hvor har dere gjemt delphi og pascal programmeringen hen ?
jeg finner det ikke .
hva gjør at denne kodelinje elegant blir hoppe over ?
for t1 := miny to maxy div h do begin
x1:=(maxx-(t1*h)div 2) +miny;
y1:=t1*h;
end;
variablene har følgende verdier :
miny:8
maxy:12
h:2
Ting er blitt flyttet rundt, aner ikke hvor kategorien ble av ^^
Jeg er ikke så kjent med Delphi (drev bare kort vedlikehold av et håpløst program)
Hva gjør "div h" og "div 2"?
Hvis det er det samme som / så vil jo maxy / 2 = 6 og 8 to 6 funker ikke. Da må du isåfall bruke 8 downto 6.
nå forsvant alt jeg holt på å legge inne.
Declarations and Statements
This topic describes the syntax of Delphi declarations and statements.
Aside from the uses clause (and reserved words like implementation that demarcate parts of a unit), a program consists entirely of declarations and statements, which are organized into blocks.
This topic covers the following items:
Declarations
Simple statements such as assignment
Structured statements such as conditional tests (e.g., if-then, and case), iteration (e.g., for, and while).
Declarations
The names of variables, constants, types, fields, properties, procedures, functions, programs, units, libraries, and packages are called identifiers. (Numeric constants like 26057 are not identifiers.) Identifiers must be declared before you can use them; the only exceptions are a few predefined types, routines, and constants that the compiler understands automatically, the variable Result when it occurs inside a function block, and the variable Self when it occurs inside a method implementation.
A declaration defines an identifier and, where appropriate, allocates memory for it. For example,
var Size: Extended;
declares a variable called Size that holds an Extended (real) value, while
function DoThis(X, Y: string): Integer;
declares a function called DoThis that takes two strings as arguments and returns an integer. Each declaration ends with a semicolon. When you declare several variables, constants, types, or labels at the same time, you need only write the appropriate reserved word once:
var
Quantity: Integer;
Description: string;
The syntax and placement of a declaration depend on the kind of identifier you are defining. In general, declarations can occur only at the beginning of a block or at the beginning of the interface or implementation section of a unit (after the uses clause). Specific conventions for declaring variables, constants, types, functions, and so forth are explained in the documentation for those topics.
Hinting Directives
The 'hint' directives platform, deprecated, and library may be appended to any declaration. These directives will produce warnings at compile time. Hint directives can be applied to type declarations, variable declarations, class, interface and structure declarations, field declarations within classes or records, procedure, function and method declarations, and unit declarations.
When a hint directive appears in a unit declaration, it means that the hint applies to everything in the unit. For example, the Windows 3.1 style OleAuto.pas unit on Windows is completely deprecated. Any reference to that unit or any symbol in that unit will produce a deprecation message.
The platform hinting directive on a symbol or unit indicates that it may not exist or that the implementation may vary considerably on different platforms. The library hinting directive on a symbol or unit indicates that the code may not exist or the implementation may vary considerably on different library architectures.
The platform and library directives do not specify which platform or library. If your goal is writing platform-independent code, you do not need to know which platform a symbol is specific to; it is sufficient that the symbol be marked as specific to some platform to let you know it may cause problems for your goal of portability.
In the case of a procedure or function declaration, the hint directive should be separated from the rest of the declaration with a semicolon. Examples:
procedure SomeOldRoutine; stdcall deprecated;
var
VersionNumber: Real library;
type
AppError = class(Exception)
end platform;
When source code is compiled in the {$HINTS ON} {$WARNINGS ON} state, each reference to an identifier declared with one of these directives generates an appropriate hint or warning. Use platform to mark items that are specific to a particular operating environment (such as Windows or .NET), deprecated to indicate that an item is obsolete or supported only for backward compatibility, and library to flag dependencies on a particular library or component framework.
The Developer Studio 2006 compiler also recognizes the hinting directive experimental. You can use this directive to designate units which are in an unstable, development state. The compiler will emit a warning when it builds an application that uses the unit.
