enkel WriteProcessMemory exempel?
Lenge siden sist jeg gjorde dette :!: Anbefaler deg å studere koden grundig til du forstår den ;) Sorry for at den ikke er kommentert... bare spør hvis du trenger hjelp til å forstå noe.
(Visual Studio 2008)
#include <iostream>
#include <windows.h>
#include <tlhelp32.h>
DWORD FindProcess(WCHAR* szFileName)
DWORD		  dwProcessId = 0;
PROCESSENTRY32 pe32;
HANDLE		 hSnapshot = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0);
if (hSnapshot != INVALID_HANDLE_VALUE)
	pe32.dwSize = sizeof(PROCESSENTRY32);
	BOOL loop = Process32First(hSnapshot, &pe32);
	while (loop)
		if (!wcscmp(pe32.szExeFile, szFileName))
			dwProcessId = pe32.th32ProcessID;
			break;
		loop = Process32Next(hSnapshot, &pe32);
	CloseHandle(hSnapshot);
return dwProcessId;
int main()
using namespace std;
DWORD dwProcessId = FindProcess(L"firefox.exe");
if (dwProcessId)
	HANDLE hProcess = OpenProcess(PROCESS_VM_WRITE | PROCESS_VM_OPERATION, false, dwProcessId);
	if (hProcess)
		LPVOID lpAddress = (LPVOID)0x00400000;
		int buffer	   = 5;
		DWORD oldprotect = 0;
		VirtualProtectEx(hProcess, lpAddress, sizeof(buffer), PAGE_EXECUTE_READWRITE, &oldprotect);
		if (!WriteProcessMemory(hProcess, lpAddress, &buffer, sizeof(buffer), NULL))
			cout << "WriteProcessMemory failed: Error " << GetLastError() << endl;
		VirtualProtectEx(hProcess, lpAddress, sizeof(buffer), oldprotect, NULL);
	} else cout << "Cannot open process. Error: " << GetLastError() << endl;
	CloseHandle(hProcess);
} else cout << "FindProcess failed (processid = 0).\n";
cin.ignore('\n', 255);
return 0;
En annen måte er å injecte en dll i prosessen og skifte på minne direkte.
F. eks: *(DWORD*)0x00400000 = 50;
Endret av Bartil
