[Løst]Innstalere xbox spill til hdd
Isåfall må du chippe og da mister du garantien og muligens muligheten for online spilling, så nei ikke på en helt ny xbox. :)
Mener du at det ikke er å anbefale å innstallere spill på xboxen fordi jeg må chippe den? :p Det har jeg ikke tenkt til :p , men hvor masse pass tar som regel et xbox spill? eks; gta IV?
Også har jeg et annet spørsmål, vil dere anbefale og la xboxen stå eller ligge?
Gta 4 tar vel rundt 6-8 gigabyte. Du trenger ikke å chippe for å legge inn spill. Du kan flashe firmware på dvd drevet for å spille "backup" spill.
Gta 4 fungerer bedre fra disk enn harddisk faktisk:
PROS
- Initial Load is cut down by around 10-15 seconds
- Mission load times are cut down by around 2 seconds max
- Radio Stations change faster and Reset Bug that affects some players appears to be gone
- Minor bug where the controller starts to vibrate a brief second before Cell Phone appears on screen ringing also appears to be gone
- The console is really quiet
CONS
- Game takes up 6.8GB of Hard Drive space
- Pop In is made WORSE, this problem is somehow made worse after Installing, things like Plants and Trees took longer to appear and items like chairs, etc, seemed to vanish more often
- Texture problems on buildings, as with Pop In, Textures change from far away mode to close up a lot less smoother
- Building Pop Ups, This problem only happened once, but the Hospital in Broker seemed to vanish from its spot to only reappear a second later, never done that when playing from Disc
- No framerate improvements
