Nero 9 Problemer
Hei.
Det har nå uten tidligere endringer oppstått en feilmeldig når jeg skal brenne cder.
"could not perform end of disc at once"
Håper noen kan hjelpe meg med å tolke noe vettug ut av loggen.
Windows Vista 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 9.4.26.100
Internal Version: 9, 4, 26, 100
Recorder: <HL-DT-ST DVD+-RW GSA-T21N>Version: A102 - HA 1 TA 0 - 9.4.26.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <ZO9500S TOM194K >Version: 1.01 - HA 1 TA 1 - 9.4.26.100
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK1646GSX iaStor Port 0 ID 0 DMA: On
DiskPeripheral : TOSHIBA MK1646GSX iaStor Port 0 ID 1 DMA: Off
CdRomPeripheral : ZO9500S TOM194K 1.01 ap82odnb Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVD+-RW GSA-T21N F: CdRom0
ZO9500S TOM194K H: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 33 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.10.2009
Audio CD
00:43:48 #1 Text 0 File SCSIPTICommands.cpp, Line 430
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
00:43:48 #2 CDADOC -1 File Cdadoc.cpp, Line 1586
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 01:51.50, Pause frames: 150, Filters: 0, Name: '- Alf Prøysen - Nøtteliten.mp3'.
Track 02: Length: 01:38.42, Pause frames: 150, Filters: 0, Name: '01 - Anita Skorgan - Først kom et lass med lisser.mp3'.
Track 03: Length: 03:06.58, Pause frames: 150, Filters: 0, Name: '02-Lillebjørn Nilsen Barn av Regnbuen.mp3'.
Track 04: Length: 02:44.09, Pause frames: 150, Filters: 0, Name: '04 - Pinkys sang.mp3'.
Track 05: Length: 03:00.00, Pause frames: 150, Filters: 0, Name: '04-Lille Vakre Anna.mp3'.
Track 06: Length: 01:25.55, Pause frames: 150, Filters: 0, Name: '05_En og to og tre indianere (Indianersangen)_.mp3'.
Track 07: Length: 01:13.49, Pause frames: 150, Filters: 0, Name: '24. Har do hørt historien on de tre små fisk(Instrumental).mp3'.
Track 08: Length: 01:13.53, Pause frames: 150, Filters: 0, Name: '4.Har du hørt historien om de tre små fisk.mp3'.
Track 09: Length: 01:46.47, Pause frames: 150, Filters: 0, Name: 'Alf Prøysen - Helene Harefrøken.mp3'.
Track 10: Length: 02:58.11, Pause frames: 150, Filters: 0, Name: 'Alf Prøysen - I Bakvendtland.MP3'.
Track 11: Length: 02:50.37, Pause frames: 150, Filters: 0, Name: 'Alf Prøysen - Lillebror.MP3'.
Track 12: Length: 02:30.13, Pause frames: 150, Filters: 0, Name: 'Alf Prøysen - Steinrøysa Nedi Bakken.MP3'.
Track 13: Length: 04:25.28, Pause frames: 150, Filters: 0, Name: 'Alf Prøysen - Så Seiler Vi På Mjøsa.mp3'.
Track 14: Length: 02:05.17, Pause frames: 150, Filters: 0, Name: 'Alf Prøysen - Trollmor.mp3'.
Track 15: Length: 00:46.37, Pause frames: 150, Filters: 0, Name: 'Barnas Beste - 02 - - FløY En Liten BlåFugl.mp3'.
Track 16: Length: 03:19.05, Pause frames: 150, Filters: 0, Name: 'Barne TV - Postman Pat.mp3'.
Track 17: Length: 01:04.37, Pause frames: 150, Filters: 0, Name: 'Barne Tv - Brannmann Sam(Norsk).mp3'.
Track 18: Length: 02:15.68, Pause frames: 150, Filters: 0, Name: 'Barne Tv - Pelle Politibil(Norsk).mp3'.
Track 19: Length: 01:14.04, Pause frames: 150, Filters: 0, Name: 'Barnesang - Det bor en baker.mp3'.
Track 20: Length: 00:34.00, Pause frames: 150, Filters: 0, Name: 'Barnesanger - Lille Petter edderkopp.mp3'.
