IF EXIST-problem i batch-fil
Denne koden putputer bare "<rename was unexpected at this time."
IF EXIST C:\OpenTTD-IS2-beta3 (
echo There's already a C:\OpenTTD-IS2-beta3 folder.
echo What do you want to do?
echo 1: Rename folder from OpenTTD-IS2-beta3 to OpenTTD-IS2-beta3_old
echo 2: Delete the folder.
echo 3: Do nothing and exit
set /p existing_folder=
if %existing_folder% ==1 (rename "C:\OpenTTD-IS2-beta3" "C:\OpenTTD-IS2-beta3_old" goto :continue_install)
if %existing_folder% ==2 (del "C:\OpenTTD-IS2-beta3" mkdir C:\OpenTTD-IS2-beta3 goto :continue_install)
if %existing_folder% ==3 (exit)
else (mkdir "C:\OpenTTD-IS2-beta3" goto :continue_install)
Noen idè om hva jeg har gjort feil her?
IF not EXIST C:\OpenTTD-IS2-beta3 goto noexist
if %existing_folder% ==1 rename "C:\OpenTTD-IS2-beta3" "C:\OpenTTD-IS2-beta3_old" | goto :continue_install
if %existing_folder% ==2 del "C:\OpenTTD-IS2-beta3" mkdir C:\OpenTTD-IS2-beta3 | goto :continue_install
if %existing_folder% ==3 exit
:noexist
mkdir "C:\OpenTTD-IS2-beta3" | goto :continue_install
:continue_install
Endret av aklla
