[Løst]Trenger hjelp med en struct- oppgave
Garanterer ikke at den er bug-fri, men tror det virker rimelig greit.
(Uten at jeg har testet noe særlig, men likevel...)
Den skal ihvertfall være svært enkel å forstå :)
#include <stdio.h>
struct Length
    int m;
    int cm;
    int mm;
//    Global variable. Creates three of the struct, as defined in the task.
struct Length LengthArray[2];
void add_length(struct Length *AddedLength)
    int i = 0;
    AddedLength->m = 0;
    AddedLength->cm = 0;
    AddedLength->mm = 0;
    for (i = 0; i < 3; i++)
        AddedLength->cm += LengthArray[i].cm;
        AddedLength->mm += LengthArray[i].mm;
        AddedLength->m += LengthArray[i].m;
        if (AddedLength->mm > 10)
            int Rem = (AddedLength->mm % 10);
            AddedLength->cm += (AddedLength->mm / 10);
            AddedLength->mm = Rem;
        if (AddedLength->cm > 100)
            int Rem = (AddedLength->cm % 100);
            AddedLength->m += (AddedLength->cm / 100);
            AddedLength->cm = Rem;
int main()
    int i = 0;
    struct Length AddedLength;
    printf("%s", "Please enter the your values.\r\n");
    //    Fills the three variables with (user generated) content, as the task specifies.
        printf("%s%i%s", "Struct #", i, "\r\nM:  ");
        scanf("%i", &LengthArray[i].m);
        printf("%s", "CM: ");
        scanf("%i", &LengthArray[i].cm);
        printf("%s", "MM: ");
        scanf("%i", &LengthArray[i].mm);
    add_length(&AddedLength);
    printf("%s%i%s%i%s%i%s", "Result: ", AddedLength.m, "m, ", AddedLength.cm, "cm, ", AddedLength.m, "mm\r\n");
    printf("%s%i%c%c%i%i", "Float: ", AddedLength.m, 0x2E, ((AddedLength.cm < 10) ? (0x30) : (0x00)), AddedLength.cm, AddedLength.mm);
Endret av ze5400
Det var lettere ja. :)
Hva betyr alle disse: "AddedLength->m = 0;" Altså "->".
Denne må du forklare litt: "struct Length LengthArray[2];" Kopierer du den den første på en måte?
" printf("%s%i%c%c%i%i", "Float: ", AddedLength.m, 0x2E, ((AddedLength.cm < 10) ? (0x30) : (0x00)), AddedLength.cm, AddedLength.mm);"
Hvis det er noe jeg bør vite så skylder jeg på at jeg har sittet på pcen hele dagen nesten... :p
Endret av mx1000
Vi benytter en peker. Derfor.
Oppretter en array-instans av strukturen, med tre plasser inni. 0,1 og 2.
Hexadesimalske koder for forskjellige ascii-tegn. 0x2E = ".", 0x30 = "0", 0x00 = NUL.
Fordi vi har angitt at vi skal passe som 'char'.
Det er faktisk mye lurere å gjøre slik, istedenfor med char, som jeg gjorde, for min metode setter inn ett whitespace når det ikke skal noe, slik at det ikke er så sweet.
Uansett, nå har jeg oppdatert posten min lengre oppe på denne siden med en hvor litt bugs er fikset, b.la. den du nevner.
Håper du har fått svar på alt du lurte på :)
Og problemet var at det var glemt en "m" slik at det ble "m" istendenfor "mm", i den nest siste setningen.
printf("\n%s%i%s%i%s%i%s", "Result: ", AddedLength.m, "m, ", AddedLength.cm, "cm, ", AddedLength.mm, "mm\r\n");
Da anser jeg denne oppgaven som løst. Bare skrive en kort rapport og levere.
Takk for all hjelp her! :D
Endret av mx1000
