Hjemmeautomasjon - Hva er det og hvorfor skulle jeg bry meg? (Automasjonskaféen)
Apropos Telldus.
Jeg hadde en morsom runde med dem i fjor:
2012-01-27 - 09:18
Hi
I am looking to buy a large number of your Tellstick NET product but will need a copy of the Declaration of Conformity for the CE certification as I can not find this in the Userguide.
Please olso send a copy of the Radio Test Report based on EN300 220.
Thanks
Mange hilsener fra
<<Navn og kontakt info her>>
2012-02-16 - 14:00
Hello?
Have you received this ?
G
Telldus answers: 2012-02-27 - 14:55
Hi,
I'm so sorry I've missed your support ticket.
The problem with our products lately is that the demand has been alot higer than the availability. We're receiving orders for all pcs of the incomming orders before we even receive the goods.
Because of this situation, we're not able to send samples or orders to any new retailers right now. I hope you can understand this situation. We're working hard on solving this, and we hope to have a good stock situation after the summer.
Best Regards
Fredrik Jacobsson
Telldus Technologies
2012-02-27 - 15:03
You missunderstand.
I just need the documentation of the CE certification at this point, so we can make the dessision of what product to go for.
The order will come later but I need the documantation now to save time.
Just please mail me a copy of the CE certification and a copy of the Radio test report.
Thanks
G
Telldus answers: 2012-02-27 - 15:08
Since we're about to move our production to a new factory, we will need do new CE tests and certifications. I will send the new documents to you as soon as they are finished.
Regards,
Fredrik
2012-02-27 - 15:27
Oh but that’s not a problem.
As long as you can document that you are certified now we totally rely that this will be updated in time for the order. Just send me the old one that will do fine, for now.
Telldus answers: 2012-02-28 - 09:44
We will do some modifications to the hardware as well, that means that the old certifications will not be valid.
2012-02-28 - 09:53
Ok
No more beating around the bush:
You are not certified at present time are you?
According to requirement of the CE process your user guide should contain a DoC (Declaration of Conformity) for RF transmitters, but it is not there. Even if the product is marked with CE?
When do you expect to be certified?
Har ikke hørt noe fra dem siden :)
Jeg synes det er litt dårlig gjort å sette CE merket på en vare uten å gjøre (den dyre) sertifiseringen :(
De fra Viking, snakker vel kun med seg selv og RFXtrx433 ?
Det jeg lurte litt på, er at det virker som om alle sammen bruker 433Mhz. Vil det da si at uansett hva jeg kjøper så kan jeg finne giverne igjen med homeseer og RFXtrx433 hvis jeg ryke på det senere ?
Alt fra Teldus snakker vel også Viking, iallfall Tellstick.Net. Men 433 mHz er bare frekvensen, det må også finnes en riktig protokoll. Jeg vet ikke med de to ulike typene av Oregon, men den jeg kjøpte, har iallfall en kjent protokoll. Og på RFXtrx-nettsiden står det to ulike protokoller for Oregon som er støttet, så jeg tipper at det er de to typene du snakker om.
Snedig! Fin graf over temperaturer, og jeg liker det at jeg kan sette et temperaturvarsel, så har jeg en reserve på temperaturvarselet som allerede er på hytta, og i fryseren. :) Takk for tipset!
Bare hyggelig. :)
Hvilken giver bruker du i fryseren?
En Viking (Suprise, surprise...) innepakket i et par fryseposer. Ingen problemer med signalet, selv om fryseren står i kjelleren og RFXtrx-en står på loftet, med en Lecavegg signalet må gå gjennom.
Ikke så veldig overrasket, har et par "Vikinger" selv på hytta, tross alle spådommer fungerer de 100%.
På skrå igjennom 2 lecavegger og noe lettvegger, ca 10m til TelldusNet.
Disse var nye nå til påske så det er litt tidlig å sprette champisen, men det tegner bra.
Kan være det er kommet en forbedret batch.
Hei igjen :)
Spørsmål vedrørende letteste og mest stabile måte å annonsere en event(alarm) fra homeseer til en mobil(innbrud og lignende)
på.
Hva har folket hvert borti?
1.Mail = Denne blir bare en av mange i mengeden, så det virker nok ikke så bra.