Track 21: Length: 01:33.42, Pause frames: 150, Filters: 0, Name: 'Barnesanger - Alf Prøysen - Blåbærtur'n.mp3'.
Track 22: Length: 01:51.50, Pause frames: 150, Filters: 0, Name: 'Barnesanger - Alf Prøysen - Nøtteliten.mp3'.
Track 23: Length: 01:08.01, Pause frames: 150, Filters: 0, Name: 'Barnesanger - B , b lille lam.mp3'.
Track 24: Length: 02:22.37, Pause frames: 150, Filters: 0, Name: 'Barnesanger - Bompi Bjørnene.mp3'.
Track 25: Length: 00:30.69, Pause frames: 150, Filters: 0, Name: 'Barnesanger - bananer i pyjamas.mp3'.
Track 26: Length: 02:13.46, Pause frames: 150, Filters: 0, Name: 'barne tv - Jeg Digger Deg.mp3'.
Track 27: Length: 01:42.39, Pause frames: 150, Filters: 0, Name: 'barne tv - Jeg er bj rnen Colargol.mp3'.
Track 28: Length: 01:06.00, Pause frames: 150, Filters: 0, Name: 'barne tv - Pippi.mp3'.
Track 29: Length: 03:25.24, Pause frames: 150, Filters: 0, Name: 'barne tv - her kommer mummi.mp3'.
Track 30: Length: 02:26.11, Pause frames: 150, Filters: 0, Name: 'barnesanger - Bolla pinnsvin.mp3'.
Total size: 61:24.39
00:43:48 #3 Text 0 File Burncd.cpp, Line 3242
Buffer underrun protection activated
00:43:48 #4 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
00:43:48 #5 Text 0 File Burncd.cpp, Line 3572
Turn on Disc-At-Once, using CD-R/RW media
00:43:49 #6 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 359846
Last address to be written: 276188
00:43:49 #7 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
00:43:49 #8 Text 0 File DlgWaitCD.cpp, Line 2843
Recorder: HL-DT-ST DVD+-RW GSA-T21N;
CDR code: 00 97 24 16; OSJ entry from: SONY Corporation
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 18 10 (LI 97:24.16), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
00:43:49 #9 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
00:43:49 #10 Text 0 File ThreadedTransferInterface.cpp, Line 739
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (- Alf Prøysen - Nøtteliten.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 8375 (8375) = #8375/1:51.50
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 8375 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
1: TRM_AUDIO_NOPRE (01 - Anita Skorgan - Først kom et lass med lisser.mp3)
original disc pos #0 + 7392 (7392) = #7392/1:38.42
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 7392 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
2: TRM_AUDIO_NOPRE (02-Lillebjørn Nilsen Barn av Regnbuen.mp3)
original disc pos #0 + 14008 (14008) = #14008/3:6.58
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14008 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
3: TRM_AUDIO_NOPRE (04 - Pinkys sang.mp3)
original disc pos #0 + 12309 (12309) = #12309/2:44.9
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12309 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
4: TRM_AUDIO_NOPRE (04-Lille Vakre Anna.mp3)
original disc pos #0 + 13500 (13500) = #13500/3:0.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13500 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
5: TRM_AUDIO_NOPRE (05_En og to og tre indianere (Indianersangen)_.mp3)
original disc pos #0 + 6430 (6430) = #6430/1:25.55
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 6430 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
6: TRM_AUDIO_NOPRE (24. Har do hørt historien on de tre små fisk(Instrumental).mp3)
original disc pos #0 + 5524 (5524) = #5524/1:13.49
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 5524 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
7: TRM_AUDIO_NOPRE (4.Har du hørt historien om de tre små fisk.mp3)
original disc pos #0 + 5528 (5528) = #5528/1:13.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 5528 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
8: TRM_AUDIO_NOPRE (Alf Prøysen - Helene Harefrøken.mp3)
original disc pos #0 + 7997 (7997) = #7997/1:46.47
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 7997 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
9: TRM_AUDIO_NOPRE (Alf Prøysen - I Bakvendtland.MP3)
