Lost tilbake 02.02.2010
Som sagt Lost er tilbake 2 februar 2010. Med siste sesongen, mest sansynelig ikke pause ved OL da på grunn av den "seine" tiden sesongen starter.
Jeff Fahey(Frank), Zuleikha Robinson(Ilana) og selvfølgelig Nestor Carbonell(Richard Alpert) rykker opp til maincast/hovedskuespiller. Og Emilie de Ravin retunerer på fulltid!
ABC ANNOUNCES THE PREMIERE OF THE SIXTH AND FINAL SEASON OF “LOST,” WITH A SPECIAL ALL-NIGHT EVENT ON TUESDAY, FEBRUARY 2
ABC announces the premiere of the sixth and final season of “Lost,” with a special all-night event on Tuesday, February 2. A recap special will kick
off the night from 8:00-9:00 p.m., ET, followed by the much anticipated two-hour premiere from 9:00-11:00 p.m.
The series will then air in its regular time period – Tuesday nights from 9:00-10:00 p.m., ET – beginning the following week, on February 9.
“Lost” stars Naveen Andrews as Sayid, Nestor Carbonell as Richard Alpert, Emilie de Ravin as Claire, Michael Emerson as Ben, Jeff Fahey as Frank
Lapidus, Matthew Fox as Jack, Jorge Garcia as Hurley, Josh Holloway as Sawyer, Daniel Dae Kim as Jin, Yunjin Kim as Sun, Ken Leung as Miles,
Evangeline Lilly as Kate, Terry O’Quinn as Locke and Zuleikha Robinson as Ilana.
“Lost” was created by Jeffrey Lieber and J.J. Abrams & Damon Lindelof. Abrams, Lindelof, Bryan Burk, Jack Bender, Edward Kitsis, Adam Horowitz, Jean Higgins and Carlton Cuse serve as executive producers. “Lost.” which is filmed entirely on location in Hawaii and premiered on September 22,2004, is from ABC Studios.
Endret av Mahavishnu
  • 2 uker senere...
Angående Juliet:
Klikk for å se/fjerne innholdet nedenfor
Hvis du ikke har fått med deg, så er Mitchell hovedskuespiller på "V" på ABC. Derfor har hun ikke mulighet til å være fast skuespiller på begge seriene. Hun skal derimot være med i flere episoder i sesong 6, bare ikke fast.
Desmond blir også veldig lite å se av. Men han skal også gjeste flere episoder utover sesongen, starter med sesongstarten.
  • 3 uker senere...
  • 2 uker senere...
Uff, håper ikke det. Da blir det som det alltid blir når et annet land enn USA sender en episode av en serie tidligere; dårligere kvalitet-leaks, masse forvirring og ikke minst sinne over at noen ikke kan å bruke spoilertags, når skal spoilertags brukes?-problematikken osv. samt den etterfølgende sutringen over at "det er så lenge til neste episode" fordi man så en episode tidligere enn man var ment til. :roll:
Nei, Australia skal ikke sende første episoden tidligere enn USA. Det med Flashforward var egentlig bare en glipp fra kanalen i Australia, fordi det var 2 ukers pause i USA.
Sendedatoene for begge kanalene i Australia som sender serien er enda ikke bestemt, eller hvertfall offentligjort.
Merk dere nytt spenndene promobilde av S6 casten i spoilertråden :)
  • 3 uker senere...
Ser fram til samleboksen kommer ut når de er ferdig å sende hele serien. Da blir det maraton :thumbup:
Da blir det endelig litt ordentlig kvalitet på episodene og. De 720p versjonene som legges ut mens sengen pågår er ikke noe særlig, alt for lav bitrate. Lite å samle på.
Når de kommer på Blu-ray derimot, blir det andre saker. 1080p og ekte kvalitet skal nytes på TV'en:D
