Hovedkort og CPU
Aopen MX36LE-UN Motherboard:
AOpen MX36LE-UN is an Intel Socket 370 motherboard based on the microATX form factor featuring the VIA Apollo PLE133T chipset. It supports Intel Socket 370 series Pentium III and Celeron processor in 66/ 100/-133MHz front side bus (FSB). The onboard IDE controller supports UltraATA 33/ 66/ 100 mode and the transfer rate up to the latest high-speed 100MB/s. Further flexibility can be achieved by taking advantage of the Communication and Network Riser (CNR) card option that allows audio or modem configuration on a single baseboard design. Besides, on the strength of built in AC97 CODEC controller, it can bring you the high-quality multimedia capabilities with the magic stereo surround. MX36LE-UN also has a LAN onboard and 4 USB ports as well as a VGA onboard that supports 4X AGP.
Der fikk du den... :)