original disc pos #0 + 13361 (13361) = #13361/2:58.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13361 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
10: TRM_AUDIO_NOPRE (Alf Prøysen - Lillebror.MP3)
original disc pos #0 + 12787 (12787) = #12787/2:50.37
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12787 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
11: TRM_AUDIO_NOPRE (Alf Prøysen - Steinrøysa Nedi Bakken.MP3)
original disc pos #0 + 11263 (11263) = #11263/2:30.13
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11263 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
12: TRM_AUDIO_NOPRE (Alf Prøysen - Så Seiler Vi På Mjøsa.mp3)
original disc pos #0 + 19903 (19903) = #19903/4:25.28
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19903 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
13: TRM_AUDIO_NOPRE (Alf Prøysen - Trollmor.mp3)
original disc pos #0 + 9392 (9392) = #9392/2:5.17
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 9392 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
14: TRM_AUDIO_NOPRE (Barnas Beste - 02 - - FløY En Liten BlåFugl.mp3)
original disc pos #0 + 3487 (3487) = #3487/0:46.37
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 3487 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
15: TRM_AUDIO_NOPRE (Barne TV - Postman Pat.mp3)
original disc pos #0 + 14930 (14930) = #14930/3:19.5
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14930 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
16: TRM_AUDIO_NOPRE (Barne Tv - Brannmann Sam(Norsk).mp3)
original disc pos #0 + 4837 (4837) = #4837/1:4.37
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 4837 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
17: TRM_AUDIO_NOPRE (Barne Tv - Pelle Politibil(Norsk).mp3)
original disc pos #0 + 10193 (10193) = #10193/2:15.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10193 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
18: TRM_AUDIO_NOPRE (Barnesang - Det bor en baker.mp3)
original disc pos #0 + 5554 (5554) = #5554/1:14.4
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 5554 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
19: TRM_AUDIO_NOPRE (Barnesanger - Lille Petter edderkopp.mp3)
original disc pos #0 + 2550 (2550) = #2550/0:34.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 2550 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
20: TRM_AUDIO_NOPRE (Barnesanger - Alf Prøysen - Blåbærtur'n.mp3)
original disc pos #0 + 7017 (7017) = #7017/1:33.42
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 7017 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
21: TRM_AUDIO_NOPRE (Barnesanger - Alf Prøysen - Nøtteliten.mp3)
22: TRM_AUDIO_NOPRE (Barnesanger - B , b lille lam.mp3)
original disc pos #0 + 5101 (5101) = #5101/1:8.1
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 5101 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
23: TRM_AUDIO_NOPRE (Barnesanger - Bompi Bjørnene.mp3)
original disc pos #0 + 10687 (10687) = #10687/2:22.37
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10687 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
24: TRM_AUDIO_NOPRE (Barnesanger - bananer i pyjamas.mp3)
original disc pos #0 + 2319 (2319) = #2319/0:30.69
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 2319 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
25: TRM_AUDIO_NOPRE (barne tv - Jeg Digger Deg.mp3)
original disc pos #0 + 10021 (10021) = #10021/2:13.46
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10021 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
26: TRM_AUDIO_NOPRE (barne tv - Jeg er bj rnen Colargol.mp3)
original disc pos #0 + 7689 (7689) = #7689/1:42.39
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 7689 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
27: TRM_AUDIO_NOPRE (barne tv - Pippi.mp3)
original disc pos #0 + 4950 (4950) = #4950/1:6.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 4950 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
28: TRM_AUDIO_NOPRE (barne tv - her kommer mummi.mp3)
