stilongz Skrevet 23. desember 2009 Del Skrevet 23. desember 2009 Får opp dette da jeg søker gjennom Minidumpen med WindBG etter at pc'n min fungerer en gang om dagen ca. Noen som kan hjelpe meg å forstå hva som er galt? BugCheck 7A, {c05cf7e0, c000000e, b9efc374, 9fe2d860} Probably caused by : SCSIPORT.SYS ( SCSIPORT!ScsiPortFdoPnp+516 ) Followup: MachineOwner --------- 1: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* KERNEL_DATA_INPAGE_ERROR (7a) The requested page of kernel data could not be read in. Typically caused by a bad block in the paging file or disk controller error. Also see KERNEL_STACK_INPAGE_ERROR. If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185, it means the disk subsystem has experienced a failure. If the error status is 0xC000009A, then it means the request failed because a filesystem failed to make forward progress. Arguments: Arg1: c05cf7e0, lock type that was held (value 1,2,3, or PTE address) Arg2: c000000e, error status (normally i/o status code) Arg3: b9efc374, current process (virtual address for lock type 3, or PTE) Arg4: 9fe2d860, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address) Debugging Details: ------------------ ERROR_CODE: (NTSTATUS) 0xc000000e - Det ble angitt en enhet som ikke finnes. DISK_HARDWARE_ERROR: There was error with disk hardware BUGCHECK_STR: 0x7a_c000000e CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: DRIVER_FAULT PROCESS_NAME: System TRAP_FRAME: ba503964 -- (.trap 0xffffffffba503964) ErrCode = 00000010 eax=87c2a450 ebx=8ac58af0 ecx=8ac58e14 edx=8ac58e10 esi=87c2a4f0 edi=8ac58e28 eip=b9efc374 esp=ba5039d8 ebp=ba503a18 iopl=0 nv up ei pl nz na po nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00210202 SCSIPORT!SpEnumerateAdapterAsynchronous: b9efc374 8bff mov edi,edi Resetting default scope LOCK_ADDRESS: 8055b4e0 -- (!locks 8055b4e0) Resource @ nt!PiEngineLock (0x8055b4e0) Available WARNING: SystemResourcesList->Flink chain invalid. Resource may be corrupted, or already deleted. WARNING: SystemResourcesList->Blink chain invalid. Resource may be corrupted, or already deleted. 1 total locks PNP_TRIAGE: Lock address : 0x8055b4e0 Thread Count : 0 Thread address: 0x00000000 Thread wait : 0x0 LAST_CONTROL_TRANSFER: from 80515b82 to 804f9f43 STACK_TEXT: ba503830 80515b82 0000007a c05cf7e0 c000000e nt!KeBugCheckEx+0x1b ba503860 805166ef 8297ccec c05cf7e0 b9efc374 nt!MiWaitForInPageComplete+0x1ca ba5038e0 80520249 c05cf7e0 b9efc374 c05cf7e0 nt!MiDispatchFault+0x2c1 ba50394c 80544588 00000008 b9efc374 00000000 nt!MmAccessFault+0x877 ba50394c b9efc374 00000008 b9efc374 00000000 nt!KiTrap0E+0xd0 ba5039d4 b9f03582 8ac58af0 8ac58e14 00000000 SCSIPORT!SpEnumerateAdapterAsynchronous ba503a18 b9ef4469 8ac58a38 87c2a438 8acb5530 SCSIPORT!ScsiPortFdoPnp+0x516 ba503a2c 804ef19f 8ac58a38 87c2a438 ba503aac SCSIPORT!ScsiPortGlobalDispatch+0x1d ba503a3c 80592b63 00000000 8ac91ca8 8ac91d88 nt!IopfCallDriver+0x31 ba503a68 804f6de7 8ac58a38 ba503a88 8ac91d88 nt!IopSynchronousCall+0xb7 ba503ab0 8058ee79 00000000 8ac94e50 00000001 nt!IopQueryDeviceRelations+0x45 ba503ac8 805922db 8ac91ca8 00000001 895138d0 nt!PipEnumerateDevice+0x23 ba503d20 8059271a 8ac91ca8 00000001 00000000 nt!PipProcessDevNodeTree+0x21b ba503d54 804f6981 00000003 8055b5c0 8056485c nt!PiProcessReenumeration+0x60 ba503d7c 8053877d 00000000 00000000 8acb0640 nt!PipDeviceActionWorker+0x14b ba503dac 805cff72 00000000 00000000 00000000 nt!ExpWorkerThread+0xef ba503ddc 805460ee 8053868e 00000001 00000000 nt!PspSystemThreadStartup+0x34 00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16 STACK_COMMAND: kb FOLLOWUP_IP: SCSIPORT!ScsiPortFdoPnp+516 b9f03582 b803010000 mov eax,103h SYMBOL_STACK_INDEX: 6 SYMBOL_NAME: SCSIPORT!ScsiPortFdoPnp+516 FOLLOWUP_NAME: MachineOwner MODULE_NAME: SCSIPORT IMAGE_NAME: SCSIPORT.SYS DEBUG_FLR_IMAGE_TIMESTAMP: 4802539d FAILURE_BUCKET_ID: 0x7a_c000000e_SCSIPORT!ScsiPortFdoPnp+516 BUCKET_ID: 0x7a_c000000e_SCSIPORT!ScsiPortFdoPnp+516 Followup: MachineOwner Lenke til kommentar
stilongz Skrevet 24. desember 2009 Forfatter Del Skrevet 24. desember 2009 (endret) Bump. Endret 27. desember 2009 av stilongz Lenke til kommentar
stilongz Skrevet 27. desember 2009 Forfatter Del Skrevet 27. desember 2009 Bump. Bump Lenke til kommentar
Tj-nome Skrevet 27. desember 2009 Del Skrevet 27. desember 2009 (endret) 1. Først kan du ta ein RAM test memtest86+ 2. sjekk diskene din for "bad sectors" Start>kjør skriv: cmd og trykk enter Dernest skriver du chkdsk c: \F \R (c: for disk c: osv.) Endret 27. desember 2009 av Tj-nome Lenke til kommentar
