Tips: Få "God mode" i Win7 og Vista 32-bit / Er kontrollpanelet for lite og tungvindt?
Synes du kontrollpanelet er for tungvindt å finne? Er det for lite? Løsningen er nærmere enn du kanskje tror.
Obs! Dette fungerer ikke i Windows Vista 64-bit, men kan kræsje hele maskinen. Prøv det på eget ansvar.
Først den originale artikkelen:
Although its name suggests perhaps even grander capabilities, Windows enthusiasts are excited over the discovery of a hidden "GodMode" feature that lets users access all of the operating system's control panels from within a single folder.
By creating a new folder in Windows 7 and renaming it with a certain text string at the end, users are able to have a single place to do everything from changing the look of the mouse pointer to making a new hard-drive partition.
The trick is also said to work in Windows Vista, although some are warning that although it works fine in 32-bit versions of Vista, it can cause 64-bit versions of that operating system to crash.
To enter "GodMode," one need only create a new folder and then rename the folder to the following:
GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
Once that is done, the folder's icon will change to resemble a control panel and will contain dozens of control options. I'm not sure it's my idea of playing God, but it is a handy way to get to all kinds of controls.
Kort oppsummert kan du lage en ny mappe et sted (f.eks på skrivebordet) og kalle den
Mappen vil endre ikon til kontrollpanelet, og du vil få alle funksjonene der samlet i en enkelt mappe. Det er ikke nødvendig kalle den GodMode, så lenge du inkluderer alt fra punktum og bakover.
Dette er egentlig for Win7, men det fungerer (tilsynelatende) med Vista 32-bit også. Det er derimot svært ustabilt i Vista 64-bit, så prøv det på eget ansvar.
Endret av thecrow77
Flere Modes :
{ED7BA470-8E54-465E-825C-99712043E01C} Godmode
{00C6D95F-329C-409a-81D7-C46C66EA7F33} Location Sensor
{0142e4d0-fb7a-11dc-ba4a-000ffe7ab428} Biometric Device
{025A5937-A6BE-4686-A844-36FE4BEC8B6D} Power Options
{05d7b0f4-2121-4eff-bf6b-ed3f69b894d9} Taskbar Icons
{1206F5F1-0569-412C-8FEC-3204630DFB70} Credentials
{15eae92e-f17a-4431-9f28-805e482dafd4} Install from Network
{17cd9488-1228-4b2f-88ce-4298e93e0966} Default programs
{1D2680C9-0E2A-469d-B787-065558BC7D43} Public Keys
{1FA9085F-25A2-489B-85D4-86326EEDCD87} Wifi Networks
{208D2C60-3AEA-1069-A2D7-08002B30309D} Network
{20D04FE0-3AEA-1069-A2D8-08002B30309D} Computer (window)
{2227A280-3AEA-1069-A2DE-08002B30309D} Printers
{241D7C96-F8BF-4F85-B01F-E2B043341A4B} Workplace Connections
{4026492F-2F69-46B8-B9BF-5654FC07E423} Firewall
Måten det fungerer på er å huske å skrive "whatever.{xxxxxx}" , sørge for å kopiere dette med høyreklikk og så rename mappa med høyreklikk og trykke enter etterpå.
Whatever står selvsagt for det dere ønsker å kalle det mens xxx er nummerene som er oppgitt.
Endret av Malvado
