7px;
	border: 2px solid #000;
	color: #fff;
.suggestionList {
	margin: 0px;
	padding: 0px;
.suggestionList li {
	margin: 0px 0px 3px 0px;
	padding: 3px;
	cursor: pointer;
.suggestionList li:hover {
	background-color: #659CD8;
</style>
</head>
<body>
<div>
	<form>
		<div>
			<p>Land 1	<br />
			<input type="text" size="30" value="" id="inputString" onkeyup="lookup(this.value);" onblur="fill();" />
			</p>
	</div>
		<div class="suggestionsBox" id="suggestions" style="display: none;">
			<img src="upArrow.png" style="position: relative; top: -12px; left: 30px;" alt="upArrow" />
			<div class="suggestionList" id="autoSuggestionsList">
			</div>
		</div>
	</form>
</div>
</body>
</html>
Lagt til boks 2
<head>
	} else {
} // lookup
</script>
function lookup(inputString2) {
	if(inputString2.length == 0) {
	} else {
		$.post("rpc.php", {queryString: ""+inputString2+""}, function(data){
} // lookup
	$('#inputString2').val(thisValue);
</script>
body {
	font-size: 11px;
	color: #000;
h3 {
	margin: 0px;
	padding: 0px;
.suggestionsBox {
	position: relative;
	left: 30px;
	width: 200px;
	color: #fff;
.suggestionList {
	margin: 0px;
	padding: 0px;
	padding: 3px;
	cursor: pointer;
</style>
</head>
<body>
<div>
	<form>
		<div>
			<p>Land 1	<br />
			<p>Land 2	<br />
			<input type="text" size="30" value="" id="inputString2" onkeyup="lookup(this.value);" onblur="fill();" />
			</p>
	</div>
			</div>
		</div>
	</form>
</div>
</body>
</html>
Det virker slik at jeg får opp det jeg søker etter, men alt havner i den nye boksen, selv om jeg søker i den første så kommer forslagene i den nye..