Statements
Statements define algorithmic actions within a program. Simple statements like assignments and procedure calls can combine to form loops, conditional statements, and other structured statements.
Multiple statements within a block, and in the initialization or finalization section of a unit, are separated by semicolons.
Simple Statements
A simple statement doesn't contain any other statements. Simple statements include assignments, calls to procedures and functions, and goto jumps.
Assignment Statements
An assignment statement has the form
variable := expression
where variable is any variable reference, including a variable, variable typecast, dereferenced pointer, or component of a structured variable. The expression is any assignment-compatible expression (within a function block, variable can be replaced with the name of the function being defined. See Procedures and functions ). The := symbol is sometimes called the assignment operator.
An assignment statement replaces the current value of variable with the value of expression. For example,
I := 3;
assigns the value 3 to the variable I. The variable reference on the left side of the assignment can appear in the expression on the right. For example,
I := I + 1;
increments the value of I. Other assignment statements include
X := Y + Z;
Done := (I >= 1) and (I < 100);
Hue1 := [blue, Succ©];
I := Sqr(J) - I * K;
Shortint(MyChar) := 122;
TByteRec(W).Hi := 0;
MyString := 'A';
SomeArray[i + 1] := P^;
TMyObject.SomeProperty := True;
Procedure and Function Calls
A procedure call consists of the name of a procedure (with or without qualifiers), followed by a parameter list (if required). Examples include
PrintHeading;
Transpose(A, N, M);
Find(Smith, William);
Writeln('Hello world!');
DoSomething();
Unit1.SomeProcedure;
TMyObject.SomeMethod(X,Y);
With extended syntax enabled ({$X+}), function calls, like calls to procedures, can be treated as statements in their own right:
MyFunction(X);
When you use a function call in this way, its return value is discarded.
For more information about procedures and functions, see Procedures and functions.
Goto Statements
A goto statement, which has the form
goto label
transfers program execution to the statement marked by the specified label. To mark a statement, you must first declare the label. Then precede the statement you want to mark with the label and a colon:
label: statement
Declare labels like this:
label label;
You can declare several labels at once:
label label1, ..., labeln;
A label can be any valid identifier or any numeral between 0 and 9999.
The label declaration, marked statement, and goto statement must belong to the same block. (See Blocks and Scope, below.) Hence it is not possible to jump into or out of a procedure or function. Do not mark more than one statement in a block with the same label.
For example,
label StartHere;
StartHere: Beep;
goto StartHere;
creates an infinite loop that calls the Beep procedure repeatedly.
Additionally, it is not possible to jump into or out of a try-finally or try-except statement.
The goto statement is generally discouraged in structured programming. It is, however, sometimes used as a way of exiting from nested loops, as in the following example.
procedure FindFirstAnswer;
var X, Y, Z, Count: Integer;
label FoundAnAnswer;
begin
Count := SomeConstant;
for X := 1 to Count do
for Y := 1 to Count do
for Z := 1 to Count do
if ... { some condition holds on X, Y, and Z } then
goto FoundAnAnswer;
... { Code to execute if no answer is found }
Exit;
FoundAnAnswer:
... { Code to execute when an answer is found }
end;
Notice that we are using goto to jump out of a nested loop. Never jump into a loop or other structured statement, since this can have unpredictable effects.
Structured Statements
Structured statements are built from other statements. Use a structured statement when you want to execute other statements sequentially, conditionally, or repeatedly.
A compound or with statement simply executes a sequence of constituent statements.
A conditional statement that is an if or case statement executes at most one of its constituents, depending on specified criteria.
Loop statements including repeat, while, and for loops execute a sequence of constituent statements repeatedly.
A special group of statements including raise, try...except, and try...finally constructions create and handle exceptions. For information about exception generation and handling, see Exceptions .
