Feil ved brenning
paales
Hei.
Når jeg skal brenne data til en dvd+r dl så får jeg feil, har prøvd med 3 dvd-plater nå, og har prøvd både nero og imgburn. Fikk en logg når jeg prøvde nero, kanskje det hjelper.
Fikk opp feilmeldinga når den skulle verifisere.
Windows Vista 6.1
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 9.0.9.100
Internal Version: 9, 0, 9, 100
(Nero Express)
Recorder: <_NEC DVD_RW ND-3550A> Version: 1.05 - HA 1 TA 0 - 9.0.9.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <_NEC DVD_RW ND-3550A >Version: 1.05 - HA 1 TA 0 - 9.0.9.100
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3550A E: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1535MB (1572408kB)
Free physical memory: 744MB (762028kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.10.2009
UDF-kompilasjon
10:27:03 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
10:27:03 #2 Text 0 File Isodoc.cpp, Line 6789
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
10:27:03 #3 Text 0 File Burncd.cpp, Line 3563
Turn on Disc-At-Once, using DVD media
10:27:03 #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
10:27:03 #5 Text 0 File DlgWaitCD.cpp, Line 312
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3828047 (850:40.47, 7476MB)
10:27:03 #6 Text 0 File DlgWaitCD.cpp, Line 324
Write in overburning mode: NO (enabled: CD)
10:27:03 #7 Text 0 File DlgWaitCD.cpp, Line 2951
Recorder: _NEC DVD_RW ND-3550A, Media type: DVD+R DL
10:27:03 #8 Text 0 File DlgWaitCD.cpp, Line 499
>>> Protocol of DlgWaitCD activities: <<<
10:27:03 #9 Text 0 File ThreadedTransferInterface.cpp, Line 756
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 3828048 (3828048) = #3828048/850:40.48
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3828048 blocks [E: _NEC DVD_RW ND-3550A]
10:27:28 #10 Text 0 File ThreadedTransferInterface.cpp, Line 958
Prepare [E: _NEC DVD_RW ND-3550A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7839842304, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3828048 | 0 | 0x00
3828048 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:27:30 #11 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
10:27:30 #12 Text 0 File Burncd.cpp, Line 4362
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
10:27:30 #13 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
10:27:30 #14 Text 0 File Burncd.cpp, Line 4484
Cache writing successful.
10:27:30 #15 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
10:27:30 #16 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11,080 KB/s)
10:27:30 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2675
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:27:30 #18 Text 0 File DVDPlusDualLayer.cpp, Line 1856
GetDriveCaps: LAST LBA of layer 1 is 0
10:27:30 #19 Text 0 File DVDPlusDualLayer.cpp, Line 768
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
10:27:30 #20 CDR -1205 File DVDPlusDualLayer.cpp, Line 784
Burning Layer 1
10:27:30 #21 Text 0 File DVDPlusDualLayer.cpp, Line 794
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
10:27:30 #22 SPTI -1066 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAD 00 00 00 00 00 00 00 08 04 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 C0 00 07
Buffer x059b4e40: Len x804
10:27:30 #23 Text 0 File DVDR.cpp, Line 6851
Drive: _NEC DVD_RW ND-3550A
Book Type request [NEC]: DVD-ROM, write to RAM
select Book Type setting from RAM
Changing the Book Type was finished successfully, return code 0
10:27:30 #24 CDR -1207 File DVDR.cpp, Line 6559
Book Type automatically set to: DVD-ROM
10:27:30 #25 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: No
10:27:30 #26 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
10:27:30 #27 Text 0 File CUDFTransferItem2.cpp, Line 660
GenUDF2 FS Layout:
Sectors to be written: 3828048
Session Start: Sector 0
Volume Structure: Sector [0, 256] (257 Sectors)
Meta Data: Sector [257, 261] (5 Sectors)
Data: Sector [262, 3827751] (3827490 Sectors)
After Data: Sector [3827752, 3827759] (8 Sectors)
Trailer Track: Sector [3827760, 3828047] (288 Sectors)
GenUDF2 Parameters:
PrepTime: 10-04-2009 10:27:03
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: None
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 4173824
Multi Session Mode: Begin
Disc Type: DVD+R DL
OS Class: 0
Volume ID: Min plate
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 0597B008
VMS Rollback File: 00000000
Create ISO bridge: 0
ECC Block Length: 16
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 16
Make Writable: 0
Access Type: Read-only
10:37:30 #28 CDR -1206 File DVDPlusDualLayer.cpp, Line 2154
Burning Layer 2
10:37:30 #29 Text 0 File DVDPlusDualLayer.cpp, Line 2163
Perform layer 1 to 2 jump before writing at address 2086912 (1FD800h)
10:46:39 #30 Text 0 File WriterStatus.cpp, Line 245
<E: _NEC DVD_RW ND-3550A> start writing Lead-Out at LBA 3828048 (3A6950h), length 0 blocks
10:47:09 #31 Text 0 File DVDPlusRW.cpp, Line 853
Writing extended Lead-out supported: 01 h, return code: 0
supported / do not write extended Lead-out / revision 0.4x/1.xx style
10:47:56 #32 Text 0 File DVDPlusRW.cpp, Line 943
EndDAO: Last written address 3828048
10:47:56 #33 Text 0 File DVDR.cpp, Line 6851
10:47:56 #34 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
10:47:56 #35 Phase 37 File dlgbrnst.cpp, Line 1767
Burn process completed successfully at 8x (11,080 KB/s)
10:47:56 #36 Phase 78 File dlgbrnst.cpp, Line 1767
Data verification started
10:47:59 #37 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 590400
10:47:59 #38 Text 0 File CUDFTransferItem2.cpp, Line 660
GenUDF2 FS Layout:
GenUDF2 Parameters:
UDF Revision: 1.02
Session Start: 0
Disc Type: DVD+R DL
OS Class: 0
Make Writable: 0
10:48:07 #39 SPTI -1128 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1128)
CDB Data: 0x28 00 00 00 00 00 00 00 10 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x11
Sense Qual: 0x00
Sense Area: 0xF0 00 03 00 00 00 00 0A 00 00 00 00 11
Buffer x09400040: Len x8000
......... (samme meldinga fra #39 til #105)
10:52:27 #105 SPTI -1128 File SCSIPassThrough.cpp, Line 215
CDB Data: 0x28 00 00 00 04 10 00 00 10 00 00 00
Sense Code: 0x11
Sense Qual: 0x00
Sense Area: 0xF0 00 03 00 00 04 10 0A 00 00 00 00 11
10:52:27 #106 SectorVerify 20 File Cdrdrv.cpp, Line 11386
Read errors from sector 263 to 1055
D:\Spill\NHL.10.PAL.XBOX360-LoCAL\nhl10x360.iso
10:52:27 #107 CDR -1222 File Writer.cpp, Line 203
Verification aborted, too much errors
10:52:28 #108 Phase 81 File dlgbrnst.cpp, Line 1767
Data verification failed
10:52:28 #109 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:52:31 #110 Text 0 File Cdrdrv.cpp, Line 11444
DriveLocker: UnLockVolume completed
10:52:31 #111 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
