xanim feilmelding
paranoid:/hdb/warez/warez/Filmer/Mad Max# xanim Madmax1.avi
XAnim Rev 2.80.0 by Mark Podlipec Copyright © 1991-1999. All Rights Reserved
comp 44495633 44495633 44495633
AVI Video Codec: Unknown DIV3(44495633) is unsupported by this executable.(E18)
AVI Audio Type Unsupported
AVI Notice: No supported Video frames found.
Usage:
XAnim [options] anim [ [options] anim ... ]
-h lists some common options, but may be out of date.
See xanim.readme or the man page for detailed help.
jeg får ikke spilt av filmer,
får en feil når jeg skal installere mplayeaahah
paranoid:/home/frankcc/# apt-get install mplayer-686
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
mplayer-686: Depends: libvorbis0 (>= 1.0rc3-1) but it is not installable
E: Sorry, broken packages