Compound Statements
A compound statement is a sequence of other (simple or structured) statements to be executed in the order in which they are written. The compound statement is bracketed by the reserved words begin and end, and its constituent statements are separated by semicolons. For example:
begin
Z := X;
X := Y;
X := Y;
end;
The last semicolon before end is optional. So we could have written this as
begin
Z := X;
X := Y;
Y := Z
end;
Compound statements are essential in contexts where Delphi syntax requires a single statement. In addition to program, function, and procedure blocks, they occur within other structured statements, such as conditionals or loops. For example:
begin
I := SomeConstant;
while I > 0 do
begin
I := I - 1;
end;
end;
You can write a compound statement that contains only a single constituent statement; like parentheses in a complex term, begin and end sometimes serve to disambiguate and to improve readability. You can also use an empty compound statement to create a block that does nothing:
begin
end;
With Statements
A with statement is a shorthand for referencing the fields of a record or the fields, properties, and methods of an object. The syntax of a with statement is
with obj do statement, or
with obj1, ..., objn do statement
where obj is an expression yielding a reference to a record, object instance, class instance, interface or class type (metaclass) instance, and statement is any simple or structured statement. Within the statement, you can refer to fields, properties, and methods of obj using their identifiers alone, that is, without qualifiers.
For example, given the declarations
type
TDate = record
Day: Integer;
Month: Integer;
Year: Integer;
end;
var
OrderDate: TDate;
you could write the following with statement.
with OrderDate do
if Month = 12 then
begin
Month := 1;
Year := Year + 1;
end
else
Month := Month + 1;
if OrderDate.Month = 12 then
begin
OrderDate.Month := 1;
OrderDate.Year := OrderDate.Year + 1;
end
else
OrderDate.Month := OrderDate.Month + 1;
If the interpretation of obj involves indexing arrays or dereferencing pointers, these actions are performed once, before statement is executed. This makes with statements efficient as well as concise. It also means that assignments to a variable within statement cannot affect the interpretation of obj during the current execution of the with statement.
Each variable reference or method name in a with statement is interpreted, if possible, as a member of the specified object or record. If there is another variable or method of the same name that you want to access from the with statement, you need to prepend it with a qualifier, as in the following example.
with OrderDate do
begin
Year := Unit1.Year;
end;
When multiple objects or records appear after with, the entire statement is treated like a series of nested with statements. Thus
with obj1, obj2, ..., objn do statement
is equivalent to
with obj1 do
with obj2 do
with objn do
// statement
In this case, each variable reference or method name in statement is interpreted, if possible, as a member of objn; otherwise it is interpreted, if possible, as a member of objn1; and so forth. The same rule applies to interpreting the objs themselves, so that, for instance, if objn is a member of both obj1 and obj2, it is interpreted as obj2.objn.
If Statements
There are two forms of if statement: if...then and the if...then...else. The syntax of an if...then statement is
if expression then statement
where expression returns a Boolean value. If expression is True, then statement is executed; otherwise it is not. For example,
if J <> 0 then Result := I / J;
The syntax of an if...then...else statement is
if expression then statement1 else statement2
where expression returns a Boolean value. If expression is True, then statement1 is executed; otherwise statement2 is executed. For example,
if J = 0 then
Exit
else
Result := I / J;
The then and else clauses contain one statement each, but it can be a structured statement. For example,
if J <> o then
begin
Result := I / J;
Count := Count + 1;
end
else if Count = Last then
Done := True
else
Exit;
Notice that there is never a semicolon between the then clause and the word else. You can place a semicolon after an entire if statement to separate it from the next statement in its block, but the then and else clauses require nothing more than a space or carriage return between them. Placing a semicolon immediately before else (in an if statement) is a common programming error.
