valve hammer 3.4
There is no player start in the map. To add one, select the Entity (axe) tool, drag the crosshairs to the position you want the player to start at, and press ENTER.
har prøvd alt men får ikke til å lage player start?
noen som kan hjelpe litt :oops:
