RudolfVanHal Skrevet 28. januar 2010 Del Skrevet 28. januar 2010 Så jeg tenkte jeg skulle kjøpe meg et par nye monitorer til musikkprodusering, så jeg lurer egentlig på om jeg skal gå for M-audio audiophile 2496 eller Audiophile 192 spørsmålet er da om det er noe vits å gå for den litt dyrere, i og med at høytalerne ikke er så heftig i seg selv? Som M1 Active 520 men med 100W og 6” baselement.The M1 Active 620 is the third generation of the acclaimed Alesis M1 Active Series. The M1 Active 620 offers incredible bass and midrange definition and flat frequency response from its high–precision driver and professionally–crafted crossover. With a bold new look, redesigned driver, bass density control and EQ, this affordable, high–precision active reference monitor delivers superb sonic clarity. 6.5" low frequency woofer for clear bass and midrange 1" silk dome tweeter for smooth, detailed highs without harshness Bi-amplified design / tweeter –30W, woofer –65W for ultra accurate frequency separation High-precision drivers offer lower distortion and smoother frequency response Acoustical waveguide for superior imaging with minimal diffraction 1" thick front baffle virtually eliminates speaker resonance Magnetically shielded for close placement to video monitors in computer-based music production studios XLR and 1/4" TRS input connectors with volume control Low frequency density switch for acoustic space adjustment of the monitors Rear port design provides deep bass extension and increased SPL Hi, mid and low frequency EQ switches to accommodate user preference and sub-woofers Top mounted, integrated power switch/clip light bar Bi-amplified Design / Tweeter – 30W, woofer – 65W Woofer. 6 1/4” lightweight, magnetically-shielded, ultra-stiff polypropylene cone with rubber surround and high power handling voice coil. Tweeter. 1” silk dome with magnetic shielding Frequency Response. 49 Hz – 20 kHz Crossover Frequency. 2.8 kHz. Signal-to-Noise Ratio. >100 dB below full output, unweighted. Inputs. XLR and 1/4” supporting both balanced and unbalanced cabling. Polarity. Positive signal on “+” pin creates forward cone displacement. Input Impedance. 20k ohms balanced or 10k ohms unbalanced. Input Sensitivity. 85 mV noise (pink) produces 90 dB(A) output SPL at 1 meter. Gain knob turned fully clockwise (maximum). Dimensions (W x H x D). 8.5” x 15.0” x 10.25” / 21.6 cm x 38.0 cm x 26.0cm. Net Weight (each speaker). 21 lbs / 9.6 kg. Lenke til kommentar https://www.diskusjon.no/topic/1198073-valg-av-studiomonitorer-og-lydkort/
Slettmeg01 Skrevet 29. januar 2010 Del Skrevet 29. januar 2010 Når det gjelder lydkort, så er det ofte antall inn- og utganger du bør se etter i første omgang. Hvis du kun skal ha lydkortet til å gi lyd til 2 monitorer, så funker de fleste lydkort som er litt bedre enn standard! Hvilke monitorer er det du har tittet på? Lenke til kommentar https://www.diskusjon.no/topic/1198073-valg-av-studiomonitorer-og-lydkort/#findComment-15121374
RudolfVanHal Skrevet 29. januar 2010 Forfatter Del Skrevet 29. januar 2010 (endret) Hvilke monitorer er det du har tittet på? Tusen takk for svar. http://www.alesis.com/m1active620 har jeg sett på men bør jeg da gå for 2496? Følger med kabel, og eventuelt noe for å kontrollere volumet på disse? Kobler også opp en Virus TI, men denne skal jeg mest sansynelig selge, så det er usikkert. Men den kan jo uansett gå via usb. Eventuelt kunne jeg senere tenkt meg å koble på studio mic´s og kanskje en mikrofon for å spille inn noen lyd.. går dette? har også sett på: Fire Solo men en ting som er viktig, er at ustyret ikke har noe problemer med å kjøring i cubase, og jeg vil ikke ha noe lag eller lyd problemer! Endret 29. januar 2010 av RudolfVanHal Lenke til kommentar https://www.diskusjon.no/topic/1198073-valg-av-studiomonitorer-og-lydkort/#findComment-15121455
kragh Skrevet 30. januar 2010 Del Skrevet 30. januar 2010 Jeg kan av erfaring anbefale Echo Audiofire serien av lydkort. Selv har jeg brukt et Audiofire 4 lydkort etter anbefaling av en venn i flere år nå, det fungerer strålende! Lenke til kommentar https://www.diskusjon.no/topic/1198073-valg-av-studiomonitorer-og-lydkort/#findComment-15126260