A special difficulty arises in connection with nested if statements. The problem arises because some if statements have else clauses while others do not, but the syntax for the two kinds of statement is otherwise the same. In a series of nested conditionals where there are fewer else clauses than if statements, it may not seem clear which else clauses are bound to which ifs. Consider a statement of the form
if expression1 then if expression2 then statement1 else statement2;
There would appear to be two ways to parse this:
if expression1 then [ if expression2 then statement1 else statement2 ];
if expression1 then [ if expression2 then statement1 ] else statement2;
The compiler always parses in the first way. That is, in real code, the statement
if ... { expression1} then
if ... {expression2} then
... {statement1}
else
... {statement2}
is equivalent to
if ... {expression1} then
begin
... {statement1}
else
... {statement2}
end;
The rule is that nested conditionals are parsed starting from the innermost conditional, with each else bound to the nearest available if on its left. To force the compiler to read our example in the second way, you would have to write it explicitly as
begin
... {statement1}
end
end
else
... {statement2};
Case Statements
The case statement may provide a readable alternative to deeply nested if conditionals. A case statement has the form
case selectorExpression of
caseList1: statement1;
caseListn: statementn;
end
where selectorExpression is any expression of an ordinal type smaller than 32 bits (string types and ordinals larger than 32 bits are invalid) and each caseList is one of the following:
A numeral, declared constant, or other expression that the compiler can evaluate without executing your program. It must be of an ordinal type compatible with selectorExpression. Thus 7, True, 4 + 5 * 3, 'A', and Integer('A') can all be used as caseLists, but variables and most function calls cannot. (A few built-in functions like Hi and Lo can occur in a caseList. See Constant expressions.)
A subrange having the form First..Last, where First and Last both satisfy the criterion above and First is less than or equal to Last.
A list having the form item1, ..., itemn, where each item satisfies one of the criteria above.
Each value represented by a caseList must be unique in the case statement; subranges and lists cannot overlap. A case statement can have a final else clause:
caselistn: statementn;
else
statements;
end
where statements is a semicolon-delimited sequence of statements. When a case statement is executed, at most one of statement1 ... statementn is executed. Whichever caseList has a value equal to that of selectorExpression determines the statement to be used. If none of the caseLists has the same value as selectorExpression, then the statements in the else clause (if there is one) are executed.
The case statement
case I of
1..5: Caption := 'Low';
6..9: Caption := 'High';
0, 10..99: Caption := 'Out of range';
else
Caption := '';
end
is equivalent to the nested conditional
if I in [1..5] then
Caption := 'Low';
else if I in [6..10] then
Caption := 'High';
else if (I = 0) or (I in [10..99]) then
else
Caption := '';
Other examples of case statements
case MyColor of
Red: X := 1;
Green: X := 2;
Blue: X = 3;
Yellow, Orange, Black: X := 0;
end;
case Selection of
Done: Form1.Close;
Compute: calculateTotal(UnitCost, Quantity);
else
Beep;
end;
Control Loops
Loops allow you to execute a sequence of statements repeatedly, using a control condition or variable to determine when the execution stops. Delphi has three kinds of control loop: repeat statements, while statements, and for statements.
You can use the standard Break and Continue procedures to control the flow of a repeat, while, or for statement. Break terminates the statement in which it occurs, while Continue begins executing the next iteration of the sequence.
Repeat Statements
The syntax of a repeat statement is
repeat statement1; ...; statementn; until expression
where expression returns a Boolean value. (The last semicolon before until is optional.) The repeat statement executes its sequence of constituent statements continually, testing expression after each iteration. When expression returns True, the repeat statement terminates. The sequence is always executed at least once because expression is not evaluated until after the first iteration.
Examples of repeat statements include
repeat
K := I mod J;
I := J;
J := K;
until J = 0;
repeat
Write('Enter a value (0..9): ');
Readln(I);
until (I >= 0) and (I <= 9);
While Statements
A while statement is similar to a repeat statement, except that the control condition is evaluated before the first execution of the statement sequence. Hence, if the condition is false, the statement sequence is never executed.
The syntax of a while statement is
while expression do statement
where expression returns a Boolean value and statement can be a compound statement. The while statement executes its constituent statement repeatedly, testing expression before each iteration. As long as expression returns True, execution continues.
