Niinja47 Skrevet 17. januar 2010 Rapporter Del Skrevet 17. januar 2010 ERROR: Denne nettsiden er ikke tilgjengelig. Det kan hende at nettsiden på linken min.. er midlertidig utilgjengelig eller flyttet permanent til en ny nettadresse. KODE: <?php include_once('config.php'); //define a maxim size for the uploaded songs in Kb define ("MAX_SIZE","10240"); //This function reads the extension of the file. It is used to determine if the file is an song by checking the extension. function getExtension($str) { $i = strrpos($str,"."); if (!$i) { return ""; } $l = strlen($str) - $i; $ext = substr($str,$i+1,$l); return $ext; } //This variable is used as a flag. The value is initialized with 0 (meaning no error found) //and it will be changed to 1 if an errro occures. //If the error occures the file will not be uploaded. $errors=0; //checks if the form has been submitted if(isset($_POST['Submit'])) { //reads the name of the file the user submitted for uploading $song=$_FILES['song']['name']; //if it is not empty if ($song) { //get the original name of the file from the clients machine $filename = stripslashes($_FILES['song']['name']); //get the extension of the file in a lower case format $extension = getExtension($filename); $extension = strtolower($extension); //if it is not a known extension, we will suppose it is an error and will not upload the file, //otherwise we will do more tests if (($extension != "mid") && ($extension != "midi") && ($extension != "mp3") && ($extension != "mp2") && ($extension != "wav") && ($extension != "wave") && ($extension != "wma")) { //print error message echo '<h1>Unknown extension! .mid, .midi, .mp3, .mp2, .wav, .wave and .wma are the supported extensions</h1>'; $errors=1; } else { //get the size of the song in bytes //$_FILES['song']['tmp_name'] is the temporary filename of the file //in which the uploaded file was stored on the server $size=filesize($_FILES['song']['tmp_name']); //compare the size with the maximum size we defined and print error if bigger if ($size > MAX_SIZE*1024) { echo '<h1>You have exceeded the size limit! The size limit is 10248 kb (10 MB)</h1>'; $errors=1; } //we will give an unique name, for example the time in unix time format $song_name=$_POST['songname'].'-'.$_POST['artist'].'.'.$extension; //the new name will be containing the full path where will be stored (songs folder) $newname="songs/".$song_name; //we verify if the song has been uploaded, and print error instead $copied = copy($_FILES['song']['tmp_name'], $newname); if (!$copied) { echo '<h1>Copy unsuccessfull!</h1>'; $errors=1; }}}} //If no errors registred, print the success message if(isset($_POST['Submit']) && !$errors) { echo "<h1>Song Suggested Successfully!</h1>"; $artistV = $_POST['artist']; $songnameV = $_POST['songname']; $yournameV = $_POST['yourname']; $youremailV = $_POST['youremail']; mysql_query("INSERT INTO `suggesters` (artistV, songnameV, yournameV, youremailV) VALUES('$artistV,', '$songnameV', '$yournameV', '$youremailV') ") or die(mysql_error()); } ?> Lenke til kommentar
Niinja47 Skrevet 17. januar 2010 Forfatter Rapporter Del Skrevet 17. januar 2010 Det virker bra med en liten fil på 300kb... Lenke til kommentar
TheRealL Skrevet 17. januar 2010 Rapporter Del Skrevet 17. januar 2010 Putt dette på toppen av scriptet: set_time_limit(0); Lenke til kommentar
Niinja47 Skrevet 17. januar 2010 Forfatter Rapporter Del Skrevet 17. januar 2010 Virket ikke :/ Hjelp meg please Lenke til kommentar
TeisL Skrevet 17. januar 2010 Rapporter Del Skrevet 17. januar 2010 Virket ikke :/ Hjelp meg please Nå har ikke jeg erfaring med dette selv, men hvor stor er filen du prøver å laste opp? Sjekk max størrelsen på upload i php.ini filen... Lenke til kommentar
Niinja47 Skrevet 17. januar 2010 Forfatter Rapporter Del Skrevet 17. januar 2010 Virket ikke :/ Hjelp meg please Nå har ikke jeg erfaring med dette selv, men hvor stor er filen du prøver å laste opp? Sjekk max størrelsen på upload i php.ini filen... ... PHPen sjekker selv for filstørrelse og advarer hvis det er for mye.. Jeg har satt max størrelse til 10MB og filene er forskjellig. Har prøvd med mye Lenke til kommentar
Niinja47 Skrevet 18. januar 2010 Forfatter Rapporter Del Skrevet 18. januar 2010 Har dere noen tips? Lenke til kommentar
Ernie Skrevet 18. januar 2010 Rapporter Del Skrevet 18. januar 2010 Hva er størrelsen på den minste filen du har prøvd som ikke har fungert? Hva er upload_max_filesize satt til i php.ini? Hvilken webserver er det du benytter, og godtar den så store filer som du forsøker å laste opp? Har du forsøkt med flere nettlesere? Hvis ikke kan det iallfall i teorien være et problem med nettleseren og ikke webserveren. Lenke til kommentar
