TundraStar Skrevet 11. november 2009 Del Skrevet 11. november 2009 Heisann! Ville bare ha en trygghetsgodkjenning av systemet jeg har satt opp før jeg kjøper det. Ser dette greit ut? -Sony Nec Optiarc DVD+-R/ RW/ DL SATA DRU-875S +24X8X8 -24X6X8X R12X LS RETAIL IN -WESTERN DIGITAL CAVIAR BLACK 1TB 32MB SATA/300 7200RPM -NZXT Tempest Steel Mid-Tower -SAMSUNG P2350 -BELKIN DVI TO DVI SINGLE LINK DVID 1.8M -CREATIVE Fatal1ty gamer headset w/mic 40mm Neodymium drivers, remote -D-LINK D-Link AirPlus G 54 Mbps Wireless USB Adapter -LOGITECH Cordless Wave Desktop mus/ tastatur -INTEL CORE I7-860 2.80GHZ SKT1156 FSB1333 8MB CACHE BOXED IN -CORSAIR Powersupply 620W, 120mm Vifte, 8xSATA, ATX/EPS, 2xPCI-E, 20/24pin -GAINWARD PCI-E GeForce GTX260 896MB Golden Sample -ASUS Mainboard S-1156 P55 ATX 2xPCI-E Audio GbLAN 2x1394 Raid DDR3 PhysX Ready (MAXIMUS III FORMULA) -4 x CRUCIAL DDR3 BallistiX 1600MHz 1GB, Non-ECC, 1.8V, 240pin, CL8-8-8-20 Takker for alle svar! Lenke til kommentar
TundraStar Skrevet 11. november 2009 Forfatter Del Skrevet 11. november 2009 Heisann! Ville bare ha en trygghetsgodkjenning av systemet jeg har satt opp før jeg kjøper det. Ser dette greit ut? -Sony Nec Optiarc DVD+-R/ RW/ DL SATA DRU-875S +24X8X8 -24X6X8X R12X LS RETAIL IN -WESTERN DIGITAL CAVIAR BLACK 1TB 32MB SATA/300 7200RPM -NZXT Tempest Steel Mid-Tower -SAMSUNG P2350 -BELKIN DVI TO DVI SINGLE LINK DVID 1.8M -CREATIVE Fatal1ty gamer headset w/mic 40mm Neodymium drivers, remote -D-LINK D-Link AirPlus G 54 Mbps Wireless USB Adapter -LOGITECH Cordless Wave Desktop mus/ tastatur -INTEL CORE I7-860 2.80GHZ SKT1156 FSB1333 8MB CACHE BOXED IN -CORSAIR Powersupply 620W, 120mm Vifte, 8xSATA, ATX/EPS, 2xPCI-E, 20/24pin -GAINWARD PCI-E GeForce GTX260 896MB Golden Sample -ASUS Mainboard S-1156 P55 ATX 2xPCI-E Audio GbLAN 2x1394 Raid DDR3 PhysX Ready (MAXIMUS III FORMULA) -4 x CRUCIAL DDR3 BallistiX 1600MHz 1GB, Non-ECC, 1.8V, 240pin, CL8-8-8-20 Takker for alle svar! Vurderer kanskje å bytte til i7 da jeg fant et veldig billig hovedkort fra MSI. MSI X58 Pro-E. Har noen noen erfaringer med dette? Lenke til kommentar
ronron25 Skrevet 11. november 2009 Del Skrevet 11. november 2009 Jeg ville sjekka om i7-860 kan kjøre med rambrikker med så høy spenning, siden i5-750 ikke bør kjøres med spenning over 1.65V. Om dette også gjelder for i7-860 vet ikke jeg, men ville sjekka det ut, som sagt. Ellers ser det greit ut. Tror faktisk dette gjelder for i7-860 også, når det gjelder hvilken spenning ram bør kjøres med: "What are the Intel® Core™ i7 processor and the Intel® Core™ i5 processor DDR3 memory voltage limitations? Intel® recommends using memory that adheres to the Jedec memory specification for DDR3 memory which is 1.5 volts, plus or minus 5%. Anything over this voltage can either damage the processor or significantly reduce the processor life span." http://www.intel.com/support/processors/sb/CS-029913.htm Lenke til kommentar
