sata to usb
har nå kjøpt en sånn duppedings til å hente ut dokumenter fra min gamle pc, men når jeg går inn på partisjonen, og på user, så kommer jeg ikke inn på den brukeren, er det fordi den er passordbeskyttet? hvordan kommer jeg meg forbi det? (den står på "private")
av en eller annen dum grunn sitter jeg nå på windows 7
kanskje noe av dette hjelper ?
http://www.sevenforums.com/tutorials/1911-...p-shortcut.html
http://www.vistax64.com/tutorials/67717-ta...rship-file.html
fant også linker til windows sine ofisielle support men de lastest ikke opp her på jobb for en eller annen grunn.
fant et utdrag fra den på et forum da :
For additional information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
307874 (http://support.microsoft.com/kb/307874/) How to disable simplified sharing and set permissions on a shared folder in Windows XP
1. Right-click the folder that you want to take ownership of, and then click Properties.
2. Click the Security tab, and then click OK on the Security message (if one appears).
3. Click Advanced, and then click the Owner tab.
4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of that folder, select the Replace owner on subcontainers and objects check box.
5. Click OK, and then click Yes when you receive the following message:
You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?
All permissions will be replaced if you press Yes.
Note folder name is the name of the folder that you want to take ownership of.
6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
