Cookies? hva er det?
WHEN I SELECT A COUNTRY MY IP ADDRESS STAYS THE SAME
a) Some web pages might find your ip address with cookies or Javascript. Try deleting cookies on the Firefox menu for Tools->"Clear Private Data". You can also disable Javascript under Tools->Options->Content->UNcheck Enable Javascript.
b) Make sure that the web page you're using to find your IP address is not cached by clicking Reload or Refresh on your browser. Even better would be to use a different website to check your IP address
Kunne noen forklart hva de mener med at jeg skal slette "cookies" ????
Og hva er "clear private data" på norsk? please svar fort.