Examples of while statements include
while Data <> X do I := I + 1;
while I > 0 do
begin
if Odd(I) then Z := Z * X;
I := I div 2;
X := Sqr(X);
end;
while not Eof(InputFile) do
begin
Readln(InputFile, Line);
Process(Line);
end;
For Statements
A for statement, unlike a repeat or while statement, requires you to specify explicitly the number of iterations you want the loop to go through. The syntax of a for statement is
for counter := initialValue to finalValue do statement
or
for counter := initialValue downto finalValue do statement
where
counter is a local variable (declared in the block containing the for statement) of ordinal type, without any qualifiers.
initialValue and finalValue are expressions that are assignment-compatible with counter.
statement is a simple or structured statement that does not change the value of counter.
The for statement assigns the value of initialValue to counter, then executes statement repeatedly, incrementing or decrementing counter after each iteration. (The for...to syntax increments counter, while the for...downto syntax decrements it.) When counter returns the same value as finalValue, statement is executed once more and the for statement terminates. In other words, statement is executed once for every value in the range from initialValue to finalValue. If initialValue is equal to finalValue, statement is executed exactly once. If initialValue is greater than finalValue in a for...to statement, or less than finalValue in a for...downto statement, then statement is never executed. After the for statement terminates (provided this was not forced by a Break or an Exit procedure), the value of counter is undefined.
For purposes of controlling execution of the loop, the expressions initialValue and finalValue are evaluated only once, before the loop begins. Hence the for...to statement is almost, but not quite, equivalent to this while construction:
begin
counter := initialValue;
while counter <= finalValue do
begin
... {statement};
counter := Succ(counter);
end;
end
The difference between this construction and the for...to statement is that the while loop reevaluates finalValue before each iteration. This can result in noticeably slower performance if finalValue is a complex expression, and it also means that changes to the value of finalValue within statement can affect execution of the loop.
Examples of for statements:
for I := 2 to 63 do
if Data > Max then
Max := Data;
for I := ListBox1.Items.Count - 1 downto 0 do
ListBox1.Items := UpperCase(ListBox1.Items);
for I := 1 to 10 do
for J := 1 to 10 do
begin
X := 0;
for K := 1 to 10 do
X := X + Mat1[i,K] * Mat2[K,J];
Mat[i,J] := X;
end;
for C := Red to Blue do Check©;
Iteration Over Containers Using For statements
Both Delphi for .NET and for Win32 support for-element-in-collection style iteration over containers. The following container iteration patterns are recognized by the compiler:
for Element in ArrayExpr do Stmt;
for Element in StringExpr do Stmt;
for Element in SetExpr do Stmt;
for Element in CollectionExpr do Stmt;
The type of the iteration variable Element must match the type held in the container. With each iteration of the loop, the iteration variable holds the current collection member. As with regular for-loops, the iteration variable must be declared within the same block as the for statement. The iteration variable cannot be modified within the loop. This includes assignment, and passing the variable to a var parameter of a procedure. Doing so will result in a compile-time error.
Array expressions can be single or multidimensional, fixed length, or dynamic arrays. The array is traversed in increasing order, starting at the lowest array bound and ending at the array size minus one. The following code shows an example of traversing single, multi-dimensional, and dynamic arrays:
type
TIntArray = array[0..9] of Integer;
TGenericIntArray = array of Integer;
var
IArray1: array[0..9] of Integer = (1, 2, 3, 4, 5, 6, 7, 8, 9, 10);
IArray2: array[1..10] of Integer = (1, 2, 3, 4, 5, 6, 7, 8, 9, 10);
IArray3: array[1..2] of TIntArray = ((11, 12, 13, 14, 15, 16, 17, 18, 19, 20),
(21, 22, 23, 24, 25, 26, 27, 28, 29, 30));
MultiDimTemp: TIntArray;
IDynArray: TGenericIntArray;
I: Integer;
begin
for I in IArray1 do
begin
// Do something with I...
end;
// Indexing begins at lower array bound of 1.
