Synk verktøy for P800 mot MAC
For me there are much better workarounds, because with system 10.2.5 or higher you get bluetooth to work with your P800. That is great, because it lets you do many useful things: (Remember to have bluetooth activated on your phone and configured your Mac to use it before).
Install Software to your P800:
Simply highlight a .sis file and press 'command' + 'shift' + s, double click on your phones name (mine is named P800 - haven't been too creative with it...). Press 'okay' when an error message prompts up. The file will be transported via bluetooth regardless. Only problem: you will only be able to send the files one by one.
Copy all your Adress Book entries to your P800:
Open the Adress Book application. Click on 'All'. Highlight all entries you've got in your list by selecting one and susequently pressing 'command' + 'a'. Then send them to your P800 via bluetooth. Only problem: If you try to export them as a single multy-entry vcard before, your phone will not be able to read it. So do it just as I described it.
du kan jo prøve dette.
there is an app for the mac called 'mobilesync' which claims to sync sony ericsson phones (over bluetooth, infared etc) with entourage. i haven't tested it yet to see if it works, mainly because even though i have office all my data is in ical/addressbook!
eller dette
php/mysql users may install and sync their p800 with http://nicolas.bougues.net/syncml/ . And It works.
eller dette.
iSync v1.1 eller v2 SKAL støtte synkronisering mot P800, og etter det jeg har lest på div. forum, så skal denne oppdateringen være nylig sluppet.
ellers kan du jo se om du finner noen svar ang. det her (skal visst være skrevet endel om P800 og iSync synkronisering der):
http://discussions.info.apple.com/[email protected]@.3bbd7cb9
