Qt Jambi og KDE integrasjon
Har litt problemer med at Qt Jambi ikke bruker KDE sitt tema, den defaulter bare til Plastique. Problemet er tydeligvis at Qt jambi må kompileres, problemet er bare at den stopper meg "make error 2" uten noe fornuftig feilmelding, kunne noen sett å se om de forsto noe mer?
Unable to locate tools.jar. Expected to find it in /usr/lib/jvm/java-6-openjdk/lib/tools.jar
Buildfile: build.xml
init.ant:
init.jumptable.do:
init.jumptable.dont:
init.taskdef:
init:
[qtjambi-initialize] qtjambi.osname: linux64
[qtjambi-initialize] qtjambi.libsubdir: lib
[qtjambi-initialize] qtjambi.qtdir: /usr/share/qt4
[qtjambi-initialize] qtjambi.compiler: gcc
[qtjambi-initialize] qtjambi.configuration: release
[qtjambi-initialize] qtjambi.phonon: false
[qtjambi-initialize] qtjambi.sqlite: true
[qtjambi-initialize] qtjambi.webkit: true
[qtjambi-initialize] qtjambi.xmlpatterns: true
[qtjambi-initialize] qtjambi.opengl: true
generator.xmlmerge.core:
generator.xmlmerge.gui:
generator.xmlmerge.network:
generator.xmlmerge.svg:
generator.xmlmerge.xml:
generator.xmlmerge.xmlpatterns:
generator.xmlmerge.opengl:
generator.xmlmerge.sql:
generator.xmlmerge.designer:
generator.xmlmerge.webkit:
generator.xmlmerge.phonon:
generator.xmlmerge:
generator.qmake:
generator.compile:
 [make]
 [make] Running : (/home/nordmoen/Nedlasting/qtjambi-src-lgpl-4.5.2_01/generator) make
 [make] make -f Makefile.Release
 [make] make[1]: Entering directory `/home/nordmoen/Nedlasting/qtjambi-src-lgpl-4.5.2_01/generator'
 [make] g++ -c -pipe -O2 -Wall -W -D_REENTRANT -DRXX_ALLOCATOR_INIT_0 -DQT_NO_DEBUG -DQT_XML_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtXml -I/usr/include/qt4 -I. -I. -I../common -Iparser -Iparser/rpp -Iparser/rpp -Irelease -o release/preprocessor.o parser/rpp/preprocessor.cpp
 [make] In file included from parser/rpp/pp.h:100,
 [make]				  from parser/rpp/preprocessor.cpp:54:
 [make] parser/rpp/pp-internal.h: In function ‘void rpp::_PP_internal::output_line(const std::string&, int, _OutputIterator)’:
 [make] parser/rpp/pp-internal.h:75: error: there are no arguments to ‘snprintf’ that depend on a template parameter, so a declaration of ‘snprintf’ must be available
 [make] parser/rpp/pp-internal.h:75: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
 [make] In file included from parser/rpp/pp.h:105,
 [make] parser/rpp/pp-macro-expander.h: In member function ‘_InputIterator rpp::pp_macro_expander::operator()(_InputIterator, _InputIterator, _OutputIterator)’:
 [make] parser/rpp/pp-macro-expander.h:264: error: there are no arguments to ‘snprintf’ that depend on a template parameter, so a declaration of ‘snprintf’ must be available
 [make] In file included from parser/rpp/pp.h:107,
 [make] parser/rpp/pp-engine-bits.h: In member function ‘void rpp::pp::file(const std::string&, _OutputIterator)’:
 [make] parser/rpp/pp-engine-bits.h:81: error: there are no arguments to ‘fopen’ that depend on a template parameter, so a declaration of ‘fopen’ must be available
 [make] parser/rpp/pp-engine-bits.h: In member function ‘void rpp::pp::file(FILE*, _OutputIterator)’:
 [make] parser/rpp/pp-engine-bits.h:111: error: there are no arguments to ‘feof’ that depend on a template parameter, so a declaration of ‘feof’ must be available
 [make] parser/rpp/pp-engine-bits.h:113: error: there are no arguments to ‘fread’ that depend on a template parameter, so a declaration of ‘fread’ must be available
 [make] parser/rpp/pp-engine-bits.h:117: error: there are no arguments to ‘fclose’ that depend on a template parameter, so a declaration of ‘fclose’ must be available
 [make] parser/rpp/pp-engine-bits.h: In member function ‘FILE* rpp::pp::find_include_file(const std::string&, std::string*, rpp::pp::INCLUDE_POLICY, bool) const’:
 [make] parser/rpp/pp-engine-bits.h:273: error: ‘fopen’ was not declared in this scope
 [make] parser/rpp/pp-engine-bits.h:286: error: ‘fopen’ was not declared in this scope
 [make] parser/rpp/pp-engine-bits.h:312: error: ‘fopen’ was not declared in this scope
 [make] make[1]: *** [release/preprocessor.o] Error 1
 [make] make: *** [release] Error 2
 [make] make[1]: Leaving directory `/home/nordmoen/Nedlasting/qtjambi-src-lgpl-4.5.2_01/generator'
BUILD FAILED
/home/nordmoen/Nedlasting/qtjambi-src-lgpl-4.5.2_01/build.xml:449: Running: make  failed with exit code: 2
Kan se ut som problemene som oppstår pga forskjeller i de nyere utgavene av gcc (tillater ikke lengre c-funksjonene uten å include eller noe). Husker ikke hvilken utgave forandringen kom i. Kan kanskje løses med -fpermissive flagget, men det er rart at dette ikke har vært patchet i Qt jambi.