for I in IArray2 do
begin
end;
// Iterating a multi-dimensional array
for MultiDimTemp in IArray3 do // Indexing from 1..2
for I in MultiDimTemp do // Indexing from 0..9
begin
end;
// Iterating over a dynamic array
IDynArray := IArray1;
for I in IDynArray do
begin
end;
The following example demonstrates iteration over string expressions:
var
C: Char;
S1, S2: String;
Counter: Integer;
OS1, OS2: ShortString;
AC: AnsiChar;
begin
S1 := 'Now is the time for all good men to come to the aid of their country.';
S2 := '';
for C in S1 do
S2 := S2 + C;
if S1 = S2 then
WriteLn('SUCCESS #1');
else
WriteLn('FAIL #1');
OS1 := 'When in the course of human events it becomes necessary to dissolve...';
OS2 := '';
for AC in OS1 do
OS2 := OS2 + AC;
if OS1 = OS2 then
WriteLn('SUCCESS #2');
else
WriteLn('FAIL #2');
end.
The following example demonstrates iteration over set expressions:
type
TMyThing = (one, two, three);
TMySet = set of TMyThing;
TCharSet = set of Char;
var
MySet: TMySet;
MyThing: TMyThing;
CharSet: TCharSet;
{$IF DEFINED(CLR)}
C: AnsiChar;
{$ELSE}
C: Char;
{$IFEND}
begin
MySet := [one, two, three];
for MyThing in MySet do
begin
// Do something with MyThing...
end;
CharSet := [#0..#255];
for C in CharSet do
begin
// Do something with C...
end;
end.
To use the for-in loop construct on a class, the class must implement a prescribed collection pattern. A type that implements the collection pattern must have the following attributes:
The class must contain a public instance method called GetEnumerator(). The GetEnumerator() method must return a class, interface, or record type.
The class, interface, or record returned by GetEnumerator() must contain a public instance method called MoveNext(). The MoveNext() method must return a Boolean.
The class, interface, or record returned by GetEnumerator() must contain a public instance, read-only property called Current. The type of the Current property must be the type contained in the collection.
If the enumerator type returned by GetEnumerator() implements the System.IDisposable interface, the compiler will call the IDisposable.Dispose method of the type when the loop terminates.
The following code demonstrates iterating over an enumerable container in Delphi.
type
TMyIntArray = array of Integer;
TMyEnumerator = class
Values: TMyIntArray;
Index: Integer;
public
constructor Create;
function GetCurrent: Integer;
function MoveNext: Boolean;
property Current: Integer read GetCurrent;
end;
TMyContainer = class
public
function GetEnumerator: TMyEnumerator;
end;
constructor TMyEnumerator.Create;
begin
inherited Create;
Values := TMyIntArray.Create(100, 200, 300);
Index := -1;
end;
function TMyEnumerator.MoveNext: Boolean;
begin
if Index < High(Values) then
begin
Inc(Index);
Result := True;
end
else
Result := False;
end;
function TMyEnumerator.GetCurrent: Integer;
begin
Result := Values[index];
end;
function TMyContainer.GetEnumerator: TMyEnumerator;
begin
Result := TMyEnumerator.Create;
end;
var
MyContainer: TMyContainer;
I: Integer;
Counter: Integer;
begin
MyContainer := TMyContainer.Create;
Counter := 0;
for I in MyContainer do
Inc(Counter, I);
WriteLn('Counter = ', Counter);
end.
The following classes and their descendents support the for-in syntax:
Classes.TList
Classes.TCollection
Classes.TStrings
Classes.TInterfaceList
Classes.TComponent
Menus.TMenuItem
ActnList.TCustomActionList
DB.TFields
ComCtrls.TListItems
ComCtrls.TTreeNodes
ComCtrls.TToolBar
Blocks and Scope
Declarations and statements are organized into blocks, which define local namespaces (or scopes) for labels and identifiers. Blocks allow a single identifier, such as a variable name, to have different meanings in different parts of a program. Each block is part of the declaration of a program, function, or procedure; each program, function, or procedure declaration has one block.
Blocks
A block consists of a series of declarations followed by a compound statement. All declarations must occur together at the beginning of the block. So the form of a block is
{declarations}
begin
{statements}
end
The declarations section can include, in any order, declarations for variables, constants (including resource strings), types, procedures, functions, and labels. In a program block, the declarations section can also include one or more exports clauses (see Libraries and packages).