original disc pos #0 + 15399 (15399) = #15399/3:25.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15399 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
29: TRM_AUDIO_NOPRE (barnesanger - Bolla pinnsvin.mp3)
original disc pos #0 + 10961 (10961) = #10961/2:26.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 10961 blocks [F: HL-DT-ST DVD+-RW GSA-T21N]
00:43:49 #11 Text 0 File ThreadedTransferInterface.cpp, Line 941
Prepare [F: HL-DT-ST DVD+-RW GSA-T21N] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 30: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 20050800, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 20050800 20403600 37789584, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 37789584 38142384 71089200, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 71089200 71442000 100392768, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 100392768 100745568 132497568, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 132497568 132850368 147973728, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 147973728 148326528 161318976, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 161318976 161671776 174673632, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 174673632 175026432 193835376, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 193835376 194188176 225613248, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 225613248 225966048 256041072, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 256041072 256393872 282884448, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 282884448 283237248 330049104, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 330049104 330401904 352491888, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 352491888 352844688 361046112, ISRC ""
16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 361046112 361398912 396514272, ISRC ""
17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 396514272 396867072 408243696, ISRC ""
18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 408243696 408596496 432570432, ISRC ""
19: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 432570432 432923232 445986240, ISRC ""
20: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 445986240 446339040 452336640, ISRC ""
21: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 452336640 452689440 469193424, ISRC ""
22: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 469193424 469546224 489244224, ISRC ""
23: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 489244224 489597024 501594576, ISRC ""
24: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 501594576 501947376 527083200, ISRC ""
25: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 527083200 527436000 532890288, ISRC ""
26: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 532890288 533243088 556812480, ISRC ""
27: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 556812480 557165280 575249808, ISRC ""
28: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 575249808 575602608 587245008, ISRC ""
29: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 587245008 587597808 623816256, ISRC ""
30: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 623816256 624169056 649949328, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 0 | 0 | 0x00
0 | 1 | 1 | 0x21 | 8375 | 0 | 0x00
8375 | 2 | 0 | 0x21 | 0 | 0 | 0x00
8525 | 2 | 1 | 0x21 | 7392 | 8525 | 0x00
15917 | 3 | 0 | 0x21 | 0 | 0 | 0x00
16067 | 3 | 1 | 0x21 | 14008 | 16067 | 0x00
30075 | 4 | 0 | 0x21 | 0 | 0 | 0x00
30225 | 4 | 1 | 0x21 | 12309 | 30225 | 0x00
42534 | 5 | 0 | 0x21 | 0 | 0 | 0x00
42684 | 5 | 1 | 0x21 | 13500 | 42684 | 0x00
56184 | 6 | 0 | 0x21 | 0 | 0 | 0x00
56334 | 6 | 1 | 0x21 | 6430 | 56334 | 0x00
62764 | 7 | 0 | 0x21 | 0 | 0 | 0x00
62914 | 7 | 1 | 0x21 | 5524 | 62914 | 0x00
68438 | 8 | 0 | 0x21 | 0 | 0 | 0x00
68588 | 8 | 1 | 0x21 | 5528 | 68588 | 0x00
74116 | 9 | 0 | 0x21 | 0 | 0 | 0x00
74266 | 9 | 1 | 0x21 | 7997 | 74266 | 0x00
82263 | 10 | 0 | 0x21 | 0 | 0 | 0x00
82413 | 10 | 1 | 0x21 | 13361 | 82413 | 0x00
95774 | 11 | 0 | 0x21 | 0 | 0 | 0x00
95924 | 11 | 1 | 0x21 | 12787 | 95924 | 0x00
