cola01 Skrevet 28. september 2009 Del Skrevet 28. september 2009 dette er erroren som kommer opp når jeg logger inn: Message: ...artographer_Professions\libs\Astrolabe\Astrolabe.lua:370: attempt to index local 'MinimapCompassRing' (a nil value) Time: 09/28/09 08:54:44 Count: 1 Stack: [string "Interface\FrameXML\BasicControls.xml:<Scrip..."]:18: in function <[string "Interface\FrameXML\BasicControls.xml:<Scrip..."]:4> [C]: ? ...artographer_Professions\libs\Astrolabe\Astrolabe.lua:370: in main chunk [C]: ? [C]: in function `pcall' Interface\AddOns\Cartographer\Cartographer.lua:928: in function `LoadLoadOnDemandModules' Interface\AddOns\Cartographer\Cartographer.lua:522: in function <Interface\AddOns\Cartographer\Cartographer.lua:370> [C]: ? ...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2461: in function <...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2436> ...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2510: in function <...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2503> ...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2583: in function <...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2546> ...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2694: in function <...AddOns\Cartographer\libs\LibRock-1.0\LibRock-1.0.lua:2689> ... (tail call): ? [C]: ? [string "safecall Dispatcher[1]"]:9: in function <[string "safecall Dispatcher[1]"]:5> (tail call): ? ...ventory\Externals\Ace3\AceAddon-3.0\AceAddon-3.0.lua:531: in function `EnableAddon' ...ventory\Externals\Ace3\AceAddon-3.0\AceAddon-3.0.lua:621: in function <...ventory\Externals\Ace3\AceAddon-3.0\AceAddon-3.0.lua:607> [C]: in function `LoadAddOn' Interface\FrameXML\UIParent.lua:232: in function `UIParentLoadAddOn' Interface\FrameXML\UIParent.lua:255: in function `CombatLog_LoadUI' Interface\FrameXML\UIParent.lua:502: in function <Interface\FrameXML\UIParent.lua:474> Locals: LIBRARY_VERSION_MAJOR = "Astrolabe-0.4" LIBRARY_VERSION_MINOR = 92 Astrolabe = <table> { IconsOnEdge_GroupChangeCallbacks = <table> { } IconsOnEdge = <table> { } MinimapUpdateMultiplier = 1 MinimapIconCount = 0 MinimapIcons = <table> { } IconsOnEdgeChanged = false GetCurrentPlayerPosition = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:311 ForceNextUpdate = false GetUnitPosition = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:275 TranslateWorldMapPosition = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:210 LastPlayerPosition = <table> { } GetVersion = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:55 WorldMapVisible = false ComputeDistance = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:149 } WorldMapSize = nil MinimapSize = nil ValidMinimapShapes = nil configConstants = <table> { MinimapUpdateMultiplier = true } AddedOrUpdatedIcons = <table> { } MinimapIconsMetatable = <table> { __index = <table> { } } twoPi = 6.2831853071796 atan2 = <function> defined =[C]:-1 sin = <function> defined =[C]:-1 cos = <function> defined =[C]:-1 abs = <function> defined =[C]:-1 sqrt = <function> defined =[C]:-1 min = <function> defined =[C]:-1 max = <function> defined =[C]:-1 yield = <function> defined =[C]:-1 GetFramerate = <function> defined =[C]:-1 assert = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:114 argcheck = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:120 getContPosition = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:132 tableCache = <table> { __mode = "v" } GetWorkingTable = <function> defined @Interface\AddOns\Cartographer_Professions\libs\Astrolabe\Astrolabe.lua:348 minimapRotationEnabled = false minimapShape = false MinimapCompassRing = nil (*temporary) = nil (*temporary) = nil (*temporary) = nil (*temporary) = nil (*temporary) = nil (*temporary) = nil (*temporary) = nil (*temporary) = nil (*tempo ,kan noen hjelp meg med dette? Lenke til kommentar
El Fantasma Skrevet 28. september 2009 Del Skrevet 28. september 2009 (endret) Oppdater addons, som f.eks Cartographer. Endret 28. september 2009 av Maverick2002 Lenke til kommentar
cola01 Skrevet 28. september 2009 Forfatter Del Skrevet 28. september 2009 Oppdater addons, som f.eks Cartographer. med wowmatrix ellns? Lenke til kommentar
El Fantasma Skrevet 28. september 2009 Del Skrevet 28. september 2009 Oppdater addons, som f.eks Cartographer. med wowmatrix ellns? Vil ikke anbefale wowmatrix. Bruk curse sin install client eller gjør det manuellt. Lenke til kommentar