For example, in a function declaration like
function UpperCase(const S: string): string;
var
Ch: Char;
L: Integer;
Source, Dest: PChar;
begin
end;
the first line of the declaration is the function heading and all of the succeeding lines make up the block. Ch, L, Source, and Dest are local variables; their declarations apply only to the UpperCase function block and override, in this block only, any declarations of the same identifiers that may occur in the program block or in the interface or implementation section of a unit.
Scope
An identifier, such as a variable or function name, can be used only within the scope of its declaration. The location of a declaration determines its scope. An identifier declared within the declaration of a program, function, or procedure has a scope limited to the block in which it is declared. An identifier declared in the interface section of a unit has a scope that includes any other units or programs that use the unit where the declaration occurs. Identifiers with narrower scope, especially identifiers declared in functions and procedures, are sometimes called local, while identifiers with wider scope are called global.
The rules that determine identifier scope are summarized below.
If the identifier is declared in ... its scope extends ...
the declaration section of a program, function, or procedure
from the point where it is declared to the end of the current block, including all blocks enclosed within that scope.
from the point where it is declared to the end of the unit, and to any other unit or program that uses that unit. (See Programs and Units .)
the implementation section of a unit, but not within the block of any function or procedure
from the point where it is declared to the end of the unit. The identifier is available to any function or procedure in the unit, including the initialization and finalization sections, if present.
the definition of a record type (that is, the identifier is the name of a field in the record)
from the point of its declaration to the end of the record-type definition. (See Records .)
the definition of a class (that is, the identifier is the name of a data field property or method in the class)
from the point of its declaration to the end of the class-type definition, and also includes descendants of the class and the blocks of all methods in the class and its descendants. (See Classes and Objects .)
Naming Conflicts
When one block encloses another, the former is called the outer block and the latter the inner block. If an identifier declared in an outer block is redeclared in an inner block, the inner declaration takes precedence over the outer one and determines the meaning of the identifier for the duration of the inner block. For example, if you declare a variable called MaxValue in the interface section of a unit, and then declare another variable with the same name in a function declaration within that unit, any unqualified occurrences of MaxValue in the function block are governed by the second, local declaration. Similarly, a function declared within another function creates a new, inner scope in which identifiers used by the outer function can be redeclared locally.
The use of multiple units further complicates the definition of scope. Each unit listed in a uses clause imposes a new scope that encloses the remaining units used and the program or unit containing the uses clause. The first unit in a uses clause represents the outermost scope and each succeeding unit represents a new scope inside the previous one. If two or more units declare the same identifier in their interface sections, an unqualified reference to the identifier selects the declaration in the innermost scope, that is, in the unit where the reference itself occurs, or, if that unit doesn't declare the identifier, in the last unit in the uses clause that does declare the identifier.
The System and SysInit units are used automatically by every program or unit. The declarations in System, along with the predefined types, routines, and constants that the compiler understands automatically, always have the outermost scope.
You can override these rules of scope and bypass an inner declaration by using a qualified identifier (see Qualified Identifiers ) or a with statement (see With Statements, above).
Related Concepts
Fundamental Syntactic Elements
Expressions
Borland® Copyright © 2005 Borland Software Corporation. All rights reserved.
Endret av elg-elg123
problemet ,loopen løse jeg på en annen måte.
hvis delphi ... er her , hvor er det da plassert hen ?
hvis man skal ha oversikt så må de forskjelige programmeringsspråkene skilles fra hverandre på en eller annen måte altså i egne grupper. slik det er nå blir alt blandet i en Lapskaus.
hvem finner da frem ?
Grunnen til at du ikke lenger finner noen Delphi/Pascal-forum på diskusjon.no er vel at de ansvarlige synes språket er for snevert til at de ønsker å vedlikeholde et eget forum for det. Det ble jo dessuten annonsert tidligere at det skulle skje en større opprydding på diskusjon.no.