108711 | 12 | 0 | 0x21 | 0 | 0 | 0x00
108861 | 12 | 1 | 0x21 | 11263 | 108861 | 0x00
120124 | 13 | 0 | 0x21 | 0 | 0 | 0x00
120274 | 13 | 1 | 0x21 | 19903 | 120274 | 0x00
140177 | 14 | 0 | 0x21 | 0 | 0 | 0x00
140327 | 14 | 1 | 0x21 | 9392 | 140327 | 0x00
149719 | 15 | 0 | 0x21 | 0 | 0 | 0x00
149869 | 15 | 1 | 0x21 | 3487 | 149869 | 0x00
153356 | 16 | 0 | 0x21 | 0 | 0 | 0x00
153506 | 16 | 1 | 0x21 | 14930 | 153506 | 0x00
168436 | 17 | 0 | 0x21 | 0 | 0 | 0x00
168586 | 17 | 1 | 0x21 | 4837 | 168586 | 0x00
173423 | 18 | 0 | 0x21 | 0 | 0 | 0x00
173573 | 18 | 1 | 0x21 | 10193 | 173573 | 0x00
183766 | 19 | 0 | 0x21 | 0 | 0 | 0x00
183916 | 19 | 1 | 0x21 | 5554 | 183916 | 0x00
189470 | 20 | 0 | 0x21 | 0 | 0 | 0x00
189620 | 20 | 1 | 0x21 | 2550 | 189620 | 0x00
192170 | 21 | 0 | 0x21 | 0 | 0 | 0x00
192320 | 21 | 1 | 0x21 | 7017 | 192320 | 0x00
199337 | 22 | 0 | 0x21 | 0 | 0 | 0x00
199487 | 22 | 1 | 0x21 | 8375 | 199487 | 0x00
207862 | 23 | 0 | 0x21 | 0 | 0 | 0x00
208012 | 23 | 1 | 0x21 | 5101 | 208012 | 0x00
213113 | 24 | 0 | 0x21 | 0 | 0 | 0x00
213263 | 24 | 1 | 0x21 | 10687 | 213263 | 0x00
223950 | 25 | 0 | 0x21 | 0 | 0 | 0x00
224100 | 25 | 1 | 0x21 | 2319 | 224100 | 0x00
226419 | 26 | 0 | 0x21 | 0 | 0 | 0x00
226569 | 26 | 1 | 0x21 | 10021 | 226569 | 0x00
236590 | 27 | 0 | 0x21 | 0 | 0 | 0x00
236740 | 27 | 1 | 0x21 | 7689 | 236740 | 0x00
244429 | 28 | 0 | 0x21 | 0 | 0 | 0x00
244579 | 28 | 1 | 0x21 | 4950 | 244579 | 0x00
249529 | 29 | 0 | 0x21 | 0 | 0 | 0x00
249679 | 29 | 1 | 0x21 | 15399 | 249679 | 0x00
265078 | 30 | 0 | 0x21 | 0 | 0 | 0x00
265228 | 30 | 1 | 0x21 | 10961 | 265228 | 0x00
276189 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
00:43:49 #12 Text 0 File SCSIPTICommands.cpp, Line 217
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
00:43:49 #13 Text 0 File Burncd.cpp, Line 4279
Caching options: cache CDRom or Network-No, small files-No (<64KB)
00:43:49 #14 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 24x (3 600 KB/s)
00:43:49 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
00:43:49 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #8525
00:43:49 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #16067
00:43:49 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #30225
00:43:49 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #42684
00:43:49 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #56334
00:43:49 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #62914
00:43:49 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #68588
00:43:49 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #74266
00:43:49 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #82413
00:43:49 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #95924
00:43:49 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #108861
00:43:49 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #120274
00:43:49 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #140327
00:43:49 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #149869
00:43:49 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #153506
00:43:49 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #168586
00:43:49 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #173573
00:43:49 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 18 (relocatable, no disc pos, no patch infos, orig at #0): write at #183916
00:43:49 #34 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 19 (relocatable, no disc pos, no patch infos, orig at #0): write at #189620
00:43:49 #35 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 20 (relocatable, no disc pos, no patch infos, orig at #0): write at #192320
00:43:49 #36 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 21 (relocatable, no disc pos, no patch infos, orig at #0): write at #199487
00:43:49 #37 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 22 (relocatable, no disc pos, no patch infos, orig at #0): write at #208012
00:43:49 #38 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 23 (relocatable, no disc pos, no patch infos, orig at #0): write at #213263
