kabel fra pc til Logitech Z5500
  • 3 uker senere...
Toslink-standarden sier vel 5m 10m, (finnes myriader av 5m toslink der ute).
Men signaltapet er så lavt i glassfiber/akryl, så det er nok ingen problemer å bruke en 10m kabel (mener å huske at andre på forumet har rapportert problemer over 25m)
Wiki:
TOSLINK may use inexpensive 1 mm plastic optical fiber, or it can use higher quality multistrand plastic optical fibers or even quartz glass optical fibers, depending on the desired bandwidth and application. TOSLINK cables are usually limited to 5 meters in length, with a technical maximum[1] of 10 meters, for reliable transmission without the use of a signal booster. However, it is very common for interfaces on newer consumer electronics (satellite receivers and PCs with optical outputs) to easily run over 30 meters on even low-cost ($0.25/ft) TOSLINK cables.
Endret av Flimzes