Igrunnen synd, da det jo faktisk var en viss aktivitet i Delphi-forumet. Men, det gikk jo en god stund fra annonseringen til oppryddingen ble foretatt, så folk har jo hatt god tid til å ytre sin mening.
Werner
hvis man skal ha oversikt så må de forskjelige programmeringsspråkene skilles fra hverandre på en eller annen måte altså i egne grupper. slik det er nå blir alt blandet i en lapp gaus.
En lapp gaus?
Werner
  • 2 uker senere...
Tingo:
Alle fora må ha sitt første innlegg, også her på diskusjon.no. Sånn er det bare, og forstår man ikke det, så har man ikke lært å telle, for å si det mildt. Det er bare NAF og Trygg Trafikk som teller 1001-1002-1003.
Edit: Men du er sikkert velkommen til å skrive innlegg nr. 2!
Endret av tasle
hva med å gjøre disse forum kartalogiene mere tilgjengelig , da kommer det flere innlegg ?
å blande en gruppe samme mde fler blir bare lapskaus og ingen vet helt hva det svares på.
i det miste forsvinner oversikten man hadde.
hvorfor i all verden kan man ikke dele det opp i et nivå til ?
de som styre hvordan kartalogitreet skal være har rotet seg bort for lenge.
i stedet for å ha en god struktur så har de heller prioriter å ha minst mulig under grupper.
her virker det mot sin hensikt
for min del kan denne posten bare dø ut.
de son trenger den finner den ikke likevel
så lenge språket er nevnt i emnetittel går det vel som smurt? Skjønte med en gang at dette spørsmålet omhandlet Delphi, nå skjønner jeg bare ikke hvorfor jeg trykket på det... Trur det var for å se hvilken gal professor som fortsatt bruker Pascal :)
hvorfor kan det ikke være en kart-alogi for språk som ligner hverandre ?
ved å gjemme pascalspråket samme med alt annet ( som basic ,maskinkode - for de som liker det- eller annet sært programmeringsspråk) fører det til at det blir enda mindre aktivitet rund pascal språket .
det blir vanskeligere å skille de forskjelige innleggene fra hverandre.
i det minste burde man ha et filter som bare viser innlegg med det programmeringsspråket man ønsker å lete etter. nye innlegg ( gjelder alle programgrinespråkene) vil fort forsvinne til fordel for mange nye inlegg i de mere populære språkene
footnote: hva er det som er så galt med pascal ?
det er et av de få programmeringsspråkene som man lett oversikt i koden.
hvis man sikter til et annet popolært prgr.språk som C så er koden der mindre oversiktlig med parantesene som marker en blokk. i pascal har man Begin og End til dette.
forøvrig så finnes det flere prog.språk som er baser på nettopp pascal
Det er ikke noe galt med Delphi, det inneholder alt man trenger til alle formål, ikke bare Pascal-syntaksen. Også C#, C++ etc.
Men det er noen som alltid skal kverulere om hva som er best av Volvo eller Saab. Det fører ingen steds hen. Vettuge folk bruker vel tid til andre ting enn det. Det blir bare enda mer tull av forstå-seg-på'ere.
Pascal er ikke veldig utbredt.
Det er faktisk en fordel at den ligger her, fordi langt flere frekventerer denne kategorien enn det som var vanlig under Delphi/Kylix kategorien. Så det er større sannsynlighet for at noen faktisk svarer her.
Det er mange andre språk som også ble effektivisert bort, som Visual Basic, Ruby og Python.
jeg ville ha flytte delphi,kylix.. som en underkategori av denne kategorien.
nettopp for at det skal bli litt bedre strukturert.
jeg er veldig redd for at nye innlegg angående delphi og kylix forsvinner for fort nedover i oversikten til fordel for de språken som er mere aktive.
uansett hvor aktiv en kategori er så er det ikke alltid fordeler å slå dem sammen.
jeg lurer fortsatt på hvor de gamle postene angående delphi og kylix har tatt veien hen
Hvis du er så misfornøyd får du finne deg et annet forum. Det er flust av høyst aktive Delphi-forum rundt om kring i verden.
Werner
