trenger hjelp angående skjermkort
superkaisa
hmm hjelper noe av dette:
Property Value
North Bridge Intel i915P/i915G Revision 0E
South Bridge Intel 82801FB (ICH6) Revision 0E
CPU Intel® Celeron® CPU 2.80GHz
Cpu Socket Socket 775 LGA
System Slots 2 PCI
Memory Summary
Maximum Capacity 4096 MBytes
Maximum Memory Module Size 1024 MBytes
Memory Slots 4
Error Correction None
Warning! Accuracy of DMI data cannot be guaranteed
eller:
Bus/Dev./Func. Type Class Type Manufacturer Device Name Sub System Device Vendor Sub System Device Name
00 / 00 / 00 PCI PCI to HOST Bridge Intel Corporation 82915G/GV/GL/P/PL/GL/910GE/GL Grantsdale Host Bridge/DRAM Controller AOpen Inc
00 / 02 / 00 PCI VGA Controller Intel Corporation 82915G/GV/GL, 82910GL Integrated Graphics Device AOpen Inc
00 / 27 / 00 PCI-X Hi-Definition Audio Intel Corporation 82801FB (ICH6) High Definition Audio Controller AOpen Inc
00 / 29 / 00 PCI USB (UHCI) Intel Corporation 82801FB (ICH6) USB UHCI Controller 1 AOpen Inc
00 / 29 / 01 PCI USB (UHCI) Intel Corporation 82801FB (ICH6) USB UHCI Controller 2 AOpen Inc
00 / 29 / 02 PCI USB (UHCI) Intel Corporation 82801FB (ICH6) USB UHCI Controller 3 AOpen Inc
00 / 29 / 03 PCI USB (UHCI) Intel Corporation 82801FB (ICH6) USB UHCI Controller 4 AOpen Inc
00 / 29 / 07 PCI USB 2.0 (EHCI) Intel Corporation 82801FB (ICH6) USB 2.0 EHCI Controller AOpen Inc
00 / 30 / 00 PCI PCI to PCI Bridge (Subtractive Decode) Intel Corporation 801FB Hub Interface to PCI Bridge (ICH6 C0 step) Intel Corporation
00 / 31 / 00 PCI PCI to ISA Bridge Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge Intel Corporation
00 / 31 / 02 PCI Bus Master IDE controller Intel Corporation 82801FB (ICH6) SATA Controller AOpen Inc
00 / 31 / 03 PCI SMBus Controller Intel Corporation 82801FB (ICH6) SMBus Controller AOpen Inc
01 / 00 / 00 PCI Ethernet Atheros Communications Inc AR5212 802.11a/b/g Wireless Adapter D-Link Inc DWL-G520 Wireless PCI Adapter(rev.B)
01 / 01 / 00 PCI Audio Device Creative Labs EMU10K1 Audio Chipset (SB Live!) Creative Labs SB0102 SBLive! 5.1
01 / 01 / 01 PCI Other Creative Labs PCI Gameport Creative Labs PCI Gameport
01 / 02 / 00 PCI Ethernet Realtek Semiconductor RTL8169 Gigabit Ethernet Adapter AOpen Inc
Noen som kan hjlpe ut fra det?
Hei Hei.
Vet ikke om du har fått fikset dette enda men her er noe du kan sjekke.
http://images.google.no/imgres?imgurl=http...sa%3DN%26um%3D1
åpne sidedøra på kabinettet ditt. mest sannsynelig 2 skruer bak eller så har du en klips \ håndtak du må ta i for å få åpnet.
Når du har fått åpnet så IKKE ta på noe inni der da du kan ødelegge dette med statisk elektisitet.
inni kabinettet vil du se et stort kort som alt er koblet sammen i. dette er hovedkortet ditt. der vil du kunne sammenligne portene som er på bildet over og det du har inni.
enten har du AGP eller så har du PCI-Express. PCI har du nok også men det er ikke noe å satse på når det kommer til skjermkort.
PCI-Express = mest sannynlig svart.
AGP = rød eller brun.
( kommer også i noen andre farger kommer ann på produsent )
PCI = Hvite.
Håper dette hjelper deg litt mer :D