00:43:49 #39 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 24 (relocatable, no disc pos, no patch infos, orig at #0): write at #224100
00:43:49 #40 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 25 (relocatable, no disc pos, no patch infos, orig at #0): write at #226569
00:43:49 #41 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 26 (relocatable, no disc pos, no patch infos, orig at #0): write at #236740
00:43:49 #42 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 27 (relocatable, no disc pos, no patch infos, orig at #0): write at #244579
00:43:49 #43 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 28 (relocatable, no disc pos, no patch infos, orig at #0): write at #249679
00:43:49 #44 Text 0 File ThreadedTransferInterface.cpp, Line 2695
Verifying disc position of item 29 (relocatable, no disc pos, no patch infos, orig at #0): write at #265228
00:43:49 #45 Text 0 File MMC.cpp, Line 17516
StartDAO : CD-Text - On
00:43:49 #46 Text 0 File MMC.cpp, Line 21767
Set BUFE: Buffer underrun protection -> ON
00:43:49 #47 Text 0 File MMC.cpp, Line 17746
CueData, Len=496
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 01 35 32
21 02 01 00 00 01 37 32
21 03 00 00 00 03 22 11
21 03 01 00 00 03 24 11
21 04 00 00 00 06 2b 00
21 04 01 00 00 06 2d 00
21 05 00 00 00 09 1d 09
21 05 01 00 00 09 1f 09
21 06 00 00 00 0c 1f 09
21 06 01 00 00 0c 21 09
21 07 00 00 00 0d 3a 40
21 07 01 00 00 0e 00 40
21 08 00 00 00 0f 0e 26
21 08 01 00 00 0f 10 26
21 09 00 00 00 10 1e 10
21 09 01 00 00 10 20 10
21 0a 00 00 00 12 12 3f
21 0a 01 00 00 12 14 3f
21 0b 00 00 00 15 12 4a
21 0b 01 00 00 15 14 4a
21 0c 00 00 00 18 0b 24
21 0c 01 00 00 18 0d 24
21 0d 00 00 00 1a 2b 31
21 0d 01 00 00 1a 2d 31
21 0e 00 00 00 1f 0b 02
21 0e 01 00 00 1f 0d 02
21 0f 00 00 00 21 12 13
21 0f 01 00 00 21 14 13
21 10 00 00 00 22 06 38
21 10 01 00 00 22 08 38
21 11 00 00 00 25 1b 3d
21 11 01 00 00 25 1d 3d
21 12 00 00 00 26 22 17
21 12 01 00 00 26 24 17
21 13 00 00 00 28 34 10
21 13 01 00 00 28 36 10
21 14 00 00 00 2a 08 14
21 14 01 00 00 2a 0a 14
21 15 00 00 00 2a 2c 14
21 15 01 00 00 2a 2e 14
21 16 00 00 00 2c 13 3e
21 16 01 00 00 2c 15 3e
21 17 00 00 00 2e 0d 25
21 17 01 00 00 2e 0f 25
21 18 00 00 00 2f 17 26
21 18 01 00 00 2f 19 26
21 19 00 00 00 31 30 00
21 19 01 00 00 31 32 00
21 1a 00 00 00 32 14 45
21 1a 01 00 00 32 16 45
21 1b 00 00 00 34 24 28
21 1b 01 00 00 34 26 28
21 1c 00 00 00 36 15 04
21 1c 01 00 00 36 17 04
21 1d 00 00 00 37 1d 04
21 1d 01 00 00 37 1f 04
21 1e 00 00 00 3a 38 1c
21 1e 01 00 00 3a 3a 1c
01 aa 01 01 00 3d 18 27
00:43:49 #48 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
00:44:07 #49 SPTI -1119 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1119)
CDB Data: 0x2A 00 FF FF D7 1A 00 02 AA 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x03
Sense Area: 0x70 00 04 00 00 00 00 0A 34 14 04 80 09 03
Buffer x0f024580: Len xffc0
0x20 10 24 3E 00 32 01 10 1C 2F 21 39 1C 36 15 2E
0x00 04 05 2C 19 2F 19 26 20 10 28 3F 00 32 01 10
0x1C 2F 21 39 1C 36 15 2E 00 04 05 2C 19 26 38 22
00:44:07 #50 CDR -1119 File Writer.cpp, Line 306
Track following error
00:44:07 #51 SPTI -1119 File SCSIPassThrough.cpp, Line 215
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x09
Sense Qual: 0x03
Sense Area: 0x71 00 04 00 00 00 00 0A 34 14 04 80 09 03
00:44:07 #52 CDR -1119 File WriterStatus.cpp, Line 292
00:44:07 #53 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
00:44:07 #54 Text 0 File DVDPlusDualLayer.cpp, Line 1452
SetDriveCaps: Set LAST LBA of layer 1 to 0
00:44:07 #55 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 24x (3 600 KB/s)
00:44:07 #56 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
00:44:07 #57 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
00:44:07 #58 Text 0 File SCSIPTICommands.cpp, Line 267
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
00:44:08 #59 Text 0 File Cdrdrv.cpp, Line 11592
DriveLocker: UnLockVolume completed
00:44:08 #60 Text 0 File SCSIPTICommands.cpp, Line 430
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
