Kalibrering av TV-apparater - dine tips
  • 4 måneder senere...
  • 7 måneder senere...
hei
er det noen son vet om et bra kalibrerings program
hare en Crea Tierra lcd tv k32s om jeg ikke får helt bra bilde på
noen råd
Endret av vesletun
Har en Samsung LE-46A656 satt opp med innstillinger jeg fant på et annet forum og som passer meg utmerket:
http://www.avforums.com/forums/showthread.php?t=757072&page=4
Modell: LE-46A656
Post 52
Yeah man. However, I think I've cracked it.
I now have the ultimate settings, I'm so happy with the PQ now, I still can't believe just how good it looks. A BIG thanks to John Hodson for the White Balance settings, these have made a huge improvement! Following those settings, I've tweaked them slightly to make, what I feel, the ultimate setting. Following those settings, I made some minor changes, and really enjoyed watching Spiderman the other night. However, I watched Pirates of the Caribbean last night, and found they were just a tad too bright, as the blacks looks a little too grey. So I've made some more changes and I'm pleased to say I think I've cracked it. John's White Balance settings make the picture darker, hence why the backlight it up more than normal and also the brightness, as a result, this definately helps the black crush issue which is brilliant! My final settings use the HDMI Black option, so the screen is a little darker, but it's up to you if you want it or not. OK, here goes... Chaps, give this a go and let me know what you think.
Backlight - 5
Contrast - 95
Brightness - 60
Sharpness - 5
Colour - 56
Tint - 46/54
Black adjust - off
Dynamic Contrast - off
Gamma - +1
Colour Space - Auto
White Balance:
R-offset - 15
G-offset - 15
B-offset - 14
R-Gain - 19
G-Gain - 15
B-Gain - 26
Flesh Tone - 0
Edge Enhancement - off
Colour Tone - Warm 1
Digital NR - off
HDMI Black Level - Low
Energy Saving - Low - IMPORTANT
I feel these settings are superb for watching Blu-rays via a PS3. I have my PS3 setup so that the AV output is RGB, not automatic. You will need to do this if you want to control the HDMI Black Level. Also, make sure you have RGB range set to LIMITED and not full.
I advise using virtually the same settings for gaming as well. Change the backlight from 5 to 6, change the colour tone from Warm 1 to Normal and change the sharpness to 25.
If you feel the blacks are too much with the settings above, you can turn the HDMI Black Level to Normal, but you will have to adjust the brightness to match. With these exact settings, if I turn the HDMI Black Level to Normal, I would then adjust the Brightness from 60 to 50. Like I said earlier, I watched Spiderman with the HDMI Black Level on Normal and it was excellent. But if you want to take a little risk of black crush to get an ever better experience, run the settings EXACTLY as I have posted above.
  • 1 år senere...
  • 5 måneder senere...
De er kalibrert for å selge, men ikke for at man skal oppleve film slik regissøren har ment. Som regel er de litt for lyse, med for kraftige farger. Dynamisk bakbelysning og 100Hz+ kan være både irriterende og ødelegge "filmsløret".
Men hva som er riktig, er jo smak og behag og bruk...
Hei, jeg har tre spørsmål. Er det noen som vet om gode instillinger for Sony KDL 40HX75G, eller hvor jeg kan finne det?
Finnes det kalibrerings-cd/dvd-plater, og hvor jeg eventuelt får kjøpt det?
Eksisterer det ferdiglagde instillinger som man kan installere via usb-minnepinne eller lignende?
Hei.
Noen som vil dele sine kalibrerte innstillinger på Panasonic 55VT50? Vet at det er forskjellig fra panel til panel, men bare for en pekepinn?
  • 2 måneder senere...
  • 4 uker senere...
  • 8 måneder senere...
Trenger hjelp med kalibrering av
UE55F7005 ?!?! kan noen hjelpe meg??
Holder på med å kalibrere min LG TV for tiden også (Det er plasma så den må kjøres inn litt før sildet kalibreres). BEste tipset jeg kan gi deg er å laste ned AVSHD, dette er en gratis kalibrerings DVD/blueray. Den har alle de nødvendige mønsterene og har en grei gjennomgang av hvordan du skal kalibrere TV-er.
Du burde også skaffe deg ett såkalt "blue filter" for kalibreringsprosessen, det kan hende at din TV har et innebygd filter (sjekk manualen din) og i det tilfellet så kan du bruke det istedenfor. Om ikke så skaffet jeg mitt her.
Jeg håper dette hjelper deg på rett vei, og jeg ønsker deg lykke til med kalibreringsprosessen.
  • 11 måneder senere...
Hei! Har et Phillips 42" (5000 series) led tv med ambilight som jeg synes er vanskelig og stille riktig.. bruker tv til film, ps3 noe pc og litt nett tv.
Er det noen som kan hjelpe til med kalibrering, eller om det er mulig og få tak i en dvd som gjør dette?
Godt nyttår alle sammen :)
Er det ikke langt enklere å kjøpe en billig hardware kalibrator til skjerm; fest til skjerm koble pc opp via HDMI og kjør gjennom med manuelle justeringer av skjerm inntil fargene/lys og kontast sitter i henhold til måler. Mye enklere enn å drive tolkninger etter syn mot testbilder - det blir aldri rett. Øyne har en tendens til å tilvenne seg de mest mystiske ting (f.eks når man fargekorrigerer foto; alt ser tipptopp ut... man går bort fra skjerm for så å komme tilbake igjen for å se at det er kraftig fargestikk av f.eks grønn....
Så bruk målinger; ikke tolkninger hva man synes ser rett ut ;)
Endret av TGB
Vet ikke jeg, derfor jeg spør her ;)
er dette noe og bruke? https://www.hifiklubben.no/unsorted/-hi-fi-klubbens-kalibrerings-disk/
Endret av Yippee
Denne krever fortsatt tolkninger fra deg og ditt syn... det blir i beste fall i området; aldri korrekt.
Jeg tror denne gjør en langt bedre jobb:
http://www.fotovideo.no/Data/Kalibrering/X-Rite/X-Rite-i1-Display-Pro-Colorimeter-m-glassfilter-og-i1-Pro-kalprogram125485-p0000140096
Det skjer ikke.. kan snart kjøpe et nytt tv for den prisen...
TV brukes til mest Film, pc spilling, PS3, Netttv osv.. gidder ikke koste mye på det..
men som sagt, vanskelig og bedømme når det er bra og ikke...
Finnes billigere utgaver som gjør en bra jobb også. Spørsmålet er om man ønsker helt korrekte farger på tv'en eller ikke. Jeg bruker det på pc skjerm siden jeg jobber med foto (greit med rett farger da). Så ikke så vanskelig å hekte den opp til tv'en en gang i blant for å få kalibrert den også. Panelenes farger "drifter" litt over tid, så greit å kalibrere et par ganger i året som minimum.
Endret av TGB
Er klart om du driver med foto, så kan jeg skjønne du vil få det perfekt :)
men jeg vil bare ha et bedre bilde som jeg kan være fornøyd med.
Men uansett, takk for at du tok deg tid :)
