Hvor liberalistisk er forumet?
97 stemmer
  1. 1. Are taxes too high?
    • Yes
      48
    • No
      49
  2. 2. Is government spending too high?
    • Yes
      46
    • No
      51
  3. 3. Are we over-regulated?
    • Yes
      58
    • No
      39
  4. 4. Are you for free trade?
    • Yes
      61
    • No
      36
  5. 5. Should the minimum wage be abolished?
    • Yes
      20
    • No
      77
  6. 6. Should rent control be abolished?
    • Yes
      21
    • No
      76
  7. 7. Do we spend too much on Social Security?
    • Yes
      39
    • No
      58
  8. 8. Should we privatize the Post Office?
    • Yes
      35
    • No
      62
  9. 9. Would private schools be an improvement over government schools?
    • Yes
      41
    • No
      56
  10. 10. Should we relax immigration laws?
    • Yes
      28
    • No
      69
  11. 11. Should the government sell off more of the public lands?
    • Yes
      31
    • No
      66
  12. 12. Are worker safety regulations too strict?
    • Yes
      17
    • No
      80
  13. 13. Do you think we spend too much on anti-poverty programs?
    • Yes
      32
    • No
      65
  14. 14. Should marijuana be legalized?
    • Yes
      54
    • No
      43
  15. 15. Should all sex between consenting adults be legal -- even for money?
    • Yes
      66
    • No
      31
  16. 16. Do you believe in freedom of expression for books, newspapers, radio, television, the Internet, and so on, even for offensive and unpopular views and subject matters?
    • Yes
      95
    • No
      2
  17. 17. Should private clubs have sole authority to select their own members, even if they are discriminatory?
    • Yes
      72
    • No
      25
  18. 18. Are you against "førstegangstjeneste"?
    • Yes
      45
    • No
      52
  19. 19. Should taxes be cut by 50% or more?
    • Yes
      23
    • No
      74
  20. 20. Should government spending be cut by 50% or more?
    • Yes
      26
    • No
      71
  21. 21. Would you abolish at least half of existing government departments?
    • Yes
      28
    • No
      69
  22. 22. Should we abolish public schools and universities?
    • Yes
      10
    • No
      87
  23. 23. Should we privatize sanitation, fire, and other local services?
    • Yes
      15
    • No
      82
  24. 24. Should all drugs be legalized for adults?
    • Yes
      28
    • No
      69
  25. 25. Is bombing civilians in an enemy country morally equivalent to murder?
    • Yes
      56
    • No
      41
  26. 26. Should highways and roads be privatized?
    • Yes
      16
    • No
      81
  27. 27. Should gold and silver be legalized as means of payment?
    • Yes
      31
    • No
      66
  28. 28. Should police be privatized?
    • Yes
      2
    • No
      95
  29. 29. Should the courts be privatized?
    • Yes
      3
    • No
      94
  30. 30. Should the law itself be privatized?
    • Yes
      1
    • No
      96
  31. 31. Should the state be abolished?
    • Yes
      9
    • No
      88
  32. 32. What's your score in this test?
    • 0
      22
    • 1-5
      11
    • 6-15
      12
    • 16-30
      11
    • 31-50
      9
    • 51-90
      11
    • 91-130
      12
    • 131-159
      6
    • 160
      3
Men vil det ikke være etproblem at gale folk kan gå rundt i gatene og representere enorm fare, og så er det ingen som kan gjøre noe med det?
Dette er jo generelt et problem i DLFistan. Det blir ingen forbygging eller risikoreusernde tiltak på forhånd, fordi disse alle griper inn i eiendomsretten på en eller annen måte. Såklart vil den gale bli dømt til streng straff eller behandling etter at han har drept deg eller noen du er glad i. Men det er en liten trøst hvis du allerede er død.
Jeg fikk forresten 35 på testen:
"31-50 points: Your libertarian credentials are obvious. Doubtlessly you will become more extreme as time goes on"
Yeah right.
Hvordan forklarer du at i et land som USA, som er mye mer liberalistisk enn Norge, så er arbeidsledigheten større enn i Norge?
Finanskrisen.
Så du sier at før finanskrisen så var det lavere arbeidsledighet i USA enn i Norge?
