[Løst]Can you run it test funker ikke
Hei siden http://cyri.systemrequirementslab.com/srtest/ funker ikke etter recovery. Jeg trykker på at den skal teste ett spill så står det
Before System Requirements Lab can analyze this computer you need to give your permission to download an ActiveX or Java Plug-in component called SysReqLab.cab, SRLApplet or System Requirements Lab from Husdawg, LLC. For more information about this component, see below. You may need to disable any Pop-up blocker you are using in order to use this service.
Troubleshooting
MORE INFORMATION ABOUT THIS TOOL
* It can only be downloaded with your permission.
* No personal information is collected.
* Easy and fast to download and run.
* Easily removed after analysis performed.
* If you are behind a firewall, you may not have permission to download browser components.
* Your browser's security settings must allow you to install ActiveX/Java Plug-in components.
* The tool is not Spyware or Adware.
Installing component..
Den står slik i en evighet uten noe framdrift. Browseren er mozilla.
