lilbossy Skrevet 19. januar 2004 Del Skrevet 19. januar 2004 Assitance with D20L problem It sounds like your PC can't communicate with the result server. If this is the only problem you have with internet, then you must think if there is any program installed on your PC that can prevent this from working, like a personal firewall etc. I have no other ideas Thank you! Takk! Will look into firewall. Was wondering if Router would be a problem too. Lenke til kommentar
GolfBag Skrevet 19. januar 2004 Del Skrevet 19. januar 2004 Yes it could... if the router has a firewall in it... Lenke til kommentar
OgnOmm Skrevet 19. januar 2004 Del Skrevet 19. januar 2004 Humm.. Fått en merkelig bug her.. alle mine tidsrelaterte verdier på en node er negative.. Avg Dock Time: -8 min, 0-56 sec Total Docking Time: -3 days, 0-2 hr, 0-13 min, 0-34 sec Avg Dock Time: -26.-828 sec Resten er bra.. Processed: 498 Osv.. Det har bedret seg litt.. var på -10min avg dock time for litt siden.. Noen som har vært borti dette før? Lenke til kommentar
Junta Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Assitance with D20L problem posted here. Hi lilbossy. Have you sorted out the problem? Lenke til kommentar
lilbossy Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Assitance with D20L problem posted here. http://www.d2ol.com/cgi-bin/ultimatebb.cgi...=3;t=000460;p=6 and in support section of forum. If you have any ideas on how to fix problem. Please let me know. It sounds like your PC can't communicate with the result server. If this is the only problem you have with internet, then you must think if there is any program installed on your PC that can prevent this from working, like a personal firewall etc. I have no other ideas I checked the firewall, could not find anything showing I blocked any D20L programs. Looking into router, to see if something on there is blocking it. Thanks/ Takk! Lenke til kommentar
Sorce Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 yess da var jeg også igang med å knekke pakker. får se om jeg ikke får opp flere noder i løpet av en uke. Lurer fortsatt på hvordan jeg kjører flere clienter samtidig.. har en p4 med HT støtte Lenke til kommentar
White_Tiger Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Da joina jeg også Lenke til kommentar
SvennR Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Da feirer jeg med boller og champagnebrus.!!!! Endelig er første plassen på TN min.. Så får vi se hvor lenge det varer, Shauge har sikkert en mengde pakker spart opp i nettopp denne anledning. Lenke til kommentar
[RCG]Balthazar Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Da feirer jeg med boller og champagnebrus.!!!! Endelig er første plassen på TN min.. Så får vi se hvor lenge det varer, Shauge har sikkert en mengde pakker spart opp i nettopp denne anledning. Gratulerer, godt kjempa! Hva har du for slags maskinpark stående? Jeg er ikke kommet lenger enn til 43'dje plass enda. Får se om jeg kan få i gang flere maskiner, akkurat nå er det 1x850AMD/512DDR/2k3Server 1xCeleron500/128SDR/WinXp 1xAMD 2600+/512DDR/WinXp 1xAMD 1900+/512SDR/WinXp 1xAMD M2500+/265DDR/WinXp (laptop, ikke ofte på nett) 1xAMD Duron 900/512/SDR/WinXp 1xAMD 2500+/512DDR/2k3Server 1xAMD 2200+/512DDR/WinXp Heh hvis bare alle kunne stått på hele døgnet Lenke til kommentar
SvennR Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Balthazar,20/01/2004 : 12:29]Da feirer jeg med boller og champagnebrus.!!!! Endelig er første plassen på TN min.. Så får vi se hvor lenge det varer, Shauge har sikkert en mengde pakker spart opp i nettopp denne anledning. Gratulerer, godt kjempa! Hva har du for slags maskinpark stående? Jeg er ikke kommet lenger enn til 43'dje plass enda. Får se om jeg kan få i gang flere maskiner, akkurat nå er det 1x850AMD/512DDR/2k3Server 1xCeleron500/128SDR/WinXp 1xAMD 2600+/512DDR/WinXp 1xAMD 1900+/512SDR/WinXp 1xAMD M2500+/265DDR/WinXp (laptop, ikke ofte på nett) 1xAMD Duron 900/512/SDR/WinXp 1xAMD 2500+/512DDR/2k3Server 1xAMD 2200+/512DDR/WinXp Heh hvis bare alle kunne stått på hele døgnet Jeg kjører: 1x Opteron 144@215Mhz bus 1x Athlon64 XP3200+@ 220Mhz bus 1x Dual Xeon 3,06Ghz@ 3,3Ghz 1x Dual Xeon 2,4Ghz 1x Dual AMD MP1800/XP2000 2x P4 2,26Ghz@ 2,8Ghz 1x Amd XP2800+ 1x P4 Celeron 2.2Ghz 1x P3 700Mhz. Da burde jeg vel ha fått med meg det meste. Lenke til kommentar
shauge Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Da feirer jeg med boller og champagnebrus.!!!! Endelig er første plassen på TN min.. Så får vi se hvor lenge det varer, Shauge har sikkert en mengde pakker spart opp i nettopp denne anledning. Gratulerer Pilgrim Har ikke noe å stille opp imot din produksjon. Det er bra å ha deg på laget vårt Nå gjelder det bare å stå på for å ta Hollenderene. Lenke til kommentar
shauge Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Da joina jeg også Supert Velkommen skal du være. Lenke til kommentar
shauge Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 yess da var jeg også igang med å knekke pakker. får se om jeg ikke får opp flere noder i løpet av en uke. Lurer fortsatt på hvordan jeg kjører flere clienter samtidig.. har en p4 med HT støtte Den enkleste måten er bare å installere programmet en gang til i en annen folder og starte D2OL.EXE i begge folderene. Du får da 2 noder på samme maskin. Hvis du kopierer node.prp fra den ene til den andre folderen så vil nodene jobbe mot samme nodenummer i statistikken. Det er greit å gjøre det når en har en HT prosessor, men er ikke noe man trenger å gjøre Lenke til kommentar
trn100 Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Hmmm... Hadde et strømbrudd her om dagen og glemte å sjekke opp nodene igjen.... Tapte 2 plasser på det :-( Er imidlertid tilbake nå..... ;-) Lenke til kommentar
GolfBag Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 (endret) Uff, jeg må kanskje vurdere å oppdatere signaturen min litt... taste, taste, taste enda litt mer... sånn... nå er det gjort. Edit: dumme regler "!"#¤%!"#¤ ikke lov med så lang signatur... måtte fjerne link til D2OL "#¤%@£$€£$!"#¤!! Endret 20. januar 2004 av GolfBag Lenke til kommentar
Sorce Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 yehaa då va eg igang for fult.. med 100% load har mer på vei.. foreløpig 150pakker done Lenke til kommentar
robgar Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Jeg får fortsatt ikke opp nodene. en annen sak, er det kommet inn engelske på laget vårt?, da burde vi skrive litt mer på engelsk i allefall. Lenke til kommentar
jonnor Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 (endret) Er alle her enige at vi burde la folk fra utlandet (de som ikke bor i Norge) være medlemmer av laget? Er det grunnleggeren av laget som har skrevet den "invitasjonen" på D2OL forumet? Ikke flame meg for mye for dette a, jeg stilte jo bare 2 spørsmål... Endret 20. januar 2004 av NorthWave Lenke til kommentar
trn100 Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 (endret) "grunnleggeren" av laget er så vidt jeg vet ikke med lenger... Skal forsøke å unngå "flaming" siden du spurte pent, men til din orientering er faktisk ikke det viktigste at Norge vinner denne gangen... Det er liksom snakk om at vi alle kan bidra med noe positivt uten å tre våre egne nisseluer over ørene, uansett hvor kledelige de måtte være for noen av oss.... Er det andre som føler at "folk som ikke bor i Norge" ikke har noe i TN å gjøre flytter jeg også.... a.... Edit: La til "a" fordi det hørtes litt smart ut... I allefall ikke det dummeste jeg har hørt... På lenge... Endret 20. januar 2004 av trn100 Lenke til kommentar
[RCG]Balthazar Skrevet 20. januar 2004 Del Skrevet 20. januar 2004 Heh hva er vigtigst... 1.Finne medisiner? 2.Sette Norge på nok et verdenskart. 3.Ha det kult med stats og konkurranseinnstinkt. Bare mine tre små meniger. Ønsker forøvrig at alle som vil være med på laget kan være velkommne hvor enn dem kommer fra. Lenke til kommentar