Endret av Hans-o
Det foregås massiv juksing med tall for å få staten til å fremtre bedre og mer effektiv den er. Et eksempel er jo inflasjonen, som gjør at staten kan skjule offentlige utgifter.
Men tilbake til moralen. Et av de argumentene som sosialistene setter høyest er likhet – de vil at man ikke skal være avhengig av penger man har spart eller tjent for å få gode tilbud innen viktige område som helse, skole og eldreomsorg; de mener at alle har krav på de samme tilbudene innen disse viktige områdene uavhengig av hvor produktiv man er eller har vært. Derfor mener de at tilbud innen disse områdene må være offentlige, dvs. komme fra stat eller kommune, og gis mer eller mindre gratis til alle.
For å få til dette sørger staten for at stadig flere betaler mer og mer til det offentlige i form av skatter og avgifter, noe som har ført til at skattetrykket i Norge av de høyeste i verden.
Dagens system, velferdsstaten, fører til til dels kolossale forskjeller på viktige områder. Ingen burde bli overrasket over dette, de på venstresiden tar feil i praktisk talt alt de sier og gjør og påstår.
Liberalister er ikke tilhengere av likhet på noe området (bortsett fra likhet for loven), vi er for frihet. Frihet utløser skaperevne og virketrang, og kanaliserer slikt inn i nyttige former, og dette sørger for at velstanden stiger for alle. Det system som de eldre vil ha det best i er et system med størst mulig individuell frihet.
Etter å ha sett nok en sosialist ignorere oppfordringene om å sette seg inn i økonomi, skjønner man at deres uvitenhet ikke er uskyldig. Ignoransen deres er en løgnaktig unnskyldning for å utøve blind vold mot fredelige mennesker. Slike mennesker er ikke uskyldige. De er uvitende fordi de har valgt å være det. De er virkelighetens Jokere, onde til beinet.
Og i likhet med Jokeren sprer disse sosialistene død og elendighet hvor enn de går. De støtter dene ene diktatoren etter den andre. Først støttet de Lenin og Mussolini. Så viste Mussolini seg å være litt frynsete i kantene da han ble alliert med Hitler. Så støttet sosialistene Stalin, Mao og Pol Pot. Men så viste det seg altså at også disse var tvilsomme. Inntil nylig støttet de Mugabe og Chavez, men disse begynner også å vise seg fra en frynsete side. Fremdeles er Castro og Che Guevara på heltelista til mange sosialister.
Første gangen sosialister støtter en ond diktator kan det til nøds unnskyldes som en glipp. Tiende gangen er det nøyaktig like troverdig som Jokeren. Dette finnes det ingen unnskyldning for. Det finnes kun to typer sosialister: de naive og de onde, og det er en glidende overgang mellom dem ettersom de fleste onde sosialister bruker sin egen uvitenhet som unnskyldning til å leve ut sine voldsromantiske fantasier.
Er du en sosialist? Da kan du bevise at du ikke er ond ved å lære deg litt økonomi og litt historie. Er du ærlig forlater du sosialismen og blir sint og kvalm over at du har latt deg lure av en så gjennomsyret ondskapsfull ideologi. Er du derimot grunnleggende ond vil du gjøre som så mange millioner sosialister før deg: du vil vifte bort denne oppfordringen som tull og tøys som du trygt kan ignorere ettersom det er sagt av en ”fæl liberalist.” Gjør du det er du en Joker og fortjener å stå til rette for all ondskap du sprer i verden.
Endret av Marxisten
Jeg tror ikke på at noen mennesker er grunnleggende ond.
Ok hva med trond mohn? Han er milliarder, rikeste mannen på vestlandet, og han betaler skatt med glede, han sponser fotballbaner og idrettsarenaer over hele vestlandet og betaler annonser for arbeiderpartiet i bergensavisen. Er han ond?
Det er ikke ondt å betale skatt, men det er ondt å rane andre.
Det er ikke propaganda, men fakta. Stoltenberg går i pen dress, han snakker pent og har ingen murstein i hånden, men under dette siviliserte ytre skjuler det seg en like primitiv voldsape som den verste Blitzer, Black Panther, Sea Shepherd, Svartskjorte eller Brunskjorte. Alle skal med, og nåde den som forsøker å slippe unna.
