Onboard SoundCard (RH 8)
hey,
i've just put redhat 8 on my new pc and im having difficulty setting up the onboard sound.
ive installed the nforce package, and the onboard ethernet works fine, but the onboard sound is proving a little more illusive.
The redhat soundcard detection recognizes that the device is nvidia, but with unknowns, and fails to test.
The detail is sketchy at the moment, i'll try to find out more and update the question.
but in the meantime, any advise would be great.
try using alsa... many new mb has onboard sound that's not supported by kernel. Like mine Asus a7v8x (can't remeber the name of the sound chip)
was not supported by 2.4.18 that rh8 uses (many other mb manufatures uses the same chip abit, msi osv...)
You can try using alsa http://www.alsa-project.org this fixed the problem for me (some crappy sound thought)
I wold recommend you to update your kernel to 2.4.20 or even better install rh9 instead.