Endret av oln
Fikk vite det samme av en venn, så jeg prøvde den siste Qt Jambi fra git og får nå en annen feil:
library.native.compile:
 [make]
 [make] Running : (/home/nordmoen/qt-jambi-4.5.2) make
 [make] cd qtjambi/ && make -f Makefile
 [make] make[1]: Entering directory `/home/nordmoen/qt-jambi-4.5.2/qtjambi'
 [make] make[1]: Nothing to be done for `first'.
 [make] make[1]: Leaving directory `/home/nordmoen/qt-jambi-4.5.2/qtjambi'
 [make] cd juic/ && make -f Makefile
 [make] make[1]: Entering directory `/home/nordmoen/qt-jambi-4.5.2/juic'
 [make] g++ -c -pipe -O2 -Wall -W -D_REENTRANT -DQT_UIC_JAVA_GENERATOR -DQT_UIC -DQT_NO_DEBUG -DQT_XML_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtXml -I/usr/include/qt4 -I. -I. -I. -o javawritedeclaration.o javawritedeclaration.cpp
 [make] In file included from javawritedeclaration.cpp:45:
 [make] javawritedeclaration.h:48:24: error: treewalker.h: No such file or directory
 [make] In file included from javawritedeclaration.cpp:46:
 [make] javawriteinitialization.h:49:20: error: option.h: No such file or directory
 [make] javawritedeclaration.cpp:47:20: error: driver.h: No such file or directory
 [make] javawritedeclaration.cpp:48:17: error: ui4.h: No such file or directory
 [make] javawritedeclaration.cpp:49:17: error: uic.h: No such file or directory
 [make] javawritedeclaration.cpp:50:26: error: databaseinfo.h: No such file or directory
 [make] javawritedeclaration.cpp:51:31: error: customwidgetsinfo.h: No such file or directory
 [make] javawritedeclaration.h:59: error: expected class-name before ‘{’ token
 [make] javawritedeclaration.h:62: error: ‘DomUI’ has not been declared
 [make] javawritedeclaration.h:63: error: ‘DomWidget’ has not been declared
 [make] javawritedeclaration.h:64: error: ‘DomLayout’ has not been declared
 [make] javawritedeclaration.h:65: error: ‘DomSpacer’ has not been declared
 [make] javawritedeclaration.h:66: error: ‘DomActionGroup’ has not been declared
 [make] javawritedeclaration.h:67: error: ‘DomAction’ has not been declared
 [make] javawriteinitialization.h:64: error: expected class-name before ‘{’ token
 [make] javawriteinitialization.h:70: error: ‘DomUI’ has not been declared
 [make] javawriteinitialization.h:71: error: ‘DomWidget’ has not been declared
 [make] javawriteinitialization.h:72: error: ‘DomLayout’ has not been declared
 [make] javawriteinitialization.h:73: error: ‘DomSpacer’ has not been declared
 [make] javawriteinitialization.h:74: error: ‘DomLayoutItem’ has not been declared
 [make] javawriteinitialization.h:79: error: ‘DomActionGroup’ has not been declared
 [make] javawriteinitialization.h:80: error: ‘DomAction’ has not been declared
 [make] javawriteinitialization.h:81: error: ‘DomActionRef’ has not been declared
 [make] javawriteinitialization.h:86: error: ‘DomTabStops’ has not been declared
 [make] javawriteinitialization.h:91: error: ‘DomCustomWidgets’ has not been declared
 [make] javawriteinitialization.h:92: error: ‘DomCustomWidget’ has not been declared
 [make] javawriteinitialization.h:97: error: ‘DomLayoutDefault’ has not been declared
 [make] javawriteinitialization.h:98: error: ‘DomLayoutFunction’ has not been declared
 [make] javawriteinitialization.h:103: error: ‘DomConnection’ has not been declared
 [make] javawriteinitialization.h:108: error: ‘DomImage’ has not been declared
