Amiga 500 - Overgang til TV
Berzerk74
Her kjøper du den:
Original Amiga A520 Video Modulator (PAL)
Reagerte litt på navnet, men leste denne siden:
http://www.amiga-hardware.com/showhardware.cgi?HARDID=725
The A520 was a TV modulator that was generally supplied with the A500 series of machines but can be used with almost any Amiga. It converts the RGB port for use with a TV by supplying an RF (aerial lead) connector. The two audio outputs were also attached the modulator for sending the audio signals down the RF lead. The L H switch is for switching between two slightly different frequencies in case it was causing or receiving interference from another device such as a VCR.
Tror kanskje det er greit å kjøpe kabelen din også.. :-/
Husker egentlig ikke hvordan koblingene ble gjort.
Endret av KongRudi
