Den store Halo: Reach - tråden
Gjest Slettet+32asd4f
52 stemmer
  1. 1. Hvilke(n) utgave(r) skal du ha?
    • Standard
      34
    • Limited Edition
      9
    • Legendary Edition
      9
    • Xbox 360 250GB: Halo Reach Bundle
      7
Har ikke lest noe særlig om spillet, men håper virkelig de gjør noen "store" endringer med SPESIELT gameplayet, grafikken, settingen osv. Det er begrenset på hvor mange ganger bungie kan gi oss nesten identiske spill før det blir kjedlig. Ikke misforså jeg elsker halo spillene og historien og musikken, men denne gangen holder det ikke å legge til et par nye leketøy.
Gjest Slettet-T9cKWhDpN0
blir litt nervøs av å lese om endringene bungie gjør, men jeg regner med at de kommer til å få det til.
To uker til beta :D
Litt om Armor Abilities:
Sprint
Sprint is Spartan only and should be pretty self-explanatory. It gives you a quick burst of speed, but while youre at a dead run, you cant get all offensive. If you want to engage, you have to let off and regain your composure. Its weapons down during the duration of your marathon session.
Active Camouflage
Active Camo can be used by Spartans and Elites alike. It grants you temporary invisibility, but the effectiveness is hampered in two distinct ways. The faster you move, the more visible you become and the shorter the duration of the effect will be. If you want to make the most of it, stand still or move slowly.
Jetpack
The Jet Pack ability allows players to fly upwards and maneuver in mid-air while in combat. You can hold the button for an extended burst or feather it after a jump for just a little more height. If youre get too close to the sun, youll need to worry about the landing, so make sure you save some juice to soften the approach.
Evade
Evade lets you make a leap of faith in any direction. Its fast, its tricksy, and its something youll be getting a lot of mileage out of as an Elite. It will shed locks and tracking and makes for one nasty juke when youre in close quarters combat.
Armor Lock
Armor Lock gives you a burst of invulnerability. You can click once to briefly engage it, or hold it for a longer lasting effect, but either way, while youre in the throes you cant move a single, solitary inch. Youre rooted. But youll shed plasma grenades, shred vehicles unfortunate enough to attempt a splatter, and deflect projectiles.
Endret av Slettet+32asd4f
Sendte en mail til Gamezone på fredag og fikk dette svaret tilbake:
"Vi har foreløpig ikke fått bekreftet at Legendary Edition kommer til Norge
og Europa. Dersom den gjør det kommer vi definitivt til å ta den inn. Info
om dette vil komme på vår nettside, i vårt nyhetsbrev og på vår
facebook-side. Følg med, så skal du se at du sikrer deg et eksemplar dersom
vi får tak i! :)"
Du kan nå forhåndsbestille den hos play.com og amazon.co.uk, og begge to ligger nå i Europa, så det blir litt rart hvis den ikke kommer til Norge. Men vi blir nok nødt å vente i spenning.
dette blir nok det beste halo spillet. kommer sikkert til å vare veldig lenge på xbox live. håper bare campaignen også er lang. gjerne så lang at den er på en egen disk, men jeg tviler.
må se til å finne halo 3 legendary edition før reach kommer ut for å komme i fin stemning.
den kan godt vare i 100 timer, men det skjer jo aldri. 15-20 timer hadde vært fint, men så må den være bra slik at den kan spilles igjen og igjen og igjen.