 [make] javawriteinitialization.h:111: error: ‘DomColor’ has not been declared
 [make] javawriteinitialization.h:114: error: ‘DomProperty’ has not been declared
 [make] javawriteinitialization.h:116: error: ‘DomString’ has not been declared
 [make] javawriteinitialization.h:119: error: ‘DomProperty’ was not declared in this scope
 [make] javawriteinitialization.h:119: error: template argument 1 is invalid
 [make] javawriteinitialization.h:120: error: ‘DomColorGroup’ has not been declared
 [make] javawriteinitialization.h:126: error: ‘DomWidget’ has not been declared
 [make] javawriteinitialization.h:127: error: ‘DomWidget’ has not been declared
 [make] javawriteinitialization.h:128: error: ‘DomWidget’ has not been declared
 [make] javawriteinitialization.h:129: error: ‘DomWidget’ has not been declared
 [make] javawriteinitialization.h:130: error: ‘DomItem’ was not declared in this scope
 [make] javawriteinitialization.h:130: error: template argument 1 is invalid
 [make] javawriteinitialization.h:131: error: ‘DomWidget’ has not been declared
 [make] javawriteinitialization.h:133: error: ISO C++ forbids declaration of ‘DomWidget’ with no type
 [make] javawriteinitialization.h:133: error: expected ‘;’ before ‘*’ token
 [make] javawriteinitialization.h:134: error: ISO C++ forbids declaration of ‘DomImage’ with no type
 [make] javawriteinitialization.h:134: error: expected ‘;’ before ‘*’ token
 [make] javawriteinitialization.h:142: error: field ‘option’ has incomplete type
 [make] javawriteinitialization.h:153: error: ‘DomWidget’ was not declared in this scope
 [make] javawriteinitialization.h:153: error: template argument 1 is invalid
 [make] javawriteinitialization.h:154: error: ‘DomLayout’ was not declared in this scope
 [make] javawriteinitialization.h:154: error: template argument 1 is invalid
 [make] javawriteinitialization.h:155: error: ‘DomActionGroup’ was not declared in this scope
 [make] javawriteinitialization.h:155: error: template argument 1 is invalid
 [make] javawriteinitialization.h:159: error: ‘DomWidget’ was not declared in this scope
 [make] javawriteinitialization.h:159: error: template argument 2 is invalid
 [make] javawriteinitialization.h:160: error: ‘DomImage’ was not declared in this scope
 [make] javawriteinitialization.h:160: error: template argument 2 is invalid
 [make] javawriteinitialization.h:161: error: ‘DomAction’ was not declared in this scope
 [make] javawriteinitialization.h:161: error: template argument 2 is invalid
 [make] javawritedeclaration.cpp: In constructor ‘Java::WriteDeclaration::WriteDeclaration(Uic*)’:
 [make] javawritedeclaration.cpp:64: error: invalid use of incomplete type ‘struct Uic’
 [make] javawritedeclaration.h:52: error: forward declaration of ‘struct Uic’
 [make] javawritedeclaration.cpp: At global scope:
 [make] javawritedeclaration.cpp:69: error: variable or field ‘acceptUI’ declared void
 [make] javawritedeclaration.cpp:69: error: ‘DomUI’ was not declared in this scope
 [make] javawritedeclaration.cpp:69: error: ‘node’ was not declared in this scope
 [make] javawritedeclaration.cpp:182: error: expected ‘}’ at end of input
 [make] make[1]: *** [javawritedeclaration.o] Error 1
 [make] make: *** [sub-juic-make_default-ordered] Error 2
 [make] make[1]: Leaving directory `/home/nordmoen/qt-jambi-4.5.2/juic'
BUILD FAILED
/home/nordmoen/qt-jambi-4.5.2/build.xml:307: Running: make  failed with exit code: 2
