***Detonator FX***
I had a little chat with Anton Nilsson from Nordichardware in regards to the 44.03 Detonator XP drivers.
Anton sent in a comparison chart of both versions. The topic of our discussion was differences between the two. Apparently there are none, except for WHQL certification and additional inf file which matches that in the beta version.
Here is a screenshot and a little print out
WHQL on the left, pre-release on the right.
Anton also mentions that the 44.03 drivers do not support floating point textures, floating point cubemaps, multiple rendering targets nor floating point volumetric textures.
http://www.nvnews.net/