2. Oppringning:Noen som har teste dette? evt med hvilken ekstra modul?
3. Sms: Fins det noen online tjenester eller må man bare bruke en GSM modul?
4. Twitter: Kan man stenge for at andre skal følge deg?(så de ikke ser dine notifkasjoner fra homeseer)?
5. Skype:
6. Growl: Hvordan virker denne??
Takker for svar og tilbakemeldinger
Hilsen Anton
Arneolav, har egentlig aldri hørt noe negativt om Viking fra noen som selv har brukt dem. Jeg kjøpte mine første da jeg kjøpte RFXtrx-en, jeg tror det var i fjor vår. Aldri hatt problemer med noen av dem, bare med andre typer sensorer.
Cossiest, hva med SMS som varsling av mail? Hvis du er på en seriøs mobiloperatør, bør de ha en varslingsmulighet for mail med SMS, og iallfall der jeg er kan man sette til at bare en viss type mail skal varsles (sånn at jeg slipper 3000 varslinger om oppdateringer av denne tråden, for eksempel...). Så har du bare et lett gjenkjennelig tema, som ofte er det som vises. Jeg har "Hyttealarm - brann", "Hyttealarm - bevegelsesdetektor 1" og så videre. Funker ypperlig.
5. Skype:
1. Ja. Blir fort en av mengden.
2. Har ikke testet oppringing. Jeg mener det er en utdøende teknologi...
3. Begge deler er mulig. Telenor har som nevnt et ypperlig URL-basert API.
4. Ja, du kan stenge at andre skal følge deg. Men Twitter er ikke "instant", det kan ta litt tid. Litt kjipt hvis du f.eks. har tenkt å få beskjed om noen ringer på døra.
5. Har ikke testet, men det burde jo fungere.
6. Du installerer en app på telefonen din og/eller på alle PCer/Mac'er du har. Så pusher HomeSeer ut beskjeder når noe skjer. Genialt! Den mest brukte notifikasjonsmetoden her i huset. Bruker Toasty på Windows Phone og Notify My Android på Android...
Hordan fungerer dette, egentlig? Sender du eposten "gjennom" operatøren?
(Høres jo ut som et overskudd som ble brukt før Push email ble utbredt, men om det fungerer så er det jo utmerket!)
Nei, jeg mottar bare mailen til min vanlige mailkonto (@online.no) og så sender den automatisk ut de første linjene av mailen som SMS. Det har de gjort i nærmere ti år, vil jeg tippe. Iallfall godt over fem. Alle som har mobil i Telenor kan få det. Netcom hadde en lignende løsning, men den fikk etter hvert en pris, så den er mindre gunstig.
Alt annet, Growl, push mail og sånt, er vel avhengig av at man er på mobilt bredbånd? Saken er at jeg nesten aldri bruker 3G-nettverk. Jeg har det enkleste, vanlige abonnementet som fins (fordi det ellers blir for mange kontantkort på Fri familie), og operatøren ble nærmest sjokkert da jeg kjøpte en Note II og sa at jeg ikke trengte noen pakke med data i det hele tatt! ;) Jeg har hjemmekontor og er innenfor et wifi-nettverk hjemme eller på hytta 95 % av tiden der det kan komme viktig jobbmail, og de få gangene jeg får en som er viktig når jeg er ute, koster det ikke mange ørene å hente ned temaet på alle som er kommet og så ta hele den ene med K9 mail på Noten.
Ser ikke den muligheten med min moskus-adresse, men det var en av de gamle gratis-adressene på ca midten av 90-tallet så det kan vel muligens forklare det.
Growl, Push Email, etc krever nettilgang, ja. Men kostnaden ved å sende en Growl-melding er vesentlig mindre enn det koster å sende en SMS.
Jeg knapt tenke meg å ha en abonnement uten fast datamengde. Brukes jo til alt, mobil, padde og laptop. Alltid på nett!;)
Hvor stort tverrsnitt er det snakk om? Du finner en del vanntette koblinger/overganger beregnet til MC, så MC-utstyrs/m,oddebutikker kan være verdt en kikk.
Ikke så all verdens, tenker jeg 0.75mm^2 eller tilsvarende. Takk for tipset, skal se hva jeg finner.
Biltema har noen krympestrømper som jeg bruker.
Krymper dem med en ligther..
De er greie, men de er dessverre ikke helt vanntette. Min metode er sånn: tre krympestrømper utenpå hverandre, og så surring av vulkteip rundt strømpene og godt ut på sidene. Det har aldri slått feil.
Har krympestrømper, så jeg peiser på med det.
Vulkaniserende teip er et fint tillegg! :)
